TMCsw 259 Posted September 22, 2025 Posted September 22, 2025 6 hours ago, moneycwq said: Under Windows, playback isn't working properly. So, you expect an OS change to fix your problem of illegally downloaded garbage?
Luke 42242 Posted September 22, 2025 Posted September 22, 2025 4 hours ago, moneycwq said: I'm really new to Debian and don't know how to set permissions. The permissions I've given so far are fragmented and come from replies from people in the thread and from the emby technicians. I'd appreciate a consistent command line, thanks! I'm not sure what you mean by recursion. I simply went to Debian > File Management > Folders > Permissions and gave all users and groups read and write permissions. Then I typed the commands I posted above, which I typed based on the instructions in the thread. I don't really understand these commands; I'm just imitating them. Hi, have you taken a look at this?
moneycwq 2 Posted September 22, 2025 Author Posted September 22, 2025 1 hour ago, TMCsw said: 那么,您希望通过操作系统的改变来解决非法下载垃圾的问题吗? sorry,This is a typo. It can be played normally under Windows. There is no error or problem.
moneycwq 2 Posted September 22, 2025 Author Posted September 22, 2025 (edited) 2 小时前,Luke 说: 你好,你看过这个了吗? 要求的是 rwxr- xr - x. 2 emby users ,实际上是 drw-rwxrw-+ 13 emby Users,那么我需要输入什么命令才能满足要求呢? 你推荐的帖子我至少读了三遍,但还是一头雾水。我不明白这些自相矛盾的命令。为什么 Emby 不能提供一组更清晰的命令来确定权限?我应该将权限设置为 755、775、777 还是其他值?我应该使用: chmod 755 -R /vol5/1000/电影院 或者? setfacl -m user:emby:rxw /vol5/1000/Cinema 无论何时我在任何地方更改此行,都会出现错误;它仅适用于 rxw。 我这样做对吗? This is the latest log file after changing the permissions. Can you see if there's any other issues? Is there a permissions issue? All my media files are stuck at the beginning when I click them, and they keep spinning in circles after the categories appear. But if I drag the progress bar a little, it plays normally. Is this still a permissions issue? embyserver.txt Edited September 22, 2025 by moneycwq
Luke 42242 Posted September 27, 2025 Posted September 27, 2025 @moneycwqI don't see anything permissions related. Since you're on Windows, have you tried our new windows app? https://emby.media/emby-for-windows.html
moneycwq 2 Posted September 28, 2025 Author Posted September 28, 2025 On 2025/9/22 at AM3点20分, Luke said: 您是否递归设置了权限?文件可能会覆盖您在上级文件夹中设置的权限。 I strongly suggest that the emby technicians list the complete commands required to increase the permissions on the folder directory so that people can fully imitate and use them. Simply telling users what permissions are required may not be of much help to users. I am almost going crazy. I just gave permissions according to the folder permissions mentioned in your previous post, but I have tried various commands and I don’t know which command suddenly allows emby to read and write media folders. Before I had time to celebrate, I restarted the NAS, and it turned out that it could not be read due to permissions issues. I really had no choice but to give the media folder 777 permissions, and now it seems to be working again. I hope that the permissions will be gone again the next time the NAS is restarted. Please take care of users who are not familiar with Linux. We only need you to post the complete commands for granting permissions so that we can imitate them one by one, or list the command lines in the user manual. Thank you very much!
moneycwq 2 Posted September 28, 2025 Author Posted September 28, 2025 On 2025/9/27 at AM10点51分, Luke said: @moneycwq我没有看到任何与权限相关的内容。既然您使用的是 Windows,您是否尝试过我们新的 Windows 应用? https://emby.media/emby-for-windows.html 我现在没有使用windwos,windows下emby没有任何问题,一切让人满意,只是现在我因为一些因素,没办法只能使用debian系统,从而导致emby各种问题 I am not using Windows now. There is no problem with Emby under Windows. Everything is satisfactory. But now I have no choice but to use Debian system due to some factors, which leads to various problems with Emby.
Luke 42242 Posted October 2, 2025 Posted October 2, 2025 On 9/28/2025 at 2:39 PM, moneycwq said: I strongly suggest that the emby technicians list the complete commands required to increase the permissions on the folder directory so that people can fully imitate and use them. Simply telling users what permissions are required may not be of much help to users. I am almost going crazy. I just gave permissions according to the folder permissions mentioned in your previous post, but I have tried various commands and I don’t know which command suddenly allows emby to read and write media folders. Before I had time to celebrate, I restarted the NAS, and it turned out that it could not be read due to permissions issues. I really had no choice but to give the media folder 777 permissions, and now it seems to be working again. I hope that the permissions will be gone again the next time the NAS is restarted. Please take care of users who are not familiar with Linux. We only need you to post the complete commands for granting permissions so that we can imitate them one by one, or list the command lines in the user manual. Thank you very much! Thanks for the update. Have the permissions held iup?
darrenkdean 31 Posted October 3, 2025 Posted October 3, 2025 Debian is a very stable & secure server OS, but it is generations behind (intentionally) for GPU drivers. I spent weeks troubleshooting the No Compatible Streams error in my Debian Linux based Emby Server. I'm guessing this only happens when transcoding (not direct streaming) & only for certain file types, HECV, DV, HDR10+. The reason it is failing, is that Debian is running Intel GPU Drivers v22 or less. The versions there after, added a great deal of transcoding support. Even using experimental driver repo's I was unable to force Debian to accept the current Intel 25 LTS GPU drivers. Swap to ubuntu, load the latest intel drivers, & all of these issues go away. Good luck! 1
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 23 hours ago, Luke said: 感谢更新。权限问题解决了吗? In desperation, I finally used chmod 777 /vol5/1000/cinema, which gave all permissions and allowed it to run, but it felt like it could easily cause permissions to get out of control. Apart from this, I couldn't find any other commands that could run normally.
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 3 hours ago, darrenkdean said: Debian 是一款非常稳定且安全的服务器操作系统,但它的 GPU 驱动程序却落后了好几代(这是故意为之)。我花了数周时间排查基于 Debian Linux 的 Emby 服务器中“无兼容流”的错误。我猜这只会在转码(而非直接流式传输)时发生,并且只适用于某些文件类型,例如 HECV、DV、HDR10+。 失败的原因是 Debian 运行的是英特尔 GPU 驱动程序 v22 或更低版本。之后的版本增加了大量的转码支持。即使使用实验性的驱动程序仓库,我也无法强制 Debian 接受当前的英特尔 25 LTS GPU 驱动程序。切换到 Ubuntu,加载最新的英特尔驱动程序,所有这些问题都解决了。祝你好运! For some special reasons, I can only use Debian and cannot use Ubuntu, so is there any way to make Debian use the latest driver? 1
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 (edited) 2025年10月2日下午1点02分,卢克说: 感谢更新。权限问题解决了吗? 我发现根本没解决问题。即使我用 chmod 777 授权了,新下载的文件还是没有权限。这太烦人了。Debian 这样的操作系统设计出来干嘛用?Emby 就不能直接给我们几个命令一次性把目录权限给别人吗?真是无语。Every time I download a new movie or TV show, I have to use ssh and chmod to grant permissions again, which is really torture. Edited October 3, 2025 by moneycwq 1
Neminem 1623 Posted October 3, 2025 Posted October 3, 2025 Guess you need to tell your downloader to set permissions when done Emby does not touch your files unless you give it permissions.
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 13 minutes ago, Neminem said: 我想你需要告诉你的下载器在完成后设置权限 除非您授予权限,否则 Emby 不会触碰您的文件。 How can I do this? Could you give me some advice? Thanks
Neminem 1623 Posted October 3, 2025 Posted October 3, 2025 Just now, moneycwq said: How can I do this? Could you give me some advice? Thanks How would I know that, I'm not managing you server. You have not told us what you do to acquire media or how it's ingested.
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 11 minutes ago, Neminem said: 我怎么知道呢,我没有管理你的服务器。 您还没有告诉我们您是如何获取媒体或如何获取媒体的。 I download pt through qbittorrent, and the downloaded directory is this Cinema. I use an administrator named emby to manage it, and I use an administrator named CHEN to manage the debian system.
moneycwq 2 Posted October 3, 2025 Author Posted October 3, 2025 (edited) 我真是疯了。我又运行了 chmod -R a+rwxX /vol5/1000/Cinema 命令,但 Cinema 里有些目录可以播放,有些却被逮捕了。我能一次性夺取永久 emby 程序对 Cinema 目录中所有目录和文件的读、写和执行权限吗?我必须逐个文件地输入这些权限吗?For example, I currently have a file called /vol5/1000/Cinema/Movie/Comedy/Miss.Congeniality.2000.2005.Double.Feature.1080p.Blu-ray.VC1.DTS-HD.MA.5.1-DiY@KBu. I used to be able to play this file fine, but today it's no longer working. Other files in the same directory play fine, which is really confusing. I'd be happy to pay a fee, like a beer, to anyone who can help me completely resolve this issue. I hope this can be completely resolved. Attached is my recent log file. Honestly, I don't understand it either. embyserver.txt ffmpeg-transcode-3d5ae3b6-84cb-4ade-a9ed-1a20022d9d91_1.txt Edited October 3, 2025 by moneycwq
TMCsw 259 Posted October 4, 2025 Posted October 4, 2025 6 hours ago, moneycwq said: I'd be happy to pay a fee, like a beer, to anyone who can help me completely resolve this issue. Why don't you start by spending a few hours learning the OS you have chosen to run Emby on (there are many ways to do this with guides, YouTube, etc.)? Lose the attitude that Emby should correct everyone's Linux install because you chose the OS to run it! Start with basic Linux permissions (get rid of the ACLs as they are rarely needed for home or even many small businesses, and confuse things). Many here don't like helping pirates (Torrents). Then maybe one of us here will give you a hand (maybe even for free)
Luke 42242 Posted October 4, 2025 Posted October 4, 2025 7 hours ago, moneycwq said: I'm going crazy. I ran chmod -R a+rwxX /vol5/1000/Cinema again, but some directories in Cinema play, while others are blocked. Can I permanently remove read, write, and execute permissions for all directories and files in the Cinema directory from the emby program at once? Do I have to enter these permissions file by file? For example, I currently have a file called /vol5/1000/Cinema/Movie/Comedy/Miss.Congeniality.2000.2005.Double.Feature.1080p.Blu-ray.VC1.DTS-HD.MA.5.1-DiY@KBu. I used to be able to play this file fine, but today it's no longer working. Other files in the same directory play fine, which is really confusing. I'd be happy to pay a fee, like a beer, to anyone who can help me completely resolve this issue. I hope this can be completely resolved. Attached is my recent log file. Honestly, I don't understand it either. embyserver.txt 70.23 MB · 0 downloads ffmpeg-transcode-3d5ae3b6-84cb-4ade-a9ed-1a20022d9d91_1.txt 13.46 kB · 0 downloads Is this a video file, or a bluray folder?
moneycwq 2 Posted October 4, 2025 Author Posted October 4, 2025 (edited) 5 hours ago, Luke said: 这是一个视频文件,还是蓝光文件夹? 这是一个蓝光文件夹,It was playing fine before, I even watched it for a while.Oh, by the way, the previous version of emby was 4.8.1, and now it seems to have been upgraded to 4.9. I wonder if this is an influencing factor? Edited October 4, 2025 by moneycwq
moneycwq 2 Posted October 4, 2025 Author Posted October 4, 2025 6 hours ago, TMCsw said: 为什么不先花几个小时来学习您选择运行 Emby 的操作系统呢(有很多方法可以通过指南、YouTube 等来做到这一点)? 不要再认为 Emby 应该纠正每个人的 Linux 安装,因为您选择了运行它的操作系统! 从基本的 Linux 权限开始(摆脱 ACL,因为家庭甚至许多小型企业很少需要它们,而且会使事情变得混乱)。 这里的许多人不喜欢帮助盗版者(Torrents)。 那么也许我们中的一个人会给你帮忙(甚至可能是免费的) I read your message and feel deeply insulted. I don't understand why you accuse me of being a pirate? Even if it's because my IP address is from China? I think this is discrimination!!! I use a Debian-based NAS OS developed by https://www.fnnas.com/. I'm a fully licensed member of Emby, which I believe can verify this; my ID is available. I don't have any pirated software on my computer. My Windows and Office are genuine, and all other software I use is genuine or open source. Why do you directly accuse me of being a pirate? What kind of prejudice or preconceptions allow you to make such accusations without understanding the facts? You're right. I should definitely learn Linux, but I'm not a computer science major. I imagine many Emby users share the same sentiment. As an Emby member, I believe Emby should provide some technical support. Furthermore, if the system and application details are clearly defined, Emby should be able to easily determine directory permissions. Even if emby isn't clear, using a command like "sudo chmod -R 777 /emby/folder" should have given all files in the directory 777 permissions. I've also followed the emby administrator's instructions and even given the media directory more permissions, so why am I still experiencing this issue? I'm willing to pay because I know knowledge is valuable, especially knowledge I don't understand, just like buying genuine software. I also hope someone can help me. As I mentioned earlier, for some unspecified reasons, I can't continue using my normal Windows system on my NAS. I've had to switch to this NAS operating system, which uses Debian, a system I'm not familiar with. I've searched and studied Google for a long time, but I can't find a solution. My limited skills are why I'm seeking help on this forum! Thank you for your attention and suggestions!
TMCsw 259 Posted October 4, 2025 Posted October 4, 2025 15 hours ago, moneycwq said: I don't have any pirated software on my computer. I never said otherwise. On 10/3/2025 at 2:25 PM, moneycwq said: I download pt through qbittorrent, Do you not consider copyright infringement (on media) piracy?
Luke 42242 Posted October 4, 2025 Posted October 4, 2025 Let's just stick to the topic of the error that he's having. @moneycwqI think there was a translation error. Is it a video file or bluray folder?
moneycwq 2 Posted October 5, 2025 Author Posted October 5, 2025 40 minutes ago, Luke said: 让我们继续讨论他所犯的错误这个话题。 @moneycwq我感觉翻译有误。是视频文件还是蓝光文件夹? 是蓝光文件夹,Blu-ray folder
moneycwq 2 Posted October 5, 2025 Author Posted October 5, 2025 44 minutes ago, TMCsw said: 我从来没有说过不是这样。 您不认为(媒体上的)版权侵权是盗版吗? I haven't really considered this. The forums I joined don't specify whether it's pirated media. I'm not in the computer industry, so if it's pirated media, then you're right. I'm also curious, is all the media on your computer legitimate? Also, I don't rely solely on Emby; I also have a Netflix membership. I only use Emby to collect movies and home videos that I really need to have. Then ask again, if you accuse me so much, I believe that your computer must not have any pirated or no royalty documents, right?
