mohoelx 12 Posted September 17, 2025 Posted September 17, 2025 I have a library for my Live TV recordings for TV Shows, and another for Movies, and basically those work just fine. What I'm wondering is, since there isn't a "content type" for Sports when creating a new Library, am I just going to have to deal with sports programs (NFL, MLB) going into the general TV Shows library? Thanks.
Luke 42239 Posted September 17, 2025 Posted September 17, 2025 Hi, why not do a separate TV shows library for sports?
mohoelx 12 Posted September 17, 2025 Author Posted September 17, 2025 That's fine, but how to I get Sports to go there? On the Live TV settings, I don't see how to do that. Do I just create a library for Sports and include it in the Series recordings folder?
Luke 42239 Posted September 17, 2025 Posted September 17, 2025 OK I see what you mean. I guess currently the only way to truly separate it would be to move it out of the recording library after the recording has completed. But obviously that is cumbersome. We should probably add a sports recording folder option under there. 1
