sbcrumb 2 Posted September 19, 2025 Posted September 19, 2025 Hi all, I’ve been working on a project called NFOGuard to solve a common headache: when you upgrade media (HDTV → Web → Blu-ray, etc.), Emby often resets the DateCreated to “now.” That pushes old movies/episodes back to the top of “Recently Added” and scrambles your library history. What NFOGuard does: Runs as a Docker service that listens to Sonarr/Radarr webhooks. Detects whether an item is a new import or an upgrade. Maintains a DB of original import dates and updates/writes .nfo files accordingly. Includes a backfill option for existing libraries (fallbacks: TV → airdate, Movies → theatrical/digital release date). Bundles an Emby plugin (the .dll is already inside the Docker image for easy testing). Status: This is Alpha software intended for power users. Make sure you have backups and be ready for breakage. Right now I’m looking for community testers to try it in different setups and workflows, and share feedback. Links: GitHub (Docker/webhook code + setup): https://github.com/sbcrumb/nfoguard Discord (alpha testinghttps://discord.gg/bbD9Pmtr Before You Test: You’re running Sonarr/Radarr and Emby. Comfortable with Docker. Backups ready (Emby DB + media). Willing to share logs/feedback if things break. Thanks in advance to anyone willing to help test — your feedback will help make this reliable for all Emby users. 1
