Luke 42242 Posted October 5, 2025 Posted October 5, 2025 1 hour ago, moneycwq said: 是蓝光文件夹,Blu-ray folder Maybe try refreshing the metadata on it and then see if it plays after that.
moneycwq 2 Posted October 5, 2025 Author Posted October 5, 2025 1 hour ago, Luke said: 也许尝试刷新它的元数据,然后看看它是否可以播放。 不行,我重启重新刷新不下10次了。挺奇怪的,之前正常播放的,我还看了一半,有进度条,现在就显示是没有合适的流,无语 No, I have restarted and refreshed it at least 10 times. It is very strange. It was playing normally before, and I was halfway through it, with a progress bar. Now it shows that there is no suitable stream. I am speechless.
Luke 42242 Posted October 6, 2025 Posted October 6, 2025 Can you please provide a log from playing the same content in the Emby web app? Thanks.
moneycwq 2 Posted October 7, 2025 Author Posted October 7, 2025 On 2025/10/6 at PM12点49分, Luke said: 您能否提供在 Emby Web 应用中播放相同内容的日志?谢谢。 我目前已经没有windows server内的emby server,只有debian下的emby server,这样的日志文件可以吗? I currently don't have an emby server in Windows Server, I only have an emby server under Debian. Is this log file okay? embyserver.txt
Luke 42242 Posted October 11, 2025 Posted October 11, 2025 OK I think this might be resolved on the server beta channel although I'm not positive about that.
