Luke 42289 Posted September 21, 2025 Posted September 21, 2025 Hi, you’re aware that you can remove the entire section from the Home Screen, right?
brothom 211 Posted September 21, 2025 Posted September 21, 2025 13 hours ago, js28194 said: uhhh.... see above? You can remove continuing playing already.... Whats the problem here? That's not a solution at all. Removing the entire section completely removes this functionality all together. 13 hours ago, js28194 said: Trying to make everything like everything else is mono-culturish. I'm baffled by this attitude. Nobody is forcing YOU to USE emby. So strange. This isn't really a constructive comment in my opinion. We're all here because we want to make Emby a better product in the long term. Nobody is talking about forcing Emby onto anyone so that's just interpretation I suppose. When a person uses software, that persons tends to have certain preferences, patterns or behaviours based on their previous experiences. By using that to our advantage we could make Emby even more user-friendly. I'm also pretty sure that companies like Netflix and Google have a much larger research budget than Emby so taking a few pages out of their book isn't such a bad idea right?
ebr 16354 Posted September 21, 2025 Posted September 21, 2025 Didn't we solve this issue by simply using the standard Android app? 1
