mickle026 653 Posted September 14, 2025 Posted September 14, 2025 (edited) Create a Netflix 'style' poster rotation for Movies, TV Shows and Music Set the config page, then the scheduled Task to run on your desired interval WARNING! Poster Rotator overwrites the downloaded poster in Emby Cache !!! I don't accept any responsibility if you didn't read this and screw up your images! i.e. Don't be an idiot first, read what this does first before even attempting to use it! If you have no idea what this does, then don't use it. I accept no responsibility whatsoever! This is the first public version, so treat it as a test version - find the bugs! Not sure how the backup original poster is working, if it creates lots of images or not in .posters PosterRotator.zip Edited September 14, 2025 by mickle026 1
Amanade3 32 Posted November 25, 2025 Posted November 25, 2025 (edited) Says in the plugin " The plugin will periodically replace the item's primary poster with one of these images according to your settings. what does periodically mean, Say if I want the poster to changeĀ should I run a scheduled task or the plugin does it in certain interval. if the later is the case, at what interval? because i tried putting a 4 different poster image in one of the movie's .posters folder, and run scheduled task twice and poster is still the same. Am i missing something? Edited November 25, 2025 by Amanade3
