jelildude 13 Posted September 21, 2025 Posted September 21, 2025 Hey all, I'm running the latest beta server on DSM 7.2 and have a funny problem I can't figure out...hoping I can get some insight here! I have a TV Shows library and a Movies library. I use theme songs for both libraries (no plugin) just by adding the movie or show theme I want as an mp3 file in the main tv show/movie folder. This has always worked flawlessly for me but as of late only my TV Show theme songs are playing...none of my Movie themes will play. I've compared library settings for both TV Shows and Movies and they are the same. I've tested my Movie theme song MP3 files and they all play fine with Windows or Media Player Classic. I've rescanned my Movies library manually and even removed the Movies library and re-installed it....Nothing is helping...I'm totally at a loss but I'd like my theme songs back...HELP!!! Thanks in adavance to any replies!
GrimReaper 4896 Posted September 21, 2025 Posted September 21, 2025 2 hours ago, jelildude said: only my TV Show theme songs are playing...none of my Movie themes will play. That's odd. How are your movie theme songs named? Could you toggle off/on again Enable theme songs switch under General settings? You can also remove one movie theme, scan media library, add it back, run scan again, open that movie detail screen and post server log afterwards?
jelildude 13 Posted September 21, 2025 Author Posted September 21, 2025 6 minutes ago, GrimReaper said: That's odd. How are your movie theme songs named? Could you toggle off/on again Enable theme songs switch under General settings? You can also remove one movie theme, scan media library, add it back, run scan again, open that movie detail screen and post server log afterwards? Hi GrimReaper. Theme songs are named theme.mp3 for every movie/show. I've toggled the "enable theme songs" and even restarted the server between to no avail...I'll try removing one theme and rescanning and then add it back and rescan again....I'm rebooting the NAS right now....I'll update when I've tried your suggestion...Thanks for answering!
Neminem 1623 Posted September 21, 2025 Posted September 21, 2025 Hmm try are they located here /Movies /Home Alone (1990) Home Alone (1990).mp4 theme.mp3 or here /Movies /Home Alone (1990) Home Alone (1990).mp4 /theme-music song1.mp3 song2.wma song3.flac
jelildude 13 Posted September 21, 2025 Author Posted September 21, 2025 2 minutes ago, Neminem said: Hmm try are they located here /Movies /Home Alone (1990) Home Alone (1990).mp4 theme.mp3 or here /Movies /Home Alone (1990) Home Alone (1990).mp4 /theme-music song1.mp3 song2.wma song3.flac Neminem, They are as in your first example.....I tried rebooting the NAS and have lost it on the network : ( I'm now starting to think I may have a hardware issue with the NAS itself...hope not but this little "issue" with theme songs has exploded into something else entirely at this point. I'll update when I've figured the connectivity out...I appreciate your help!
jelildude 13 Posted September 21, 2025 Author Posted September 21, 2025 Okay NAS is back up... I've tried removing theme songs and re-scanning library (followed by adding themes back and re-scanning again) but still no luck....I'm stumped. I've even gone so far as to uninstall the Beta server and install the official release server, this did not work. Still only getting theme playback from the TV Shows folder and not from Movies folder even though both are structured exactly the same. /Movies /A Simple Plan A Simple Plan.mkv theme.mp3 /TV Shows /LOST Season 1 Season 2 Season 3 Season 4 Season 5 Season 6 theme.mp3 I don't understand what is going on. I've done everything I can think of including going through my Synology permissions and all that...
GrimReaper 4896 Posted September 21, 2025 Posted September 21, 2025 2 hours ago, jelildude said: I don't understand what is going on. I've done everything I can think of including going through my Synology permissions and all that... 4 hours ago, GrimReaper said: post server log afterwards
jelildude 13 Posted September 21, 2025 Author Posted September 21, 2025 Ok first time dealing with log files, hope I'm doing this right 2025-09-21 17:41:17.586 Info Main: Application path: /volume1/@appstore/EmbyServer/system/EmbyServer.dll 2025-09-21 17:41:17.671 Info NetworkManager: Adding event handler for NetworkChange.NetworkAddressChanged 2025-09-21 17:41:17.871 Info App: Setting default culture to en-US 2025-09-21 17:41:17.876 Info Main: Emby Server 4.9.1.34 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Mon Jul 21 23:14:27 CST 2025 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system 2025-09-21 17:41:17.876 Info Main: Logs path: /var/packages/EmbyServer/var/logs 2025-09-21 17:41:17.876 Info Main: Cache path: /var/packages/EmbyServer/var/cache 2025-09-21 17:41:17.876 Info Main: Internal metadata path: /var/packages/EmbyServer/var/metadata 2025-09-21 17:41:17.876 Info Main: DefaultThreadCurrentCulture: en-US 2025-09-21 17:41:17.876 Info Main: DefaultThreadCurrentUICulture: en-US 2025-09-21 17:41:17.876 Info Main: DefaultThreadCurrentUICulture: en-US 2025-09-21 17:41:17.880 Info Main: Server Friendly Name: x_secret1_x 2025-09-21 17:41:17.881 Info Main: Local time: 09/21/2025 17:41:17 -05:00 2025-09-21 17:41:17.882 Info Main: PID file: /var/packages/EmbyServer/var/EmbyServer.pid 2025-09-21 17:41:17.885 Info App: Emby Server Version: 4.9.1.34 2025-09-21 17:41:17.887 Info App: Loading assemblies 2025-09-21 17:41:17.906 Info App: File /var/packages/EmbyServer/var/plugins/Emby.XmlTV.dll has version 1.2.0.0 2025-09-21 17:41:17.906 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.XmlTV.dll has version 1.2.0.0 2025-09-21 17:41:17.906 Info App: File /var/packages/EmbyServer/var/plugins/Emby.PortMapper.dll has version 1.3.0.0 2025-09-21 17:41:17.906 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.PortMapper.dll has version 1.3.0.0 2025-09-21 17:41:17.907 Info App: File /var/packages/EmbyServer/var/plugins/Fanart.dll has version 1.0.16.0 2025-09-21 17:41:17.907 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Fanart.dll has version 1.0.16.0 2025-09-21 17:41:17.907 Info App: File /var/packages/EmbyServer/var/plugins/Emby.Webhooks.dll has version 1.0.36.0 2025-09-21 17:41:17.907 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.Webhooks.dll has version 1.0.36.0 2025-09-21 17:41:17.907 Info App: File /var/packages/EmbyServer/var/plugins/MovieDb.dll has version 1.8.5.0 2025-09-21 17:41:17.907 Info App: File /volume1/@appstore/EmbyServer/system/plugins/MovieDb.dll has version 1.8.5.0 2025-09-21 17:41:17.907 Info App: File /var/packages/EmbyServer/var/plugins/OpenSubtitles.dll has version 1.0.64.0 2025-09-21 17:41:17.907 Info App: File /volume1/@appstore/EmbyServer/system/plugins/OpenSubtitles.dll has version 1.0.64.0 2025-09-21 17:41:17.908 Info App: File /var/packages/EmbyServer/var/plugins/BlurayMounter.dll has version 1.0.3.0 2025-09-21 17:41:17.908 Info App: File /volume1/@appstore/EmbyServer/system/plugins/BlurayMounter.dll has version 1.0.3.0 2025-09-21 17:41:17.908 Info App: File /var/packages/EmbyServer/var/plugins/Emby.M3UTuner.dll has version 1.0.39.0 2025-09-21 17:41:17.908 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.M3UTuner.dll has version 1.0.39.0 2025-09-21 17:41:17.908 Info App: File /var/packages/EmbyServer/var/plugins/StudioImages.dll has version 1.0.3.0 2025-09-21 17:41:17.908 Info App: File /volume1/@appstore/EmbyServer/system/plugins/StudioImages.dll has version 1.0.3.0 2025-09-21 17:41:17.908 Info App: File /var/packages/EmbyServer/var/plugins/Emby.Dlna.dll has version 1.5.3.0 2025-09-21 17:41:17.909 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.Dlna.dll has version 1.5.2.0 2025-09-21 17:41:17.909 Info App: File /var/packages/EmbyServer/var/plugins/Emby.Server.CinemaMode.dll has version 1.0.48.0 2025-09-21 17:41:17.909 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.48.0 2025-09-21 17:41:17.909 Info App: File /var/packages/EmbyServer/var/plugins/MusicBrainz.dll has version 1.0.26.0 2025-09-21 17:41:17.909 Info App: File /volume1/@appstore/EmbyServer/system/plugins/MusicBrainz.dll has version 1.0.26.0 2025-09-21 17:41:17.909 Info App: File /var/packages/EmbyServer/var/plugins/Tvdb.dll has version 1.6.2.0 2025-09-21 17:41:17.910 Info App: File /volume1/@appstore/EmbyServer/system/plugins/Tvdb.dll has version 1.6.2.0 2025-09-21 17:41:17.910 Info App: File /var/packages/EmbyServer/var/plugins/MBBackup.dll has version 1.8.0.0 2025-09-21 17:41:17.910 Info App: File /volume1/@appstore/EmbyServer/system/plugins/MBBackup.dll has version 1.8.0.0 2025-09-21 17:41:17.910 Info App: File /var/packages/EmbyServer/var/plugins/EmbyGuideData.dll has version 1.0.18.0 2025-09-21 17:41:17.910 Info App: File /volume1/@appstore/EmbyServer/system/plugins/EmbyGuideData.dll has version 1.0.18.0 2025-09-21 17:41:17.910 Info App: File /var/packages/EmbyServer/var/plugins/AudioDb.dll has version 1.0.20.0 2025-09-21 17:41:17.910 Info App: File /volume1/@appstore/EmbyServer/system/plugins/AudioDb.dll has version 1.0.20.0 2025-09-21 17:41:17.910 Info App: File /var/packages/EmbyServer/var/plugins/NfoMetadata.dll has version 1.0.83.0 2025-09-21 17:41:17.910 Info App: File /volume1/@appstore/EmbyServer/system/plugins/NfoMetadata.dll has version 1.0.83.0 2025-09-21 17:41:17.910 Info App: File /var/packages/EmbyServer/var/plugins/OMDb.dll has version 1.0.22.0 2025-09-21 17:41:17.911 Info App: File /volume1/@appstore/EmbyServer/system/plugins/OMDb.dll has version 1.0.22.0 2025-09-21 17:41:17.911 Info App: File /var/packages/EmbyServer/var/plugins/DvdMounter.dll has version 1.0.1.0 2025-09-21 17:41:17.911 Info App: File /volume1/@appstore/EmbyServer/system/plugins/DvdMounter.dll has version 1.0.1.0 2025-09-21 17:41:17.951 Info App: Loading Emby.Api, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Web, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading MediaBrowser.Model, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading MediaBrowser.Common, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading MediaBrowser.Controller, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Providers, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Photos, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Server.Implementations, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.LiveTV, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.ActivityLog, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Server.MediaEncoding, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.LocalMetadata, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Notifications, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Web.GenericUI, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Codecs.Dxva, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Codecs, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Server.Connect, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.Server.Sync, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading EmbyServer, Version=4.9.1.34, Culture=neutral, PublicKeyToken=null 2025-09-21 17:41:17.951 Info App: Loading Emby.XmlTV, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.XmlTV.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.PortMapper, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.PortMapper.dll 2025-09-21 17:41:17.951 Info App: Loading Fanart, Version=1.0.16.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Fanart.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.Webhooks, Version=1.0.36.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.Webhooks.dll 2025-09-21 17:41:17.951 Info App: Loading MovieDb, Version=1.8.5.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/MovieDb.dll 2025-09-21 17:41:17.951 Info App: Loading OpenSubtitles, Version=1.0.64.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/OpenSubtitles.dll 2025-09-21 17:41:17.951 Info App: Loading BlurayMounter, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/BlurayMounter.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.M3UTuner, Version=1.0.39.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.M3UTuner.dll 2025-09-21 17:41:17.951 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/StudioImages.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.Dlna, Version=1.5.3.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.Dlna.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.Server.CinemaMode, Version=1.0.48.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.Server.CinemaMode.dll 2025-09-21 17:41:17.951 Info App: Loading MusicBrainz, Version=1.0.26.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/MusicBrainz.dll 2025-09-21 17:41:17.951 Info App: Loading Tvdb, Version=1.6.2.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Tvdb.dll 2025-09-21 17:41:17.951 Info App: Loading MBBackup, Version=1.8.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/MBBackup.dll 2025-09-21 17:41:17.951 Info App: Loading EmbyGuideData, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/EmbyGuideData.dll 2025-09-21 17:41:17.951 Info App: Loading AudioDb, Version=1.0.20.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/AudioDb.dll 2025-09-21 17:41:17.951 Info App: Loading NfoMetadata, Version=1.0.83.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/NfoMetadata.dll 2025-09-21 17:41:17.951 Info App: Loading OMDb, Version=1.0.22.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/OMDb.dll 2025-09-21 17:41:17.951 Info App: Loading DvdMounter, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/DvdMounter.dll 2025-09-21 17:41:17.951 Info App: Loading CoverArt, Version=4.1.28.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/CoverArt.dll 2025-09-21 17:41:17.951 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Mediabrowser.Plugins.Trailers.dll 2025-09-21 17:41:17.951 Info App: Loading statistics, Version=3.4.2.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Statistics.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.DataExplorer2, Version=4.9.1.13, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.DataExplorer2.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.DiagnosticsPlugin, Version=4.8.0.81, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.DiagnosticsPlugin.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.TranscodingTestPlugin, Version=4.8.5.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.TranscodingTestPlugin.dll 2025-09-21 17:41:17.951 Info App: Loading Emby.Bulky, Version=1.0.20.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.Bulky.dll 2025-09-21 17:41:17.951 Info App: Loading EpMetaRefresh, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/EpMetaRefresh.dll 2025-09-21 17:41:17.951 Info App: Loading TvMaze, Version=4.8.12.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/TvMaze.dll 2025-09-21 17:41:17.951 Info App: Loading DiskSpace, Version=1.0.6.4, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/DiskSpace.dll 2025-09-21 17:41:17.951 Info App: Loading playback_reporting, Version=2.1.0.7, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/playback_reporting.dll 2025-09-21 17:41:17.951 Info App: Loading EmbyReports, Version=1.0.51.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/EmbyReports.dll 2025-09-21 17:41:18.222 Info SqliteUserRepository: Initializing PooledDatabaseConnectionManager with pool size: 3 2025-09-21 17:41:18.228 Info SqliteUserRepository: Sqlite version: 3.49.2 2025-09-21 17:41:18.228 Info SqliteUserRepository: Sqlite compiler options: ATOMIC_INTRINSICS=1,COMPILER=gcc-10.3.0,DEFAULT_AUTOVACUUM,DEFAULT_CACHE_SIZE=-2000,DEFAULT_FILE_FORMAT=4,DEFAULT_JOURNAL_SIZE_LIMIT=-1,DEFAULT_MMAP_SIZE=0,DEFAULT_PAGE_SIZE=4096,DEFAULT_PCACHE_INITSZ=20,DEFAULT_RECURSIVE_TRIGGERS,DEFAULT_SECTOR_SIZE=4096,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_AUTOCHECKPOINT=1000,DEFAULT_WAL_SYNCHRONOUS=2,DEFAULT_WORKER_THREADS=0,DIRECT_OVERFLOW_READ,ENABLE_COLUMN_METADATA,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_MATH_FUNCTIONS,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MALLOC_SOFT_LIMIT=1024,MAX_ATTACHED=10,MAX_COLUMN=2000,MAX_COMPOUND_SELECT=500,MAX_DEFAULT_PAGE_SIZE=8192,MAX_EXPR_DEPTH=1000,MAX_FUNCTION_ARG=1000,MAX_LENGTH=1000000000,MAX_LIKE_PATTERN_LENGTH=50000,MAX_MMAP_SIZE=0x7fff0000,MAX_PAGE_COUNT=0xfffffffe,MAX_PAGE_SIZE=65536,MAX_SCHEMA_RETRY=25,MAX_SQL_LENGTH=1000000000,MAX_TRIGGER_DEPTH=1000,MAX_VARIABLE_NUMBER=250000,MAX_VDBE_OP=250000000,MAX_WORKER_THREADS=8,MUTEX_PTHREADS,OMIT_LOOKASIDE,OMIT_SHARED_CACHE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2025-09-21 17:41:18.228 Info SqliteUserRepository: Sqlite ThreadSafe: 1 2025-09-21 17:41:18.228 Info SqliteUserRepository: Sqlite ThreadingMode: MultiThreaded 2025-09-21 17:41:18.228 Info SqliteUserRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/users.db. isReadOnly: False 2025-09-21 17:41:18.239 Info SqliteUserRepository: Default journal_mode for /var/packages/EmbyServer/var/data/users.db is wal 2025-09-21 17:41:18.245 Info SqliteUserRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:18.247 Info SqliteUserRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.247 Info SqliteUserRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.247 Info SqliteUserRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.247 Info SqliteUserRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.247 Info SqliteUserRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.311 Info SqliteItemRepository: Initializing PooledDatabaseConnectionManager with pool size: 20 2025-09-21 17:41:18.314 Info AuthenticationRepository: Initializing PooledDatabaseConnectionManager with pool size: 5 2025-09-21 17:41:18.356 Info ActivityRepository: Initializing PooledDatabaseConnectionManager with pool size: 3 2025-09-21 17:41:18.357 Info ActivityRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/activitylog.db. isReadOnly: False 2025-09-21 17:41:18.358 Info ActivityRepository: Default journal_mode for /var/packages/EmbyServer/var/data/activitylog.db is wal 2025-09-21 17:41:18.358 Info ActivityRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:18.358 Info ActivityRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.358 Info ActivityRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.358 Info ActivityRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.358 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.358 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.388 Info NetworkManager: Detecting local network addresses 2025-09-21 17:41:18.389 Info NetworkManager: networkInterface: Ethernet eth1, Speed: 1000000000, Description: eth1 2025-09-21 17:41:18.393 Info NetworkManager: GatewayAddresses: 192.168.1.1 2025-09-21 17:41:18.393 Info NetworkManager: UnicastAddresses: 192.168.1.80 2025-09-21 17:41:18.394 Info NetworkManager: networkInterface: Loopback lo, Speed: -1, Description: lo 2025-09-21 17:41:18.394 Info NetworkManager: GatewayAddresses: 2025-09-21 17:41:18.402 Info NetworkManager: UnicastAddresses: 127.0.0.1,::1 2025-09-21 17:41:18.442 Info NetworkManager: Detected local ip addresses: [{"IPAddress":"192.168.1.80","HasGateWayAddress":true,"PrefixLength":24,"IPv4Mask":"255.255.255.0"},{"IPAddress":"127.0.0.1","HasGateWayAddress":false,"PrefixLength":8,"IPv4Mask":"255.0.0.0"},{"IPAddress":"::1","HasGateWayAddress":false,"PrefixLength":128}] 2025-09-21 17:41:18.451 Info App: Adding HttpListener prefix http://+:8096/ 2025-09-21 17:41:18.498 Info AuthenticationRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/authentication.db. isReadOnly: False 2025-09-21 17:41:18.499 Info AuthenticationRepository: Default journal_mode for /var/packages/EmbyServer/var/data/authentication.db is wal 2025-09-21 17:41:18.499 Info AuthenticationRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:18.499 Info AuthenticationRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.499 Info AuthenticationRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.499 Info AuthenticationRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.499 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.499 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.505 Info SqliteItemRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/library.db. isReadOnly: False 2025-09-21 17:41:18.512 Info SqliteItemRepository: Default journal_mode for /var/packages/EmbyServer/var/data/library.db is wal 2025-09-21 17:41:18.512 Info SqliteItemRepository: PRAGMA cache_size=-131072 2025-09-21 17:41:18.512 Info SqliteItemRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.512 Info SqliteItemRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.512 Info SqliteItemRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.512 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.512 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.518 Info SqliteItemRepository: Init Complete 2025-09-21 17:41:18.522 Info SqliteItemRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/library.db. isReadOnly: True 2025-09-21 17:41:18.523 Info SqliteItemRepository: PRAGMA cache_size=-131072 2025-09-21 17:41:18.523 Info SqliteItemRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.523 Info SqliteItemRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.523 Info SqliteItemRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.523 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.523 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.632 Info SqliteUserRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/users.db. isReadOnly: True 2025-09-21 17:41:18.632 Info SqliteUserRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:18.632 Info SqliteUserRepository: PRAGMA page_size=4096 2025-09-21 17:41:18.632 Info SqliteUserRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:18.632 Info SqliteUserRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:18.632 Info SqliteUserRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:18.633 Info SqliteUserRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:18.937 Info App: Emby Server 4.9.1.34 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Mon Jul 21 23:14:27 CST 2025 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system 2025-09-21 17:41:18.937 Info App: Logs path: /var/packages/EmbyServer/var/logs 2025-09-21 17:41:18.937 Info App: Cache path: /var/packages/EmbyServer/var/cache 2025-09-21 17:41:18.937 Info App: Internal metadata path: /var/packages/EmbyServer/var/metadata 2025-09-21 17:41:18.937 Info App: Transcoding temporary files path: /var/packages/EmbyServer/var/transcoding-temp 2025-09-21 17:41:18.937 Info App: DefaultThreadCurrentCulture: en-US 2025-09-21 17:41:18.937 Info App: DefaultThreadCurrentUICulture: en-US 2025-09-21 17:41:18.937 Info App: DefaultThreadCurrentUICulture: en-US 2025-09-21 17:41:18.937 Info App: Server Friendly Name: x_secret1_x 2025-09-21 17:41:18.937 Info App: Local time: 09/21/2025 17:41:18 -05:00 2025-09-21 17:41:18.965 Info EpMetaRefresh - Plugin: Plugin Loaded 2025-09-21 17:41:19.501 Error Server-0HNFPBVTIP8B4:00000001: Error processing request *** Error Report *** Version: 4.9.1.34 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Mon Jul 21 23:14:27 CST 2025 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Common.Extensions.ServiceUnavailableException: MediaBrowser.Common.Extensions.ServiceUnavailableException: Emby Server is loading. Please try again shortly. at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, RestPath restPath, String urlString, String localPath, String contentTypeInPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2025-09-21 17:41:19.522 Info Server-0HNFPBVTIP8B4:00000001: http/1.1 Response 503 to host1. Time: 32ms. GET http://192.168.1.80:8096/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:41:20.307 Info FfmpegManager: FFMpeg: /var/packages/EmbyServer/target/bin/ffmpeg 2025-09-21 17:41:20.307 Info FfmpegManager: FFProbe: /var/packages/EmbyServer/target/bin/ffprobe 2025-09-21 17:41:20.308 Info FfmpegManager: FFDetect: /var/packages/EmbyServer/target/bin/ffdetect 2025-09-21 17:41:20.314 Info Skia: SkiaSharp version: 2.88.0.0 2025-09-21 17:41:20.328 Info libvips: NetVips version: 3.0.0.0 2025-09-21 17:41:20.330 Info ImageProcessor: Adding image processor Skia 2025-09-21 17:41:20.330 Info ImageProcessor: Adding image processor libvips 2025-09-21 17:41:20.420 Info NewMediaReportNotification - TaskNotifictionReport: NewMediaReportNotification Loaded 2025-09-21 17:41:20.421 Info UserActivityReportNotification - TaskNotifictionReport: UserActivityReportNotification Loaded 2025-09-21 17:41:20.422 Info PlaybackReporting - TaskRunBackup: TaskCleanDb Loaded 2025-09-21 17:41:20.436 Error SystemService-0HNFPBVTIP8B4:00000002: Error processing request *** Error Report *** Version: 4.9.1.34 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Mon Jul 21 23:14:27 CST 2025 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Common.Extensions.ServiceUnavailableException: MediaBrowser.Common.Extensions.ServiceUnavailableException: Emby Server is loading. Please try again shortly. at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, RestPath restPath, String urlString, String localPath, String contentTypeInPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2025-09-21 17:41:20.437 Info SystemService-0HNFPBVTIP8B4:00000002: http/1.1 Response 503 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:41:20.444 Info TaskManager: Daily trigger for Video preview thumbnail extraction set to fire at 09/22/2025 02:00:00, which is 498.65927789333335 minutes from now. 2025-09-21 17:41:20.500 Info TaskManager: Daily trigger for Rotate log file set to fire at 09/22/2025 00:00:00, which is 378.65833173666664 minutes from now. 2025-09-21 17:41:20.506 Info TaskManager: Queueing task HardwareDetectionScheduledTask 2025-09-21 17:41:20.510 Info TaskManager: Executing Hardware Detection 2025-09-21 17:41:20.532 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /var/packages/EmbyServer/target/bin/ffmpeg -hide_banner -version 2025-09-21 17:41:20.557 Info TaskManager: Daily trigger for Emby Server Backup set to fire at 09/22/2025 00:10:00, which is 388.65736979166667 minutes from now. 2025-09-21 17:41:20.562 Info TaskManager: Daily trigger for Calculate statistics for TV Shows set to fire at 09/22/2025 00:15:00, which is 393.6572969833333 minutes from now. 2025-09-21 17:41:20.563 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 2025-09-21 17:41:20.563 Info TaskManager: Daily trigger for Refresh Recently Aired Episodes set to fire at 09/22/2025 03:00:00, which is 558.6572743033333 minutes from now. 2025-09-21 17:41:20.565 Info TaskManager: Daily trigger for Trim Db set to fire at 09/22/2025 00:05:00, which is 383.6572404483333 minutes from now. 2025-09-21 17:41:20.566 Info TaskManager: Daily trigger for Create Playlists set to fire at 09/22/2025 03:00:00, which is 558.65723115 minutes from now. 2025-09-21 17:41:20.566 Info TaskManager: Daily trigger for New Media Notification set to fire at 09/22/2025 06:00:00, which is 738.6572223566667 minutes from now. 2025-09-21 17:41:20.567 Info TaskManager: Daily trigger for User Activity Notification set to fire at 09/22/2025 00:20:00, which is 398.65721355833335 minutes from now. 2025-09-21 17:41:20.570 Info App: ServerId: 4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:41:20.585 Info FfmpegManager: FfmpegValidator.Validate complete 2025-09-21 17:41:20.632 Info App: Starting entry point Emby.Server.Implementations.Networking.RemoteAddressEntryPoint 2025-09-21 17:41:20.633 Info App: Loading data from /var/packages/EmbyServer/var/data/wan.dat 2025-09-21 17:41:20.635 Info App: Entry point completed: Emby.Server.Implementations.Networking.RemoteAddressEntryPoint. Duration: 0.002986 seconds 2025-09-21 17:41:20.635 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2025-09-21 17:41:20.636 Info App: Loading data from /var/packages/EmbyServer/var/data/connect.txt 2025-09-21 17:41:20.637 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0019708 seconds 2025-09-21 17:41:20.637 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2025-09-21 17:41:20.660 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0231944 seconds 2025-09-21 17:41:20.660 Info App: Core startup complete 2025-09-21 17:41:20.661 Info App: Starting entry point Emby.TranscodingTestPlugin.Plugin 2025-09-21 17:41:20.664 Info App: Entry point completed: Emby.TranscodingTestPlugin.Plugin. Duration: 0.0026889 seconds 2025-09-21 17:41:20.664 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2025-09-21 17:41:20.665 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0012411 seconds 2025-09-21 17:41:20.665 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistUpgradeEntryPoint 2025-09-21 17:41:20.666 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistUpgradeEntryPoint. Duration: 0.0013019 seconds 2025-09-21 17:41:20.666 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2025-09-21 17:41:20.667 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0002776 seconds 2025-09-21 17:41:20.667 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2025-09-21 17:41:20.715 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0481321 seconds 2025-09-21 17:41:20.715 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2025-09-21 17:41:20.715 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0003863 seconds 2025-09-21 17:41:20.715 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2025-09-21 17:41:20.715 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001372 seconds 2025-09-21 17:41:20.715 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2025-09-21 17:41:20.716 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.000796 seconds 2025-09-21 17:41:20.716 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LogLibrariesEntryPoint 2025-09-21 17:41:20.718 Info App: Libraries Server Configuration: CollapseVideoFolders: False Library: Music, id: 5493, CollectionType: music, CollapseSingleItemFolders: False Configured paths: /volume1/SYNOLOGY/MUSIC Library Folder: MUSIC, id: 5494: path: /volume1/SYNOLOGY/MUSIC Library: BassBuzz, id: 12354, CollectionType: , CollapseSingleItemFolders: False Configured paths: /volume1/SYNOLOGY/Bass Lessons Library Folder: Bass Lessons, id: 12355: path: /volume1/SYNOLOGY/Bass Lessons Library: Audiobooks, id: 18090, CollectionType: audiobooks, CollapseSingleItemFolders: False Configured paths: /volume1/SYNOLOGY/Audiobooks Library Folder: Audiobooks, id: 18091: path: /volume1/SYNOLOGY/Audiobooks Library: TV Shows, id: 24400, CollectionType: tvshows, CollapseSingleItemFolders: False Configured paths: /volume1/SYNOLOGY/HD TV Series Library Folder: HD TV Series, id: 24401: path: /volume1/SYNOLOGY/HD TV Series Library: Movies, id: 30636, CollectionType: movies, CollapseSingleItemFolders: False Configured paths: /volume1/SYNOLOGY/1080p Movies Library Folder: 1080p Movies, id: 30637: path: /volume1/SYNOLOGY/1080p Movies 2025-09-21 17:41:20.718 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LogLibrariesEntryPoint. Duration: 0.0019304 seconds 2025-09-21 17:41:20.718 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2025-09-21 17:41:20.720 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0016801 seconds 2025-09-21 17:41:20.720 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2025-09-21 17:41:20.720 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0003316 seconds 2025-09-21 17:41:20.720 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2025-09-21 17:41:20.721 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0002242 seconds 2025-09-21 17:41:20.721 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2025-09-21 17:41:20.721 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0002626 seconds 2025-09-21 17:41:20.721 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2025-09-21 17:41:20.725 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0040479 seconds 2025-09-21 17:41:20.725 Info App: Starting entry point Emby.LiveTV.EntryPoint 2025-09-21 17:41:20.725 Info SoftwareCodecProvider: h264, libx264, x264, V-E-libx264 2025-09-21 17:41:20.725 Info SoftwareCodecProvider: hevc, libx265, x265, V-E-libx265 2025-09-21 17:41:20.726 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2, V-E-mpeg4 2025-09-21 17:41:20.727 Info LiveTV: Loading live tv data from /var/packages/EmbyServer/var/data/livetv/timers 2025-09-21 17:41:20.728 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /volume1/SYNOLOGY/1080p Movies for item 30637 2025-09-21 17:41:20.728 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.0029772 seconds 2025-09-21 17:41:20.728 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2025-09-21 17:41:20.729 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.001239 seconds 2025-09-21 17:41:20.729 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2025-09-21 17:41:20.730 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0005658 seconds 2025-09-21 17:41:20.730 Info App: Starting entry point Emby.Notifications.NotificationManagerEntryPoint 2025-09-21 17:41:20.731 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3), V-E-msmpeg4 2025-09-21 17:41:20.731 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2025-09-21 17:41:20.731 Info SoftwareCodecProvider: av1, libaom-av1, libaom-av1, V-E-libaom_av1 2025-09-21 17:41:20.742 Info SoftwareCodecProvider: h264, libx264, x264, V-E-libx264 2025-09-21 17:41:20.742 Info SoftwareCodecProvider: hevc, libx265, x265, V-E-libx265 2025-09-21 17:41:20.742 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2, V-E-mpeg4 2025-09-21 17:41:20.742 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3), V-E-msmpeg4 2025-09-21 17:41:20.742 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2025-09-21 17:41:20.743 Info Notifications: Registering event nofitier Activity Log 2025-09-21 17:41:20.743 Info SoftwareCodecProvider: av1, libaom-av1, libaom-av1, V-E-libaom_av1 2025-09-21 17:41:20.743 Info Notifications: Registering event nofitier Emby Server User Notifications 2025-09-21 17:41:20.743 Info Notifications: Registering event factory CoreNotificationTypeFactory 2025-09-21 17:41:20.743 Info Notifications: Registering event factory BackupNotificationTypeFactory 2025-09-21 17:41:20.743 Info Notifications: Registering event factory MyNotifications 2025-09-21 17:41:20.744 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /volume1/SYNOLOGY/Audiobooks for item 18091 2025-09-21 17:41:20.750 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /volume1/SYNOLOGY/Bass Lessons for item 12355 2025-09-21 17:41:20.756 Info App: Entry point completed: Emby.Notifications.NotificationManagerEntryPoint. Duration: 0.0259095 seconds 2025-09-21 17:41:20.756 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2025-09-21 17:41:20.757 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0011796 seconds 2025-09-21 17:41:20.757 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2025-09-21 17:41:20.758 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /volume1/SYNOLOGY/HD TV Series for item 24401 2025-09-21 17:41:20.758 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 8.41E-05 seconds 2025-09-21 17:41:20.758 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2025-09-21 17:41:20.786 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /var/packages/EmbyServer/target/bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2025-09-21 17:41:20.813 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /volume1/SYNOLOGY/MUSIC for item 5494 2025-09-21 17:41:20.814 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0560898 seconds 2025-09-21 17:41:20.814 Info App: Starting entry point MovieDb.Security.PluginStartup 2025-09-21 17:41:20.816 Info App: Entry point completed: MovieDb.Security.PluginStartup. Duration: 0.00199 seconds 2025-09-21 17:41:20.816 Info App: Starting entry point Emby.Security.PluginSecurityManager 2025-09-21 17:41:20.817 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.64E-05 seconds 2025-09-21 17:41:20.817 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2025-09-21 17:41:20.820 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0029768 seconds 2025-09-21 17:41:20.820 Info App: Starting entry point Tvdb.EntryPoint 2025-09-21 17:41:20.821 Info App: Entry point completed: Tvdb.EntryPoint. Duration: 0.0011623 seconds 2025-09-21 17:41:20.821 Info App: Starting entry point MBBackup.ServerEntryPoint 2025-09-21 17:41:20.821 Info App: Entry point completed: MBBackup.ServerEntryPoint. Duration: 4.54E-05 seconds 2025-09-21 17:41:20.821 Info App: Starting entry point NfoMetadata.EntryPoint 2025-09-21 17:41:20.821 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0001577 seconds 2025-09-21 17:41:20.821 Info App: Starting entry point CoverArt.ServerEntryPoint 2025-09-21 17:41:20.836 Info CoverArt: CoverArt plugin loading SkiaCoverArtImageProcessor image processor 2025-09-21 17:41:20.837 Info CoverArt: CoverArt plugin loading NetVipsCoverArtImageProcessor image processor 2025-09-21 17:41:20.848 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 0 2025-09-21 17:41:20.887 Info App: Init BeginReceive on 0.0.0.0 2025-09-21 17:41:20.887 Info App: Init BeginReceive on 0.0.0.0 2025-09-21 17:41:20.888 Info App: Init BeginReceive on 192.168.1.80 2025-09-21 17:41:20.888 Info App: Init BeginReceive on 127.0.0.1 2025-09-21 17:41:20.895 Info App: Entry point completed: CoverArt.ServerEntryPoint. Duration: 0.0737796 seconds 2025-09-21 17:41:20.895 Info App: Starting entry point MediaBrowser.Plugins.Trailers.EntryPoint 2025-09-21 17:41:20.895 Info App: Entry point completed: MediaBrowser.Plugins.Trailers.EntryPoint. Duration: 4.36E-05 seconds 2025-09-21 17:41:20.895 Info App: Starting entry point Emby.Bulky.BulkyPluginEntryPoint 2025-09-21 17:41:20.895 Info App: Entry point completed: Emby.Bulky.BulkyPluginEntryPoint. Duration: 3.37E-05 seconds 2025-09-21 17:41:20.895 Info App: Starting entry point playback_reporting.EventMonitorEntryPoint 2025-09-21 17:41:20.895 Info PlaybackReporting - EventMonitorEntryPoint: EventMonitorEntryPoint Running 2025-09-21 17:41:20.896 Info PlaybackReporting - EventMonitorEntryPoint: ActivityRepository : Creating 2025-09-21 17:41:20.897 Info PlaybackReporting - EventMonitorEntryPoint: ActivityRepository : CreateConnection : /var/packages/EmbyServer/var/data/playback_reporting.db 2025-09-21 17:41:20.897 Info PlaybackReporting - EventMonitorEntryPoint: ActivityRepository : ConnectionCreated : 36808710 2025-09-21 17:41:20.897 Info PlaybackReporting - EventMonitorEntryPoint: ActivityRepository : New Instance Created : 62842937 2025-09-21 17:41:20.898 Info PlaybackReporting - EventMonitorEntryPoint: Table Actual Cols : DateCreated DATETIME, UserId TEXT, ItemId TEXT, ItemType TEXT, ItemName TEXT, PlaybackMethod TEXT, ClientName TEXT, DeviceName TEXT, PlayDuration INT, PauseDuration INT, RemoteAddress TEXT, TranscodeReasons TEXT 2025-09-21 17:41:20.898 Info PlaybackReporting - EventMonitorEntryPoint: Table Alter SQL : 2025-09-21 17:41:20.898 Info App: Entry point completed: playback_reporting.EventMonitorEntryPoint. Duration: 0.0030665 seconds 2025-09-21 17:41:20.898 Info App: All entry points have started 2025-09-21 17:41:20.899 Info PlaybackReporting - EventMonitorEntryPoint: PlaybackMonitoringTask : Started 2025-09-21 17:41:20.947 Info VaapiCodecProvider: Adapter #0: 'GeminiLake UHD Graphics 600' Id:12677 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 23.4.3 (a9f272496), Vendor: Intel Corporation) 2025-09-21 17:41:21.058 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: /var/packages/EmbyServer/target/bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2025-09-21 17:41:21.086 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 2025-09-21 17:41:21.146 Info QuickSyncCodecProvider: Adapter #0: 'GeminiLake UHD Graphics 600' Id:12677 (Driver: , Vendor: 32902, SDK Version: 1.35) 2025-09-21 17:41:21.186 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /var/packages/EmbyServer/target/bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2025-09-21 17:41:21.188 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 - Failed 2025-09-21 17:41:21.446 Info AuthenticationRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/authentication.db. isReadOnly: True 2025-09-21 17:41:21.446 Info AuthenticationRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:21.446 Info AuthenticationRepository: PRAGMA page_size=4096 2025-09-21 17:41:21.446 Info AuthenticationRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:21.446 Info AuthenticationRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:21.446 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:21.446 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:22.282 Info CodecManager: CodecList: Decoders mpeg2video VAAPI GeminiLake UHD Graphics 600 - MPEG-2 QuickSync GeminiLake UHD Graphics 600 - MPEG-2 h264 VAAPI GeminiLake UHD Graphics 600 - H.264 (AVC) QuickSync GeminiLake UHD Graphics 600 - H.264 (AVC) vc1 VAAPI GeminiLake UHD Graphics 600 - VC-1 QuickSync GeminiLake UHD Graphics 600 - VC-1 vp8 VAAPI GeminiLake UHD Graphics 600 - VP8 QuickSync GeminiLake UHD Graphics 600 - VP8 hevc VAAPI GeminiLake UHD Graphics 600 - H.265 (HEVC) QuickSync GeminiLake UHD Graphics 600 - H.265 (HEVC) vp9 VAAPI GeminiLake UHD Graphics 600 - VP9 QuickSync GeminiLake UHD Graphics 600 - VP9 av1 QuickSync GeminiLake UHD Graphics 600 - AV1 Encoders h264 VAAPI GeminiLake UHD Graphics 600 - H.264 (AVC) QuickSync GeminiLake UHD Graphics 600 - H.264 (AVC) hevc VAAPI GeminiLake UHD Graphics 600 - H.265 (HEVC) QuickSync GeminiLake UHD Graphics 600 - H.265 (HEVC) 2025-09-21 17:41:22.283 Info TaskManager: Hardware Detection Completed after 0 minute(s) and 1 seconds 2025-09-21 17:41:23.253 Info AuthenticationRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/authentication.db. isReadOnly: True 2025-09-21 17:41:23.253 Info AuthenticationRepository: PRAGMA cache_size=-65536 2025-09-21 17:41:23.253 Info AuthenticationRepository: PRAGMA page_size=4096 2025-09-21 17:41:23.253 Info AuthenticationRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:23.253 Info AuthenticationRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:23.253 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:23.253 Info AuthenticationRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:23.312 Info SqliteItemRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/library.db. isReadOnly: True 2025-09-21 17:41:23.313 Info SqliteItemRepository: PRAGMA cache_size=-131072 2025-09-21 17:41:23.313 Info SqliteItemRepository: PRAGMA page_size=4096 2025-09-21 17:41:23.313 Info SqliteItemRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:23.313 Info SqliteItemRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:23.313 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:23.313 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:23.327 Info SqliteItemRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/library.db. isReadOnly: True 2025-09-21 17:41:23.328 Info SqliteItemRepository: PRAGMA cache_size=-131072 2025-09-21 17:41:23.328 Info SqliteItemRepository: PRAGMA page_size=4096 2025-09-21 17:41:23.328 Info SqliteItemRepository: PRAGMA foreign_keys=1 2025-09-21 17:41:23.328 Info SqliteItemRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:41:23.328 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:41:23.328 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:41:23.497 Info TaskManager: Queueing task PluginUpdateTask 2025-09-21 17:41:23.498 Info TaskManager: Queueing task SystemUpdateTask 2025-09-21 17:41:23.498 Info TaskManager: Executing Check for application updates 2025-09-21 17:41:23.506 Info TaskManager: Executing Check for plugin updates 2025-09-21 17:41:23.512 Info TaskManager: Queueing task SubtitleOcrDataTask 2025-09-21 17:41:23.512 Info TaskManager: Executing Download OCR Data 2025-09-21 17:41:23.516 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2025-09-21 17:41:23.519 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2025-09-21 17:41:23.554 Info TaskManager: Download OCR Data Completed after 0 minute(s) and 0 seconds 2025-09-21 17:41:23.563 Info TaskManager: Queueing task TvMazeUpdateTask 2025-09-21 17:41:23.563 Info TaskManager: Executing TV Maze Update 2025-09-21 17:41:23.571 Info TV Maze: MazeSeriesCache.CachePath: Setting Cache Path to: /var/packages/EmbyServer/var/cache/tvmaze 2025-09-21 17:41:23.620 Info HttpClient: GET http://api.tvmaze.com/updates/shows 2025-09-21 17:41:23.881 Info HttpClient: Http response 200 from http://api.tvmaze.com/updates/shows after 261ms 2025-09-21 17:41:23.922 Info HttpClient: Http response 200 from https://www.mb3admin.com/admin/service/EmbyPackages.json after 406ms 2025-09-21 17:41:24.418 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2025-09-21 17:41:24.724 Info TV Maze: MazeSeasonCache.CachePath: Setting Cache Path to: /var/packages/EmbyServer/var/cache/tvmazeseason 2025-09-21 17:41:24.752 Info TV Maze: MazePersonCache.CachePath: Setting Cache Path to: /var/packages/EmbyServer/var/cache/tvmazeperson 2025-09-21 17:41:24.754 Info HttpClient: GET http://api.tvmaze.com/updates/people 2025-09-21 17:41:24.869 Info HttpClient: Http response 200 from https://api.github.com/repos/MediaBrowser/Emby.Releases/releases after 1350ms 2025-09-21 17:41:24.872 Info HttpClient: Http response 200 from http://api.tvmaze.com/updates/people after 118ms 2025-09-21 17:41:25.475 Info App: No application update available. 2025-09-21 17:41:25.475 Info TaskManager: Check for application updates Completed after 0 minute(s) and 1 seconds 2025-09-21 17:41:26.655 Error PortMapper: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2025-09-21 17:41:26.657 Error PortMapper: Error in GetSpecificMappingAsync *** Error Report *** Version: 4.9.1.34 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Mon Jul 21 23:14:27 CST 2025 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) Source: Emby.PortMapper TargetSite: Void MoveNext() 2025-09-21 17:41:28.511 Info TaskManager: TV Maze Update Completed after 0 minute(s) and 4 seconds 2025-09-21 17:43:23.622 Info SessionsService-0HNFPBVTIP8BA:00000003: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:23.638 Info SessionsService-0HNFPBVTIP8BA:00000003: http/1.1 Response 204 to host1. Time: 16ms. POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:23.667 Info ActivityRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/activitylog.db. isReadOnly: True 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA cache_size=-65536 2025-09-21 17:43:23.668 Info ActivityRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/activitylog.db. isReadOnly: True 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA cache_size=-65536 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA page_size=4096 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA foreign_keys=1 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:43:23.668 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:43:23.668 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA page_size=4096 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA foreign_keys=1 2025-09-21 17:43:23.668 Info ActivityRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:43:23.668 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:43:23.668 Info ActivityRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:43:33.754 Info UniversalAudioService-0HNFPBVTIP8BD:00000007: http/1.1 HEAD http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603533&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:43:33.886 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:43:33.904 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.909 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.910 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.943 Info UniversalAudioService-0HNFPBVTIP8BD:00000007: http/1.1 Response 200 to host1. Time: 189ms. HEAD http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603533&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:43:33 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, ETag="d76c4eb881d14e56bc3cc770af7e3a3b", Content-Length=4128251, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:43:33.950 Info UniversalAudioService-0HNFPBVTIP8BD:00000008: http/1.1 GET http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603533&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=identity;q=1, *;q=0, Accept-Language=en-US,en;q=0.9, Range=bytes=0-, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:43:33.960 Info App: GetPostedPlaybackInfo request. IsPlayback: true, isInLocalNetwork: True 2025-09-21 17:43:33.962 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:43:33.962 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.963 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.963 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:33.964 Info SessionManager: Adding playSession 1758494603533 to session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:43:33.980 Info UniversalAudioService-0HNFPBVTIP8BD:00000008: http/1.1 Response 206 to host1. Time: 30ms. GET http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603533&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:43:33 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, Content-Range=bytes 0-4128250/4128251, ETag="d76c4eb881d14e56bc3cc770af7e3a3b", Content-Length=4128251, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:43:33.998 Info PlaystateService-0HNFPBVTIP8BF:0000000A: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:34.047 Info SessionManager: Playback start reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 0 ms. PlaySessionId: 1758494603533 2025-09-21 17:43:34.053 Info PlaystateService-0HNFPBVTIP8BF:0000000A: http/1.1 Response 204 to host1. Time: 55ms. POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:34.056 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStart : Entered 2025-09-21 17:43:34.057 Info PlaybackReporting - EventMonitorEntryPoint: Adding PlaybackInfo to playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:43:34.058 Info PlaybackReporting - EventMonitorEntryPoint: Saving PlaybackInfo to DB 2025-09-21 17:43:34.241 Info PlaystateService-0HNFPBVTIP8BF:0000000B: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:34.254 Info PlaystateService-0HNFPBVTIP8BF:0000000B: http/1.1 Response 204 to host1. Time: 13ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:41.082 Info SqliteItemRepository: Opening sqlite connection to /var/packages/EmbyServer/var/data/library.db. isReadOnly: True 2025-09-21 17:43:41.083 Info SqliteItemRepository: PRAGMA cache_size=-131072 2025-09-21 17:43:41.083 Info SqliteItemRepository: PRAGMA page_size=4096 2025-09-21 17:43:41.083 Info SqliteItemRepository: PRAGMA foreign_keys=1 2025-09-21 17:43:41.083 Info SqliteItemRepository: PRAGMA SECURE_DELETE=0 2025-09-21 17:43:41.083 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DDL to 0 is 0 2025-09-21 17:43:41.083 Info SqliteItemRepository: Result of setting SQLITE_DBCONFIG_DQS_DML to 0 is 0 2025-09-21 17:43:41.411 Info PlaystateService-0HNFPBVTIP8BD:0000000A: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:41.417 Info SessionManager: Playback stopped reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 6752 ms. PlaySessionId: 1758494603533 2025-09-21 17:43:41.419 Info SessionManager: Removed playSession 1758494603533 from session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:43:41.420 Info PlaystateService-0HNFPBVTIP8BD:0000000A: http/1.1 Response 204 to host1. Time: 9ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:41.425 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStop : Entered 2025-09-21 17:43:41.425 Info PlaybackReporting - EventMonitorEntryPoint: Saving final duration for Item : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:43:41.697 Info PlaybackReporting - EventMonitorEntryPoint: Removing Old Key from playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:43:43.353 Info UniversalAudioService-0HNFPBVTIP8BD:00000010: http/1.1 HEAD http://192.168.1.80:8096/emby/Audio/26712/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603534&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:43:43.356 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:43:43.356 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.356 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.356 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.357 Info UniversalAudioService-0HNFPBVTIP8BD:00000010: http/1.1 Response 200 to host1. Time: 4ms. HEAD http://192.168.1.80:8096/emby/Audio/26712/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603534&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:43:42 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, ETag="0de140cd5a6a8a4b5cc05838170126d1", Content-Length=1341468, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:43:43.376 Info UniversalAudioService-0HNFPBVTIP8BF:00000011: http/1.1 GET http://192.168.1.80:8096/emby/Audio/26712/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603534&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=identity;q=1, *;q=0, Accept-Language=en-US,en;q=0.9, Range=bytes=0-, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:43:43.376 Info App: GetPostedPlaybackInfo request. IsPlayback: true, isInLocalNetwork: True 2025-09-21 17:43:43.377 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:43:43.377 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.377 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.377 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:43.377 Info SessionManager: Adding playSession 1758494603534 to session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:43:43.379 Info UniversalAudioService-0HNFPBVTIP8BF:00000011: http/1.1 Response 206 to host1. Time: 4ms. GET http://192.168.1.80:8096/emby/Audio/26712/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494603534&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:43:42 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, Content-Range=bytes 0-1341467/1341468, ETag="0de140cd5a6a8a4b5cc05838170126d1", Content-Length=1341468, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:43:43.399 Info PlaystateService-0HNFPBVTIP8BF:00000012: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:43.400 Info SessionManager: Playback start reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 0 ms. PlaySessionId: 1758494603534 2025-09-21 17:43:43.401 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStart : Entered 2025-09-21 17:43:43.401 Info PlaybackReporting - EventMonitorEntryPoint: Adding PlaybackInfo to playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|26712|DirectPlay 2025-09-21 17:43:43.401 Info PlaybackReporting - EventMonitorEntryPoint: Saving PlaybackInfo to DB 2025-09-21 17:43:43.401 Info PlaystateService-0HNFPBVTIP8BF:00000012: http/1.1 Response 204 to host1. Time: 2ms. POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:43.641 Info PlaystateService-0HNFPBVTIP8BF:00000013: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:43.643 Info PlaystateService-0HNFPBVTIP8BF:00000013: http/1.1 Response 204 to host1. Time: 2ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:45.510 Info PlaystateService-0HNFPBVTIP8BF:00000015: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:45.511 Info SessionManager: Playback stopped reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 1535 ms. PlaySessionId: 1758494603534 2025-09-21 17:43:45.511 Info SessionManager: Removed playSession 1758494603534 from session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:43:45.511 Info PlaystateService-0HNFPBVTIP8BF:00000015: http/1.1 Response 204 to host1. Time: 1ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:43:45.511 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStop : Entered 2025-09-21 17:43:45.511 Info PlaybackReporting - EventMonitorEntryPoint: Saving final duration for Item : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|26712|DirectPlay 2025-09-21 17:43:45.827 Info PlaybackReporting - EventMonitorEntryPoint: Removing Old Key from playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|26712|DirectPlay 2025-09-21 17:43:47.056 Info MediaInfoService-0HNFPBVTIP8BF:00000017: http/1.1 POST http://192.168.1.80:8096/emby/Items/30748/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:43:47.092 Info App: User policy for Jay. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2025-09-21 17:43:47.117 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:47.120 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:47.120 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:43:47.124 Info MediaInfoService-0HNFPBVTIP8BF:00000017: http/1.1 Response 200 to host1. Time: 69ms. POST http://192.168.1.80:8096/emby/Items/30748/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:44:46.088 Info SessionsService-0HNFPBVTIP8B4:00000018: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:44:46.090 Info SessionsService-0HNFPBVTIP8B4:00000018: http/1.1 Response 204 to host1. Time: 1ms. POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:44:48.816 Info MediaInfoService-0HNFPBVTIP8B4:0000001C: http/1.1 POST http://192.168.1.80:8096/emby/Items/30745/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:44:48.822 Info App: User policy for Jay. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2025-09-21 17:44:48.830 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:44:48.831 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:44:48.832 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:44:48.833 Info MediaInfoService-0HNFPBVTIP8B4:0000001C: http/1.1 Response 200 to host1. Time: 17ms. POST http://192.168.1.80:8096/emby/Items/30745/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:46:28.654 Info SessionsService-0HNFPBVTIP8BH:00000006: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:46:28.655 Info SessionsService-0HNFPBVTIP8BH:00000006: http/1.1 Response 204 to host1. Time: 1ms. POST http://192.168.1.80:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:46:59.420 Info ConfigurationService-0HNFPBVTIP8BK:0000000F: http/1.1 POST http://192.168.1.80:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:46:59.462 Info ServerConfigurationManager: Saving system configuration 2025-09-21 17:46:59.464 Info ConfigurationService-0HNFPBVTIP8BK:0000000F: http/1.1 Response 204 to host1. Time: 45ms. POST http://192.168.1.80:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:46:59.465 Info App: Setting default culture to en-US 2025-09-21 17:47:02.379 Debug UserLibraryService-0HNFPBVTIP8BK:00000010: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:02.379 Debug ItemsService-0HNFPBVTIP8BH:0000000A: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:02.380 Debug UserLibraryService-0HNFPBVTIP8BM:00000002: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:02.390 Debug UserLibraryService-0HNFPBVTIP8BM:00000002: http/1.1 Response 200 to host1. Time: 11ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:02.391 Debug TvShowsService-0HNFPBVTIP8BN:00000002: http/1.1 GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:02.392 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:47:02.397 Debug TvShowsService-0HNFPBVTIP8BN:00000002: http/1.1 Response 200 to host1. Time: 6ms. GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:02.401 Debug UserLibraryService-0HNFPBVTIP8BK:00000010: http/1.1 Response 200 to host1. Time: 22ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:02.402 Debug ItemsService-0HNFPBVTIP8BH:0000000A: http/1.1 Response 200 to host1. Time: 23ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:03.942 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to 192.168.1.229 2025-09-21 17:47:03.942 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to 192.168.1.229 2025-09-21 17:47:03.944 Debug UserLibraryService-0HNFPBVTIP8BH:0000000B: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/24400?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:03.956 Debug SqliteItemRepository: GetSubviews total time: 7.632ms 2025-09-21 17:47:03.956 Debug UserLibraryService-0HNFPBVTIP8BH:0000000B: http/1.1 Response 200 to host1. Time: 13ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/24400?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:03.966 Debug ItemsService-0HNFPBVTIP8BH:0000000C: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?IncludeItemTypes=Series&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&StartIndex=0&SortBy=SortName&SortOrder=Ascending&ParentId=24400&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Recursive=true&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:03.975 Debug ItemsService-0HNFPBVTIP8BH:0000000C: http/1.1 Response 200 to host1. Time: 10ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?IncludeItemTypes=Series&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&StartIndex=0&SortBy=SortName&SortOrder=Ascending&ParentId=24400&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Recursive=true&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:06.987 Debug UserLibraryService-0HNFPBVTIP8BH:0000000D: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/24407?fields=ShareLevel&ExcludeFields=VideoChapters,VideoMediaSources,MediaStreams&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:06.989 Debug UserLibraryService-0HNFPBVTIP8BH:0000000D: http/1.1 Response 200 to host1. Time: 3ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/24407?fields=ShareLevel&ExcludeFields=VideoChapters,VideoMediaSources,MediaStreams&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:06.996 Debug TvShowsService-0HNFPBVTIP8BH:0000000E: http/1.1 GET http://192.168.1.80:8096/emby/Shows/24407/Seasons?UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,Overview&IsSpecialSeason=false&EnableUserData=false&EnableTotalRecordCount=false&EnableImages=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:06.997 Debug TvShowsService-0HNFPBVTIP8BH:0000000E: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Shows/24407/Seasons?UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,Overview&IsSpecialSeason=false&EnableUserData=false&EnableTotalRecordCount=false&EnableImages=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.004 Debug ItemsService-0HNFPBVTIP8BH:0000000F: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=6ee31637e48f41cc80a2afcf6066bf69&Limit=1&EnableTotalRecordCount=false&EnableImages=false&IncludeItemTypes=Episode&ParentId=24407&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.005 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:47:07.006 Debug ItemsService-0HNFPBVTIP8BH:0000000F: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=6ee31637e48f41cc80a2afcf6066bf69&Limit=1&EnableTotalRecordCount=false&EnableImages=false&IncludeItemTypes=Episode&ParentId=24407&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.020 Debug TvShowsService-0HNFPBVTIP8BH:00000010: http/1.1 GET http://192.168.1.80:8096/emby/Shows/24407/Seasons?UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,Overview&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.020 Debug LiveTvService-0HNFPBVTIP8BK:00000011: http/1.1 GET http://192.168.1.80:8096/emby/LiveTv/Programs?UserId=6ee31637e48f41cc80a2afcf6066bf69&HasAired=false&SortBy=StartDate&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&EnableUserData=false&Fields=PrimaryImageAspectRatio,ChannelInfo&Limit=16&LibrarySeriesId=24407&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.021 Debug LiveTvService-0HNFPBVTIP8BK:00000011: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/LiveTv/Programs?UserId=6ee31637e48f41cc80a2afcf6066bf69&HasAired=false&SortBy=StartDate&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&EnableUserData=false&Fields=PrimaryImageAspectRatio,ChannelInfo&Limit=16&LibrarySeriesId=24407&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.022 Debug TvShowsService-0HNFPBVTIP8BH:00000010: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/Shows/24407/Seasons?UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,Overview&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.022 Debug LibraryService-0HNFPBVTIP8BL:00000003: http/1.1 GET http://192.168.1.80:8096/emby/Items/24407/ThemeMedia?UserId=6ee31637e48f41cc80a2afcf6066bf69&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.022 Debug LibraryService-0HNFPBVTIP8BM:00000003: http/1.1 GET http://192.168.1.80:8096/emby/Items/24407/Similar?Limit=12&UserId=6ee31637e48f41cc80a2afcf6066bf69&ImageTypeLimit=1&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.023 Debug App: Sqlite: 284 - automatic index on LinkedCounts(AId) 2025-09-21 17:47:07.023 Debug LibraryService-0HNFPBVTIP8BL:00000003: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Items/24407/ThemeMedia?UserId=6ee31637e48f41cc80a2afcf6066bf69&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.026 Debug LibraryService-0HNFPBVTIP8BM:00000003: http/1.1 Response 200 to host1. Time: 4ms. GET http://192.168.1.80:8096/emby/Items/24407/Similar?Limit=12&UserId=6ee31637e48f41cc80a2afcf6066bf69&ImageTypeLimit=1&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.032 Debug ItemsService-0HNFPBVTIP8BN:00000003: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=24407&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.034 Debug ItemsService-0HNFPBVTIP8BN:00000003: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=24407&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.042 Debug SystemService-0HNFPBVTIP8BL:00000004: http/1.1 GET http://192.168.1.80:8096/emby/System/Endpoint?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.043 Debug SystemService-0HNFPBVTIP8BL:00000004: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/System/Endpoint?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:07.340 Info UniversalAudioService-0HNFPBVTIP8BL:00000005: http/1.1 HEAD http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494788368&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:47:07.362 Debug App: GetPostedPlaybackInfo request: {"Id":"24439","UserId":"6ee31637e48f41cc80a2afcf6066bf69","MaxStreamingBitrate":200000000,"StartTimeTicks":0,"DeviceProfile":{"SupportedMediaTypes":"Audio,Photo,Video","MaxStreamingBitrate":8000000,"MusicStreamingTranscodingBitrate":256000,"DeclaredFeatures":[],"DirectPlayProfiles":[{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma","Type":"Audio"},{"Container":"webm","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S24LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false}],"ContainerProfiles":[],"CodecProfiles":[],"ResponseProfiles":[],"SubtitleProfiles":[]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowInterlacedVideoStreamCopy":false,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false} 2025-09-21 17:47:07.362 Debug SqliteItemRepository: GetitemById Audio 24439 /volume1/SYNOLOGY/HD TV Series/IT/theme.mp3 2025-09-21 17:47:07.363 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:47:07.363 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.363 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.363 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.363 Debug SqliteItemRepository: GetitemById Audio 24439 /volume1/SYNOLOGY/HD TV Series/IT/theme.mp3 2025-09-21 17:47:07.364 Info UniversalAudioService-0HNFPBVTIP8BL:00000005: http/1.1 Response 200 to host1. Time: 24ms. HEAD http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494788368&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:47:06 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, ETag="d76c4eb881d14e56bc3cc770af7e3a3b", Content-Length=4128251, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:47:07.373 Info UniversalAudioService-0HNFPBVTIP8BL:00000006: http/1.1 GET http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494788368&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Source Ip: host1, Accept=*/*, Connection=keep-alive, Host=192.168.1.80:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0, Accept-Encoding=identity;q=1, *;q=0, Accept-Language=en-US,en;q=0.9, Range=bytes=0-, Referer=http://192.168.1.80:8096/web/index.html, DNT=1 2025-09-21 17:47:07.373 Debug App: GetPostedPlaybackInfo request: {"Id":"24439","UserId":"6ee31637e48f41cc80a2afcf6066bf69","MaxStreamingBitrate":200000000,"StartTimeTicks":0,"DeviceProfile":{"SupportedMediaTypes":"Audio,Photo,Video","MaxStreamingBitrate":8000000,"MusicStreamingTranscodingBitrate":256000,"DeclaredFeatures":[],"DirectPlayProfiles":[{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma","Type":"Audio"},{"Container":"webm","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S24LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false}],"ContainerProfiles":[],"CodecProfiles":[],"ResponseProfiles":[],"SubtitleProfiles":[]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowInterlacedVideoStreamCopy":false,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":true,"AutoOpenLiveStream":false} 2025-09-21 17:47:07.373 Info App: GetPostedPlaybackInfo request. IsPlayback: true, isInLocalNetwork: True 2025-09-21 17:47:07.373 Debug SqliteItemRepository: GetitemById Audio 24439 /volume1/SYNOLOGY/HD TV Series/IT/theme.mp3 2025-09-21 17:47:07.374 Info App: User policy for Jay. EnableAudioPlaybackTranscoding: True 2025-09-21 17:47:07.374 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.374 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.374 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:07.374 Info SessionManager: Adding playSession 1758494788368 to session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:47:07.374 Debug SqliteItemRepository: GetitemById Audio 24439 /volume1/SYNOLOGY/HD TV Series/IT/theme.mp3 2025-09-21 17:47:07.387 Info UniversalAudioService-0HNFPBVTIP8BL:00000006: http/1.1 Response 206 to host1. Time: 15ms. GET http://192.168.1.80:8096/emby/Audio/24439/universal?UserId=6ee31637e48f41cc80a2afcf6066bf69&DeviceId=0143d1e1-5a0c-4a8c-9add-388cf4470655&MaxStreamingBitrate=200000000&Container=opus,mp3|mp3,mp2,mp3|mp2,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav|PCM_S16LE,wav|PCM_S24LE,ogg&TranscodingContainer=aac&TranscodingProtocol=hls&AudioCodec=aac&api_key=x_secret2_x&PlaySessionId=1758494788368&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. Headers: Content-Type=audio/mpeg, Date=Sun, 21 Sep 2025 22:47:06 GMT, Server=UPnP/1.0 DLNADOC/1.50, Accept-Ranges=bytes, Cache-Control=private, no-transform, Content-Range=bytes 0-4128250/4128251, ETag="d76c4eb881d14e56bc3cc770af7e3a3b", Content-Length=4128251, Cross-Origin-Resource-Policy=cross-origin, Private-Network-Access-Name=DS220, Private-Network-Access-Id=4b77e26e9c0e4685a369b983965f4117 2025-09-21 17:47:07.520 Info PlaystateService-0HNFPBVTIP8BL:00000007: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.521 Debug SqliteItemRepository: GetitemById Audio 24439 /volume1/SYNOLOGY/HD TV Series/IT/theme.mp3 2025-09-21 17:47:07.521 Info SessionManager: Playback start reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 0 ms. PlaySessionId: 1758494788368 2025-09-21 17:47:07.522 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStart : Entered 2025-09-21 17:47:07.522 Info PlaybackReporting - EventMonitorEntryPoint: Adding PlaybackInfo to playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:47:07.522 Info PlaystateService-0HNFPBVTIP8BL:00000007: http/1.1 Response 204 to host1. Time: 2ms. POST http://192.168.1.80:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:47:07.522 Info PlaybackReporting - EventMonitorEntryPoint: Saving PlaybackInfo to DB 2025-09-21 17:47:07.646 Info PlaystateService-0HNFPBVTIP8BL:00000008: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:07.646 Debug SessionManager: Playback progress (TimeUpdate) reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 9 ms. PlaySessionId: 1758494788368 2025-09-21 17:47:07.647 Info PlaystateService-0HNFPBVTIP8BL:00000008: http/1.1 Response 204 to host1. Time: 1ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:47:15.062 Info PlaystateService-0HNFPBVTIP8BL:00000009: http/1.1 POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:15.062 Info SessionManager: Playback stopped reported by app Emby Web 4.9.1.34 on Edge Windows playing theme. Position: 6912 ms. PlaySessionId: 1758494788368 2025-09-21 17:47:15.063 Info SessionManager: Removed playSession 1758494788368 from session 2db60e91c288377a5377cf2e414ba1f8 2025-09-21 17:47:15.063 Info PlaystateService-0HNFPBVTIP8BL:00000009: http/1.1 Response 204 to host1. Time: 1ms. POST http://192.168.1.80:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:47:15.063 Debug EncodingManager: ReportPlaybackStopped PlaySessionId: 1758494788368 2025-09-21 17:47:15.063 Info PlaybackReporting - EventMonitorEntryPoint: _sessionManager_PlaybackStop : Entered 2025-09-21 17:47:15.063 Info PlaybackReporting - EventMonitorEntryPoint: Saving final duration for Item : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:47:15.565 Info PlaybackReporting - EventMonitorEntryPoint: Removing Old Key from playback_trackers : 0143d1e1-5a0c-4a8c-9add-388cf4470655|6ee31637e48f41cc80a2afcf6066bf69|24439|DirectPlay 2025-09-21 17:47:17.368 Debug UserLibraryService-0HNFPBVTIP8BL:0000000A: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:17.369 Debug TvShowsService-0HNFPBVTIP8BK:00000012: http/1.1 GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:17.370 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:47:17.372 Debug ItemsService-0HNFPBVTIP8BM:00000004: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:17.382 Debug UserLibraryService-0HNFPBVTIP8BN:00000004: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:17.383 Debug TvShowsService-0HNFPBVTIP8BK:00000012: http/1.1 Response 200 to host1. Time: 15ms. GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:17.384 Debug UserLibraryService-0HNFPBVTIP8BL:0000000A: http/1.1 Response 200 to host1. Time: 16ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:17.388 Debug ItemsService-0HNFPBVTIP8BM:00000004: http/1.1 Response 200 to host1. Time: 16ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:17.391 Debug UserLibraryService-0HNFPBVTIP8BN:00000004: http/1.1 Response 200 to host1. Time: 9ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:18.840 Debug UserLibraryService-0HNFPBVTIP8BN:00000005: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30636?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:18.842 Debug SqliteItemRepository: GetSubviews total time: 1.9455ms 2025-09-21 17:47:18.843 Debug UserLibraryService-0HNFPBVTIP8BN:00000005: http/1.1 Response 200 to host1. Time: 3ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30636?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:18.856 Debug ItemsService-0HNFPBVTIP8BN:00000006: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?IncludeItemTypes=Movie&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&StartIndex=0&SortBy=SortName&SortOrder=Ascending&ParentId=30636&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Recursive=true&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30642 /volume1/SYNOLOGY/1080p Movies/Apt Pupil 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30643 /volume1/SYNOLOGY/1080p Movies/Beverly Hills Cop 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30647 /volume1/SYNOLOGY/1080p Movies/Contagion 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30648 /volume1/SYNOLOGY/1080p Movies/Dolores Claiborne 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30652 /volume1/SYNOLOGY/1080p Movies/Invasion of the Body Snatchers 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30653 /volume1/SYNOLOGY/1080p Movies/Jaws 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30681 /volume1/SYNOLOGY/1080p Movies/Jeff Wayne's Musical Version of The War of The Worlds 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30657 /volume1/SYNOLOGY/1080p Movies/Moby Dick 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30658 /volume1/SYNOLOGY/1080p Movies/No Country For Old Men 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30664 /volume1/SYNOLOGY/1080p Movies/The Omen 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30679 /volume1/SYNOLOGY/1080p Movies/Rear Window 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30680 /volume1/SYNOLOGY/1080p Movies/Romeo + Juliet 2025-09-21 17:47:18.860 Debug SqliteItemRepository: GetitemById Folder 30685 /volume1/SYNOLOGY/1080p Movies/The Silence of The Lambs 2025-09-21 17:47:18.882 Debug ItemsService-0HNFPBVTIP8BN:00000006: http/1.1 Response 200 to host1. Time: 26ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?IncludeItemTypes=Movie&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&StartIndex=0&SortBy=SortName&SortOrder=Ascending&ParentId=30636&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Recursive=true&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:18.890 Debug TagService-0HNFPBVTIP8BN:00000007: http/1.1 GET http://192.168.1.80:8096/emby/Items/Prefixes?IncludeItemTypes=Movie&SortOrder=Ascending&ParentId=30636&Recursive=true&userId=6ee31637e48f41cc80a2afcf6066bf69&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:18.900 Debug TagService-0HNFPBVTIP8BN:00000007: http/1.1 Response 200 to host1. Time: 11ms. GET http://192.168.1.80:8096/emby/Items/Prefixes?IncludeItemTypes=Movie&SortOrder=Ascending&ParentId=30636&Recursive=true&userId=6ee31637e48f41cc80a2afcf6066bf69&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:20.990 Debug UserLibraryService-0HNFPBVTIP8BN:00000008: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30747?fields=ShareLevel&ExcludeFields=VideoChapters,VideoMediaSources,MediaStreams&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:20.991 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:20.993 Debug UserLibraryService-0HNFPBVTIP8BN:00000008: http/1.1 Response 200 to host1. Time: 3ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30747?fields=ShareLevel&ExcludeFields=VideoChapters,VideoMediaSources,MediaStreams&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:21.013 Info MediaInfoService-0HNFPBVTIP8BN:00000009: http/1.1 POST http://192.168.1.80:8096/emby/Items/30747/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.021 Debug App: GetPostedPlaybackInfo request: {"Id":"30747","UserId":"6ee31637e48f41cc80a2afcf6066bf69","MaxStreamingBitrate":200000000,"StartTimeTicks":0,"DeviceProfile":{"SupportedMediaTypes":"Audio,Photo,Video","MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"DeclaredFeatures":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","VideoCodec":"h264,hevc,av1,vp8,vp9","Type":"Video"},{"Container":"mkv","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","VideoCodec":"h264,hevc,av1,vp8,vp9","Type":"Video"},{"Container":"flv","AudioCodec":"aac,mp3","VideoCodec":"h264","Type":"Video"},{"Container":"3gp","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mov","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE,PCM_S24LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"av1,VP8,VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"mkv","Type":"Video","VideoCodec":"h264,hevc,av1,vp8,vp9","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":true,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"ts","Type":"Video","VideoCodec":"hevc,h264,av1","AudioCodec":"ac3,mp3,aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true,"AllowInterlacedVideoStreamCopy":false,"ManifestSubtitles":"vtt","MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"ac3,eac3,mp3,aac,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0,"MaxWidth":0,"MaxHeight":0,"FillEmptySubtitleSegments":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[],"Codec":"aac"},{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[],"Codec":"flac"},{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[],"Codec":"vorbis"},{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[]},{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline|high 10","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"62","IsRequired":false},{"Condition":"LessThanEqual","Property":"Width","Value":"3840","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"},{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoCodecTag","Value":"hvc1|hev1|hevc|hdmv","IsRequired":false},{"Condition":"LessThanEqual","Property":"Width","Value":"3840","IsRequired":false}],"ApplyConditions":[],"Codec":"hevc"},{"Type":"Video","Conditions":[{"Condition":"LessThanEqual","Property":"Width","Value":"3840","IsRequired":false}],"ApplyConditions":[]}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"eia_608","Method":"VideoSideData","Protocol":"hls"},{"Format":"eia_708","Method":"VideoSideData","Protocol":"hls"},{"Format":"vtt","Method":"External"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowInterlacedVideoStreamCopy":false,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false} 2025-09-21 17:47:21.021 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.027 Info App: User policy for Jay. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2025-09-21 17:47:21.030 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:21.031 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:21.031 Info App: RemoteClientBitrateLimit: 6000000, RemoteIp: host1, IsInLocalNetwork: True 2025-09-21 17:47:21.031 Info MediaInfoService-0HNFPBVTIP8BN:00000009: http/1.1 Response 200 to host1. Time: 19ms. POST http://192.168.1.80:8096/emby/Items/30747/PlaybackInfo?UserId=6ee31637e48f41cc80a2afcf6066bf69&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=200000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. 2025-09-21 17:47:21.044 Debug WebAppService-0HNFPBVTIP8BN:0000000A: http/1.1 GET http://192.168.1.80:8096/web/modules/mediainfo/rotten.png. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.045 Debug WebAppService-0HNFPBVTIP8BN:0000000A: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/web/modules/mediainfo/rotten.png. 2025-09-21 17:47:21.047 Debug ItemsService-0HNFPBVTIP8BL:0000000B: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=30747&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.047 Debug LibraryService-0HNFPBVTIP8BK:00000013: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Similar?Limit=12&UserId=6ee31637e48f41cc80a2afcf6066bf69&ImageTypeLimit=1&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.048 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.049 Debug App: Sqlite: 284 - automatic index on LinkedCounts(AId) 2025-09-21 17:47:21.050 Debug ItemsService-0HNFPBVTIP8BL:0000000B: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items?fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=30747&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:21.052 Debug UserLibraryService-0HNFPBVTIP8BM:00000005: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30747/SpecialFeatures?Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.053 Debug UserLibraryService-0HNFPBVTIP8BM:00000005: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/30747/SpecialFeatures?Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:21.053 Debug LibraryService-0HNFPBVTIP8BL:0000000C: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/ThemeMedia?UserId=6ee31637e48f41cc80a2afcf6066bf69&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.054 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.054 Debug LibraryService-0HNFPBVTIP8BL:0000000C: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Items/30747/ThemeMedia?UserId=6ee31637e48f41cc80a2afcf6066bf69&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:21.056 Debug LibraryService-0HNFPBVTIP8BK:00000013: http/1.1 Response 200 to host1. Time: 9ms. GET http://192.168.1.80:8096/emby/Items/30747/Similar?Limit=12&UserId=6ee31637e48f41cc80a2afcf6066bf69&ImageTypeLimit=1&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:21.064 Debug ImageService-0HNFPBVTIP8BK:00000014: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Backdrop/0?tag=a9484c2d4d8dcf589d066d0afe002121&maxWidth=2560&quality=70. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.065 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.065 Debug App: Found cached image /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/fanart2.jpg 2025-09-21 17:47:21.066 Debug ImageService-0HNFPBVTIP8BH:00000011: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/1?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.067 Debug ImageService-0HNFPBVTIP8BL:0000000D: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Primary?maxHeight=541&maxWidth=361&tag=222f76ea2c5dd874f3f96ba58135cc00&keepAnimation=true&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.067 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.067 Debug App: Found cached image /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/poster.jpg 2025-09-21 17:47:21.068 Debug ImageService-0HNFPBVTIP8BN:0000000B: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/0?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.068 Debug ImageService-0HNFPBVTIP8BI:00000006: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/2?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.073 Debug ImageService-0HNFPBVTIP8BM:00000006: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Logo?maxHeight=286&tag=35f16c928c3be1ab99a2635b441ff13a&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.073 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:21.073 Debug App: Found cached image /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/logo.png 2025-09-21 17:47:21.134 Debug ImageService-0HNFPBVTIP8BN:0000000B: http/1.1 Response 200 to host1. Time: 67ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/0?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.138 Debug ImageService-0HNFPBVTIP8BI:00000006: http/1.1 Response 200 to host1. Time: 70ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/2?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.141 Debug ImageService-0HNFPBVTIP8BN:0000000C: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/4?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.142 Debug ImageService-0HNFPBVTIP8BH:00000011: http/1.1 Response 200 to host1. Time: 76ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/1?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.143 Debug ImageService-0HNFPBVTIP8BH:00000012: http/1.1 GET http://192.168.1.80:8096/emby/Items/31991/Images/Primary?maxHeight=289&maxWidth=193&tag=ec26d76575a740f47adfff3d8bba92b4&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.144 Debug SqliteItemRepository: GetitemById Person 31991 Don Harvey 2025-09-21 17:47:21.146 Debug ImageService-0HNFPBVTIP8BI:00000007: http/1.1 GET http://192.168.1.80:8096/emby/Items/31988/Images/Primary?maxHeight=289&maxWidth=193&tag=370c7b353add2e76f4e01c76fa77c40e&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.146 Debug App: ConvertImageToLocal item 31991 - image url: https://image.tmdb.org/t/p/original/dc10W0hRNxrO0IcwgKOcsUajtOG.jpg 2025-09-21 17:47:21.146 Debug SqliteItemRepository: GetitemById Person 31988 Tom Wright 2025-09-21 17:47:21.147 Debug App: ConvertImageToLocal item 31988 - image url: https://image.tmdb.org/t/p/original/lJ4L5fdXBeNr528gBB4eMTdvfd4.jpg 2025-09-21 17:47:21.149 Info HttpClient: GET https://image.tmdb.org/t/p/original/lJ4L5fdXBeNr528gBB4eMTdvfd4.jpg 2025-09-21 17:47:21.151 Info HttpClient: GET https://image.tmdb.org/t/p/original/dc10W0hRNxrO0IcwgKOcsUajtOG.jpg 2025-09-21 17:47:21.215 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/525eb9ad1be0455eb7248ac9ea2f3c69.webp took 148ms for /var/packages/EmbyServer/var/cache/images/enhanced-images/1/194426583ef07efe35f54036478a0cf2.png. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/e/e3ba80f8-c768-73ca-4e9b-24c1761dc5ac.webp 2025-09-21 17:47:21.222 Debug ImageService-0HNFPBVTIP8BL:0000000D: http/1.1 Response 200 to host1. Time: 155ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Primary?maxHeight=541&maxWidth=361&tag=222f76ea2c5dd874f3f96ba58135cc00&keepAnimation=true&quality=90. 2025-09-21 17:47:21.239 Debug ImageService-0HNFPBVTIP8BL:0000000E: http/1.1 GET http://192.168.1.80:8096/emby/Items/31985/Images/Primary?maxHeight=289&maxWidth=193&tag=0629e0d42510cdbd2b2b897c6cbafe88&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.239 Debug SqliteItemRepository: GetitemById Person 31985 Dorothy Lamour 2025-09-21 17:47:21.239 Debug App: ConvertImageToLocal item 31985 - image url: https://image.tmdb.org/t/p/original/nPUEpYPfQ7upyGmYLhDnotKPlcJ.jpg 2025-09-21 17:47:21.240 Info HttpClient: GET https://image.tmdb.org/t/p/original/nPUEpYPfQ7upyGmYLhDnotKPlcJ.jpg 2025-09-21 17:47:21.267 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/54872d93a5ef4172b41fe96bbc410ccb.webp took 194ms for /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/logo.png. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/3/3ca3210d-d8f8-c798-4eca-9bab015adc50.webp 2025-09-21 17:47:21.275 Debug ImageService-0HNFPBVTIP8BM:00000006: http/1.1 Response 200 to host1. Time: 202ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Logo?maxHeight=286&tag=35f16c928c3be1ab99a2635b441ff13a&quality=90. 2025-09-21 17:47:21.280 Debug ImageService-0HNFPBVTIP8BM:00000007: http/1.1 GET http://192.168.1.80:8096/emby/Items/31986/Images/Primary?maxHeight=289&maxWidth=193&tag=82a4b702bd9629b7f9c7e9b77047faf5&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.280 Debug SqliteItemRepository: GetitemById Person 31986 Lois Chiles 2025-09-21 17:47:21.281 Debug App: ConvertImageToLocal item 31986 - image url: https://image.tmdb.org/t/p/original/4iNFyon7E8LvwyyrMVDQ8nItVZk.jpg 2025-09-21 17:47:21.281 Info HttpClient: GET https://image.tmdb.org/t/p/original/4iNFyon7E8LvwyyrMVDQ8nItVZk.jpg 2025-09-21 17:47:21.337 Debug ImageService-0HNFPBVTIP8BN:0000000C: http/1.1 Response 200 to host1. Time: 197ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/4?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.352 Debug ImageService-0HNFPBVTIP8BN:0000000D: http/1.1 GET http://192.168.1.80:8096/emby/Items/31989/Images/Primary?maxHeight=289&maxWidth=193&tag=8439a0500475a8709c57d747527eb168&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.352 Debug SqliteItemRepository: GetitemById Person 31989 Frank Salsedo 2025-09-21 17:47:21.352 Debug App: ConvertImageToLocal item 31989 - image url: https://image.tmdb.org/t/p/original/2HoTBejS2oZVQrVcuKyXIoNDvmp.jpg 2025-09-21 17:47:21.353 Info HttpClient: GET https://image.tmdb.org/t/p/original/2HoTBejS2oZVQrVcuKyXIoNDvmp.jpg 2025-09-21 17:47:21.433 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/lJ4L5fdXBeNr528gBB4eMTdvfd4.jpg after 283ms 2025-09-21 17:47:21.444 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/2HoTBejS2oZVQrVcuKyXIoNDvmp.jpg after 91ms 2025-09-21 17:47:21.469 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/f/Frank Salsedo-tmdb-92903/folder.jpg 2025-09-21 17:47:21.483 Debug ImageProcessor: OnImageSizeObtained Frank Salsedo 2025-09-21 17:47:21.500 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/dc10W0hRNxrO0IcwgKOcsUajtOG.jpg after 350ms 2025-09-21 17:47:21.533 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/t/Tom Wright-tmdb-55270/folder.jpg 2025-09-21 17:47:21.534 Debug ImageProcessor: OnImageSizeObtained Tom Wright 2025-09-21 17:47:21.544 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/0d6e8db8bfe2451ba4afe53040173183.webp took 64ms for /var/packages/EmbyServer/var/metadata/people/f/Frank Salsedo-tmdb-92903/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/d/d46f9e2d-8b9b-04bd-991c-7fcf95e49285.webp 2025-09-21 17:47:21.547 Debug ImageService-0HNFPBVTIP8BN:0000000D: http/1.1 Response 200 to host1. Time: 195ms. GET http://192.168.1.80:8096/emby/Items/31989/Images/Primary?maxHeight=289&maxWidth=193&tag=8439a0500475a8709c57d747527eb168&quality=90. 2025-09-21 17:47:21.555 Debug ImageService-0HNFPBVTIP8BN:0000000E: http/1.1 GET http://192.168.1.80:8096/emby/Items/31993/Images/Primary?maxHeight=289&maxWidth=193&tag=b50a0fbcb982dc27d3f88b8235eece2a&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.562 Debug SqliteItemRepository: GetitemById Person 31993 Paul Satterfield 2025-09-21 17:47:21.562 Debug App: ConvertImageToLocal item 31993 - image url: https://image.tmdb.org/t/p/original/n8Id0zf5N9xeqPngA4YtGoPIcMj.jpg 2025-09-21 17:47:21.562 Info HttpClient: GET https://image.tmdb.org/t/p/original/n8Id0zf5N9xeqPngA4YtGoPIcMj.jpg 2025-09-21 17:47:21.566 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/nPUEpYPfQ7upyGmYLhDnotKPlcJ.jpg after 326ms 2025-09-21 17:47:21.567 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/d/Dorothy Lamour-tmdb-83400/folder.jpg 2025-09-21 17:47:21.568 Debug ImageProcessor: OnImageSizeObtained Dorothy Lamour 2025-09-21 17:47:21.581 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/d/Don Harvey-tmdb-1280/folder.jpg 2025-09-21 17:47:21.582 Debug ImageProcessor: OnImageSizeObtained Don Harvey 2025-09-21 17:47:21.597 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/4iNFyon7E8LvwyyrMVDQ8nItVZk.jpg after 316ms 2025-09-21 17:47:21.610 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/n8Id0zf5N9xeqPngA4YtGoPIcMj.jpg after 48ms 2025-09-21 17:47:21.610 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/p/Paul Satterfield-tmdb-4498/folder.jpg 2025-09-21 17:47:21.611 Debug ImageProcessor: OnImageSizeObtained Paul Satterfield 2025-09-21 17:47:21.625 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/485d1d86fe5c42939a5764a651b1b1c7.webp took 56ms for /var/packages/EmbyServer/var/metadata/people/d/Dorothy Lamour-tmdb-83400/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/0/0e693ec0-0ac8-da4b-98dc-ebdb495c7ccc.webp 2025-09-21 17:47:21.637 Debug ImageService-0HNFPBVTIP8BL:0000000E: http/1.1 Response 200 to host1. Time: 398ms. GET http://192.168.1.80:8096/emby/Items/31985/Images/Primary?maxHeight=289&maxWidth=193&tag=0629e0d42510cdbd2b2b897c6cbafe88&quality=90. 2025-09-21 17:47:21.651 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/l/Lois Chiles-tmdb-10475/folder.jpg 2025-09-21 17:47:21.652 Debug ImageProcessor: OnImageSizeObtained Lois Chiles 2025-09-21 17:47:21.654 Debug ImageService-0HNFPBVTIP8BL:0000000F: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/3?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.691 Debug ImageService-0HNFPBVTIP8BL:0000000F: http/1.1 Response 200 to host1. Time: 37ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/3?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.693 Debug ImageService-0HNFPBVTIP8BL:00000010: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/5?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.694 Debug ImageService-0HNFPBVTIP8BL:00000010: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/5?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.695 Debug ImageService-0HNFPBVTIP8BL:00000011: http/1.1 GET http://192.168.1.80:8096/emby/Items/31994/Images/Primary?maxHeight=289&maxWidth=193&tag=68de8d5a7c6b3dde213739d70bb58f83&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.696 Debug SqliteItemRepository: GetitemById Person 31994 Jeremy Green 2025-09-21 17:47:21.696 Debug App: ConvertImageToLocal item 31994 - image url: https://image.tmdb.org/t/p/original/qtBtr9YkRv8X6B8lz0HLkhTruwG.jpg 2025-09-21 17:47:21.696 Info HttpClient: GET https://image.tmdb.org/t/p/original/qtBtr9YkRv8X6B8lz0HLkhTruwG.jpg 2025-09-21 17:47:21.697 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/1d6d17cdb18e4b8793f56ebc3204275c.webp took 86ms for /var/packages/EmbyServer/var/metadata/people/p/Paul Satterfield-tmdb-4498/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/e/e0b6d0ca-fb84-bf43-a822-ef50c8e0bb91.webp 2025-09-21 17:47:21.698 Debug ImageService-0HNFPBVTIP8BN:0000000E: http/1.1 Response 200 to host1. Time: 143ms. GET http://192.168.1.80:8096/emby/Items/31993/Images/Primary?maxHeight=289&maxWidth=193&tag=b50a0fbcb982dc27d3f88b8235eece2a&quality=90. 2025-09-21 17:47:21.704 Debug ImageService-0HNFPBVTIP8BN:0000000F: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/6?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.717 Debug ImageService-0HNFPBVTIP8BN:0000000F: http/1.1 Response 200 to host1. Time: 12ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/6?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.724 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/qtBtr9YkRv8X6B8lz0HLkhTruwG.jpg after 28ms 2025-09-21 17:47:21.725 Debug ImageService-0HNFPBVTIP8BN:00000010: http/1.1 GET http://192.168.1.80:8096/emby/Items/1091/Images/Primary?maxHeight=289&maxWidth=193&tag=a24529747c0a19d906da9694af5ae464&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.725 Debug SqliteItemRepository: GetitemById Person 1091 Holt McCallany 2025-09-21 17:47:21.725 Debug App: ConvertImageToLocal item 1091 - image url: https://image.tmdb.org/t/p/original/nttzDvj4rpcCvtxbsEwLRN6nQFq.jpg 2025-09-21 17:47:21.725 Info HttpClient: GET https://image.tmdb.org/t/p/original/nttzDvj4rpcCvtxbsEwLRN6nQFq.jpg 2025-09-21 17:47:21.726 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/j/Jeremy Green-tmdb-107369/folder.jpg 2025-09-21 17:47:21.727 Debug ImageProcessor: OnImageSizeObtained Jeremy Green 2025-09-21 17:47:21.767 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/91059b18a81b40e0a11f8e0a4a4563ab.webp took 233ms for /var/packages/EmbyServer/var/metadata/people/t/Tom Wright-tmdb-55270/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/3/30ba9a6a-c2b0-56fe-35c7-1189ec6b60df.webp 2025-09-21 17:47:21.772 Debug ImageService-0HNFPBVTIP8BI:00000007: http/1.1 Response 200 to host1. Time: 627ms. GET http://192.168.1.80:8096/emby/Items/31988/Images/Primary?maxHeight=289&maxWidth=193&tag=370c7b353add2e76f4e01c76fa77c40e&quality=90. 2025-09-21 17:47:21.779 Debug ImageService-0HNFPBVTIP8BI:00000008: http/1.1 GET http://192.168.1.80:8096/emby/Items/31984/Images/Primary?maxHeight=289&maxWidth=193&tag=10ad7c13fba59816315e382b5bad4064&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.779 Debug SqliteItemRepository: GetitemById Person 31984 George Kennedy 2025-09-21 17:47:21.779 Debug App: ConvertImageToLocal item 31984 - image url: https://image.tmdb.org/t/p/original/fIVmcPEcPmh0Rbx4mYf9aneCmDe.jpg 2025-09-21 17:47:21.779 Info HttpClient: GET https://image.tmdb.org/t/p/original/fIVmcPEcPmh0Rbx4mYf9aneCmDe.jpg 2025-09-21 17:47:21.814 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/68f53a4c09dd4d0ab932dcb695e44062.webp took 232ms for /var/packages/EmbyServer/var/metadata/people/d/Don Harvey-tmdb-1280/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/a/af9e4b94-dccb-cffc-71cd-ec09f7145955.webp 2025-09-21 17:47:21.815 Debug ImageService-0HNFPBVTIP8BH:00000012: http/1.1 Response 200 to host1. Time: 672ms. GET http://192.168.1.80:8096/emby/Items/31991/Images/Primary?maxHeight=289&maxWidth=193&tag=ec26d76575a740f47adfff3d8bba92b4&quality=90. 2025-09-21 17:47:21.819 Debug ImageService-0HNFPBVTIP8BH:00000013: http/1.1 GET http://192.168.1.80:8096/emby/Items/31992/Images/Primary?maxHeight=289&maxWidth=193&tag=46bdce837447afdc1a7d54b323a60b81&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.819 Debug SqliteItemRepository: GetitemById Person 31992 Daniel Beer 2025-09-21 17:47:21.819 Debug App: ConvertImageToLocal item 31992 - image url: https://image.tmdb.org/t/p/original/mTiFrOhZn8gIzIALkaizt0BOiQM.jpg 2025-09-21 17:47:21.820 Info HttpClient: GET https://image.tmdb.org/t/p/original/mTiFrOhZn8gIzIALkaizt0BOiQM.jpg 2025-09-21 17:47:21.824 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/fIVmcPEcPmh0Rbx4mYf9aneCmDe.jpg after 44ms 2025-09-21 17:47:21.829 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/g/George Kennedy-tmdb-12950/folder.jpg 2025-09-21 17:47:21.830 Debug ImageProcessor: OnImageSizeObtained George Kennedy 2025-09-21 17:47:21.859 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/mTiFrOhZn8gIzIALkaizt0BOiQM.jpg after 40ms 2025-09-21 17:47:21.885 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/bcecfabfce624e689b243bcca47d1169.webp took 158ms for /var/packages/EmbyServer/var/metadata/people/j/Jeremy Green-tmdb-107369/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/c/c525dbba-6af0-0bdd-d1fc-c816a57f48ee.webp 2025-09-21 17:47:21.893 Debug ImageService-0HNFPBVTIP8BL:00000011: http/1.1 Response 200 to host1. Time: 198ms. GET http://192.168.1.80:8096/emby/Items/31994/Images/Primary?maxHeight=289&maxWidth=193&tag=68de8d5a7c6b3dde213739d70bb58f83&quality=90. 2025-09-21 17:47:21.898 Debug ImageService-0HNFPBVTIP8BL:00000012: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/7?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.912 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/365b102aec94469aaeb7f44b2a5e086a.webp took 260ms for /var/packages/EmbyServer/var/metadata/people/l/Lois Chiles-tmdb-10475/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/7/7c24040b-7526-2680-74c3-84da40b79090.webp 2025-09-21 17:47:21.913 Debug ImageService-0HNFPBVTIP8BM:00000007: http/1.1 Response 200 to host1. Time: 633ms. GET http://192.168.1.80:8096/emby/Items/31986/Images/Primary?maxHeight=289&maxWidth=193&tag=82a4b702bd9629b7f9c7e9b77047faf5&quality=90. 2025-09-21 17:47:21.921 Debug ImageService-0HNFPBVTIP8BM:00000008: http/1.1 GET http://192.168.1.80:8096/emby/Items/31995/Images/Primary?maxHeight=289&maxWidth=193&tag=98d1254a5df752e399876132e5ebdd2d&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.921 Debug SqliteItemRepository: GetitemById Person 31995 Page Hannah 2025-09-21 17:47:21.921 Debug App: ConvertImageToLocal item 31995 - image url: https://image.tmdb.org/t/p/original/sScxJrKNE0qruyZNsTz1kttQg0I.jpg 2025-09-21 17:47:21.921 Info HttpClient: GET https://image.tmdb.org/t/p/original/sScxJrKNE0qruyZNsTz1kttQg0I.jpg 2025-09-21 17:47:21.952 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/sScxJrKNE0qruyZNsTz1kttQg0I.jpg after 31ms 2025-09-21 17:47:21.954 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/d/Daniel Beer-tmdb-107368/folder.jpg 2025-09-21 17:47:21.955 Debug ImageProcessor: OnImageSizeObtained Daniel Beer 2025-09-21 17:47:21.959 Debug ImageService-0HNFPBVTIP8BL:00000012: http/1.1 Response 200 to host1. Time: 60ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Chapter/7?maxWidth=372&tag=5e701de725d1cb85624eabfa3502a2ef&mediaSourceId=mediasource_30747&quality=90. 2025-09-21 17:47:21.960 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/p/Page Hannah-tmdb-107370/folder.jpg 2025-09-21 17:47:21.960 Debug ImageProcessor: OnImageSizeObtained Page Hannah 2025-09-21 17:47:21.962 Debug ImageService-0HNFPBVTIP8BL:00000013: http/1.1 GET http://192.168.1.80:8096/emby/Items/31996/Images/Primary?maxHeight=289&maxWidth=193&tag=9b8ac27594e78d3fa788703ea0cea97c&quality=90. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:21.963 Debug SqliteItemRepository: GetitemById Person 31996 David Beecroft 2025-09-21 17:47:21.963 Debug App: ConvertImageToLocal item 31996 - image url: https://image.tmdb.org/t/p/original/t5iYHtXAPwxYfyaoQTiCclYtSPy.jpg 2025-09-21 17:47:21.963 Info HttpClient: GET https://image.tmdb.org/t/p/original/t5iYHtXAPwxYfyaoQTiCclYtSPy.jpg 2025-09-21 17:47:21.973 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/8469c4809e5e422caa93052b9d36ac2f.webp took 143ms for /var/packages/EmbyServer/var/metadata/people/g/George Kennedy-tmdb-12950/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/8/89fa8d0b-69c6-6207-7b2d-4e9ff3918c1c.webp 2025-09-21 17:47:21.977 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/nttzDvj4rpcCvtxbsEwLRN6nQFq.jpg after 251ms 2025-09-21 17:47:21.982 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/h/Holt McCallany-tmdb-7497/folder.jpg 2025-09-21 17:47:21.983 Debug ImageProcessor: OnImageSizeObtained Holt McCallany 2025-09-21 17:47:21.990 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/t5iYHtXAPwxYfyaoQTiCclYtSPy.jpg after 27ms 2025-09-21 17:47:21.991 Info ProviderManager: Saving image to /var/packages/EmbyServer/var/metadata/people/d/David Beecroft-tmdb-107371/folder.jpg 2025-09-21 17:47:21.991 Debug ImageProcessor: OnImageSizeObtained David Beecroft 2025-09-21 17:47:22.001 Debug ImageService-0HNFPBVTIP8BI:00000008: http/1.1 Response 200 to host1. Time: 222ms. GET http://192.168.1.80:8096/emby/Items/31984/Images/Primary?maxHeight=289&maxWidth=193&tag=10ad7c13fba59816315e382b5bad4064&quality=90. 2025-09-21 17:47:22.124 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/bc3158f09c0e4211bbd392a522f76cce.webp took 133ms for /var/packages/EmbyServer/var/metadata/people/d/David Beecroft-tmdb-107371/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/a/aa3f0f34-b44b-adf2-85ef-5b06d88c10e3.webp 2025-09-21 17:47:22.154 Debug ImageService-0HNFPBVTIP8BL:00000013: http/1.1 Response 200 to host1. Time: 192ms. GET http://192.168.1.80:8096/emby/Items/31996/Images/Primary?maxHeight=289&maxWidth=193&tag=9b8ac27594e78d3fa788703ea0cea97c&quality=90. 2025-09-21 17:47:22.176 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/7c2c442e69e84c39a86019e48c4c1047.webp took 1111ms for /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/fanart2.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/e/eb9aec42-83be-4d8d-9fea-8bdb43f81675.webp 2025-09-21 17:47:22.177 Debug ImageService-0HNFPBVTIP8BK:00000014: http/1.1 Response 200 to host1. Time: 1113ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Backdrop/0?tag=a9484c2d4d8dcf589d066d0afe002121&maxWidth=2560&quality=70. 2025-09-21 17:47:22.182 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/ea66516442de45758736ce7c714d360e.webp took 222ms for /var/packages/EmbyServer/var/metadata/people/p/Page Hannah-tmdb-107370/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/2/2597e165-9e63-3bc8-5dbe-65d1bdcb075c.webp 2025-09-21 17:47:22.186 Debug ImageService-0HNFPBVTIP8BM:00000008: http/1.1 Response 200 to host1. Time: 266ms. GET http://192.168.1.80:8096/emby/Items/31995/Images/Primary?maxHeight=289&maxWidth=193&tag=98d1254a5df752e399876132e5ebdd2d&quality=90. 2025-09-21 17:47:22.203 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/d5de1c1205424100ad57c2edc8d7f587.webp took 220ms for /var/packages/EmbyServer/var/metadata/people/h/Holt McCallany-tmdb-7497/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/b/bb036904-f1f8-0d2a-81b2-eeb7ecb6c96a.webp 2025-09-21 17:47:22.206 Debug ImageService-0HNFPBVTIP8BN:00000010: http/1.1 Response 200 to host1. Time: 482ms. GET http://192.168.1.80:8096/emby/Items/1091/Images/Primary?maxHeight=289&maxWidth=193&tag=a24529747c0a19d906da9694af5ae464&quality=90. 2025-09-21 17:47:22.264 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/a195b3a9092b41aa9d0bc3e189782c24.webp took 309ms for /var/packages/EmbyServer/var/metadata/people/d/Daniel Beer-tmdb-107368/folder.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/8/89c0f08e-1e8f-4caf-0322-f95d54ba02ab.webp 2025-09-21 17:47:22.280 Debug ImageService-0HNFPBVTIP8BH:00000013: http/1.1 Response 200 to host1. Time: 461ms. GET http://192.168.1.80:8096/emby/Items/31992/Images/Primary?maxHeight=289&maxWidth=193&tag=46bdce837447afdc1a7d54b323a60b81&quality=90. 2025-09-21 17:47:23.237 Debug UserLibraryService-0HNFPBVTIP8B6:00000004: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:47:23.237 Debug UserLibraryService-0HNFPBVTIP8B7:00000004: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:47:23.240 Debug TvShowsService-0HNFPBVTIP8B8:00000004: http/1.1 GET http://192.168.1.80:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio,DateCreated,CanDelete&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableTotalRecordCount=false&Limit=30&ImageTypeLimit=1&LegacyNextUp=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:47:23.241 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:47:23.245 Debug TvShowsService-0HNFPBVTIP8B8:00000004: http/1.1 Response 200 to host2. Time: 5ms. GET http://192.168.1.80:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio,DateCreated,CanDelete&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableTotalRecordCount=false&Limit=30&ImageTypeLimit=1&LegacyNextUp=true&format=json. 2025-09-21 17:47:23.250 Debug UserLibraryService-0HNFPBVTIP8B6:00000004: http/1.1 Response 200 to host2. Time: 14ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. 2025-09-21 17:47:23.253 Debug UserLibraryService-0HNFPBVTIP8B7:00000004: http/1.1 Response 200 to host2. Time: 17ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. 2025-09-21 17:47:45.055 Debug ImageService-0HNFPBVTIP8BH:00000014: http/1.1 GET http://192.168.1.80:8096/emby/Items/30747/Images/Backdrop/1?tag=81550e5e319f28594433562d03b409f9&maxWidth=2560&quality=70. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.055 Debug SqliteItemRepository: GetitemById Movie 30747 /volume1/SYNOLOGY/1080p Movies/Creepshow 2/Creepshow 2.mkv 2025-09-21 17:47:45.055 Debug App: Found cached image /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/fanart3.jpg 2025-09-21 17:47:45.511 Debug ImageProcessor: Image encoding using Skia to /var/packages/EmbyServer/var/cache/temp/78033c28fb784735b51e4149437a5b38.webp took 455ms for /var/packages/EmbyServer/var/metadata/library/44/44aeacd360b519034efaf7270c65fd28/imagecache/fanart3.jpg. Now moving to /var/packages/EmbyServer/var/cache/images/resized-images/1/195531d8-c855-2d8e-7a39-0483425254d9.webp 2025-09-21 17:47:45.512 Debug ImageService-0HNFPBVTIP8BH:00000014: http/1.1 Response 200 to host1. Time: 457ms. GET http://192.168.1.80:8096/emby/Items/30747/Images/Backdrop/1?tag=81550e5e319f28594433562d03b409f9&maxWidth=2560&quality=70. 2025-09-21 17:47:45.704 Debug UserService-0HNFPBVTIP8BH:00000015: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.704 Debug ItemsService-0HNFPBVTIP8BK:00000015: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.705 Debug UserService-0HNFPBVTIP8BH:00000015: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:45.705 Debug TvShowsService-0HNFPBVTIP8BL:00000014: http/1.1 GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.707 Debug UserLibraryService-0HNFPBVTIP8BN:00000011: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.708 Debug UserLibraryService-0HNFPBVTIP8BM:00000009: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:47:45.709 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:47:45.720 Debug TvShowsService-0HNFPBVTIP8BL:00000014: http/1.1 Response 200 to host1. Time: 15ms. GET http://192.168.1.80:8096/emby/Shows/NextUp?LegacyNextUp=true&UserId=6ee31637e48f41cc80a2afcf6066bf69&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:45.723 Debug UserLibraryService-0HNFPBVTIP8BM:00000009: http/1.1 Response 200 to host1. Time: 15ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:45.728 Debug ItemsService-0HNFPBVTIP8BK:00000015: http/1.1 Response 200 to host1. Time: 24ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Resume?Recursive=true&MediaTypes=Video&IncludeNextUp=false&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:47:45.728 Debug UserLibraryService-0HNFPBVTIP8BN:00000011: http/1.1 Response 200 to host1. Time: 21ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,ProgramPrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&Limit=16&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:23.248 Debug UserLibraryService-0HNFPBVTIP8B7:00000005: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:49:23.250 Debug UserLibraryService-0HNFPBVTIP8B6:00000005: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:49:23.250 Debug TvShowsService-0HNFPBVTIP8B8:00000005: http/1.1 GET http://192.168.1.80:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio,DateCreated,CanDelete&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableTotalRecordCount=false&Limit=30&ImageTypeLimit=1&LegacyNextUp=true&format=json. Source Ip: host2, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2025-09-21 17:49:23.251 Debug App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey) 2025-09-21 17:49:23.256 Debug TvShowsService-0HNFPBVTIP8B8:00000005: http/1.1 Response 200 to host2. Time: 7ms. GET http://192.168.1.80:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio,DateCreated,CanDelete&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableTotalRecordCount=false&Limit=30&ImageTypeLimit=1&LegacyNextUp=true&format=json. 2025-09-21 17:49:23.267 Debug UserLibraryService-0HNFPBVTIP8B6:00000005: http/1.1 Response 200 to host2. Time: 17ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=24400&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. 2025-09-21 17:49:23.272 Debug UserLibraryService-0HNFPBVTIP8B7:00000005: http/1.1 Response 200 to host2. Time: 24ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69/Items/Latest?ParentId=30636&Fields=PrimaryImageAspectRatio,CanDelete,ItemCounts,DisplayPreferencesId,CriticRating,CommunityRating,OfficialRating,PremiereDate,EndDate,ProductionYear&EnableTotalRecordCount=false&Limit=20&GroupItems=true&format=json. 2025-09-21 17:49:47.444 Debug UserService-0HNFPBVTIP8BN:00000012: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.445 Debug UserService-0HNFPBVTIP8BN:00000012: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.447 Debug App: SessionInfosWebSocketListener Begin transmitting over websocket to 192.168.1.229 2025-09-21 17:49:47.447 Debug ScheduledTaskService-0HNFPBVTIP8BK:00000016: http/1.1 GET http://192.168.1.80:8096/emby/ScheduledTasks?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.447 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 192.168.1.229 2025-09-21 17:49:47.449 Debug ScheduledTaskService-0HNFPBVTIP8BK:00000016: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/ScheduledTasks?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.449 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.229 2025-09-21 17:49:47.449 Debug LiveTvService-0HNFPBVTIP8BL:00000015: http/1.1 GET http://192.168.1.80:8096/emby/LiveTv/Recordings?UserId=6ee31637e48f41cc80a2afcf6066bf69&IsInProgress=true&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary,Thumb,Backdrop&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.450 Debug LiveTvService-0HNFPBVTIP8BL:00000015: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/LiveTv/Recordings?UserId=6ee31637e48f41cc80a2afcf6066bf69&IsInProgress=true&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary,Thumb,Backdrop&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.450 Debug SessionsService-0HNFPBVTIP8BH:00000016: http/1.1 GET http://192.168.1.80:8096/emby/Sessions?IncludeAllSessionsIfAdmin=true&IsPlaying=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.451 Debug SessionsService-0HNFPBVTIP8BH:00000016: http/1.1 Response 200 to host1. Time: 0ms. GET http://192.168.1.80:8096/emby/Sessions?IncludeAllSessionsIfAdmin=true&IsPlaying=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.451 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.229 2025-09-21 17:49:47.451 Debug SystemService-0HNFPBVTIP8BM:0000000A: http/1.1 GET http://192.168.1.80:8096/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.452 Debug SystemService-0HNFPBVTIP8BM:0000000A: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.457 Debug ActivityLogService-0HNFPBVTIP8BK:00000017: http/1.1 GET http://192.168.1.80:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2025-09-14T22:49:47.450Z&hasUserId=false&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.458 Debug ActivityLogService-0HNFPBVTIP8BK:00000017: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2025-09-14T22:49:47.450Z&hasUserId=false&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.459 Debug UserService-0HNFPBVTIP8BH:00000017: http/1.1 GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.459 Debug UserService-0HNFPBVTIP8BH:00000017: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/Users/6ee31637e48f41cc80a2afcf6066bf69?X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.460 Debug WebAppService-0HNFPBVTIP8BN:00000013: http/1.1 GET http://192.168.1.80:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.460 Debug ActivityLogService-0HNFPBVTIP8BO:00000001: http/1.1 GET http://192.168.1.80:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2025-09-14T22:49:47.449Z&hasUserId=true&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.462 Debug WebAppService-0HNFPBVTIP8BN:00000013: http/1.1 Response 200 to host1. Time: 2ms. GET http://192.168.1.80:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.463 Debug ActivityLogService-0HNFPBVTIP8BO:00000001: http/1.1 Response 200 to host1. Time: 3ms. GET http://192.168.1.80:8096/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2025-09-14T22:49:47.449Z&hasUserId=true&EnableTotalRecordCount=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:47.485 Debug WebAppService-0HNFPBVTIP8BO:00000002: http/1.1 GET http://192.168.1.80:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableInUserMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:47.486 Debug WebAppService-0HNFPBVTIP8BO:00000002: http/1.1 Response 200 to host1. Time: 1ms. GET http://192.168.1.80:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=6ee31637e48f41cc80a2afcf6066bf69&EnableInUserMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:51.704 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.229 2025-09-21 17:49:51.704 Debug App: SessionInfosWebSocketListener stop transmitting over websocket to 192.168.1.229 2025-09-21 17:49:51.711 Debug SystemService-0HNFPBVTIP8BO:00000003: http/1.1 GET http://192.168.1.80:8096/emby/System/Logs/Query?IncludeItemTypes=Log&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,DateModified,Size&StartIndex=0&Recursive=true&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0 2025-09-21 17:49:51.715 Debug SystemService-0HNFPBVTIP8BO:00000003: http/1.1 Response 200 to host1. Time: 3ms. GET http://192.168.1.80:8096/emby/System/Logs/Query?IncludeItemTypes=Log&Fields=BasicSyncInfo,CanDelete,CanDownload,PrimaryImageAspectRatio,DateModified,Size&StartIndex=0&Recursive=true&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Edge Windows&X-Emby-Device-Id=0143d1e1-5a0c-4a8c-9add-388cf4470655&X-Emby-Client-Version=4.9.1.34&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. 2025-09-21 17:49:59.521 Debug SystemService-0HNFPBVTIP8BO:00000005: http/1.1 GET http://192.168.1.80:8096/emby/System/Logs/embyserver.txt?Sanitize=true&api_key=x_secret2_x&SetFilename=true. Source Ip: host1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 Edg/141.0.0.0
Luke 42240 Posted September 22, 2025 Posted September 22, 2025 HI, I can confirm there is an issue in 4.9.1.34. 4.9.1.35 is on it's way up. Please let us know if this resolves it for you. Thanks.
jelildude 13 Posted September 22, 2025 Author Posted September 22, 2025 3 hours ago, Luke said: HI, I can confirm there is an issue in 4.9.1.34. 4.9.1.35 is on it's way up. Please let us know if this resolves it for you. Thanks. Luke, thanks for the heads up! I'll update when the new version drops and we'll see what happens!
jelildude 13 Posted September 22, 2025 Author Posted September 22, 2025 Awesome Luke! I'm gonna update after work in a few hours and I'll post results here... 1
Solution jelildude 13 Posted September 22, 2025 Author Solution Posted September 22, 2025 ISSUE IS FIXED!! The newest Beta update fixed my issue with Movie theme songs not playing! I'd like to thank GrimReaper and Neminem for the suggestions, and big thanks to Luke for being so responsive to the Emby user experience....So glad to be a Lifetime Premier user and a part of the community! 1 1
