Tank_Killer 7 Posted September 21, 2025 Posted September 21, 2025 4.8.11.0 is a bit of a trainwreck and i have been struggling with it since it came out. I cant use metadata with split tunneling as for some reason the requests will only go out IPV6 and doesnt fallback to a IPV4 request if not sucsessful. I have to disable my vpn and refresh metadata manually. ever since 4.8.11.0 metadata wont download completely i have so many series where images are broken and metadata is imcomplete and my library is a terrible looking mess Whenever i try to fully refresh metadata and "replace existing images" it hangs at 93% and the server becomes unresponsive and i have to restart the server. my metadata never completes. i have waited hours. I have deleted the libraries and re added them, when the metadata is refreshed it never completely downloads all the images and information. its completely broken and frustrating as heck my folder layout is "series name/season/all media files for the season" I will send the logs via PM as they contain too much information to post publicly
Luke 42289 Posted September 21, 2025 Posted September 21, 2025 HI there, can you please provide a specific example? How to Report a Problem Thanks !
