Luke 42239 Posted September 29, 2025 Posted September 29, 2025 OK once you get the 1.0.40 m3u plugin update, please run the refresh guide scheduled task and then see if that helps. Thanks.
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 7 minutes ago, Luke said: OK once you get the 1.0.40 m3u plugin update, please run the refresh guide scheduled task and then see if that helps. Thanks. Just updated, restarted Emby, Tried the header stream only, gave me the same 404 error with a different domain.
Luke 42239 Posted September 29, 2025 Posted September 29, 2025 Just now, lawm0500 said: Just updated, restarted Emby, Tried the header stream only, gave me the same 404 error with a different domain. Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 2 minutes ago, Luke said: Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks! Just sent you a DM.
Luke 42239 Posted September 29, 2025 Posted September 29, 2025 OK once you get the 1.0.41 m3u plugin update, please run the refresh guide scheduled task and then see if that helps. Thanks.
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 9 minutes ago, Luke said: OK once you get the 1.0.41 m3u plugin update, please run the refresh guide scheduled task and then see if that helps. Thanks. Sent another DM. If you need me to send the stream itself, let me know.
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 6 minutes ago, lawm0500 said: Sent another DM. If you need me to send the stream itself, let me know. Never mind, it is now working. Thank you for the help @Luke.
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 11 minutes ago, lawm0500 said: Never mind, it is now working. Thank you for the help @Luke. @LukeNew problem. Different service, redirects are loading without the header, so the stream doesn't work. Something is telling me that Emby doesn't know how to process the redirects. Will send a log with the stream itself.
Solution Luke 42239 Posted September 29, 2025 Solution Posted September 29, 2025 3 hours ago, lawm0500 said: @LukeNew problem. Different service, redirects are loading without the header, so the stream doesn't work. Something is telling me that Emby doesn't know how to process the redirects. Will send a log with the stream itself. OK since you're on the beta server please try again with the next build. Thanks.
lawm0500 6 Posted September 29, 2025 Author Posted September 29, 2025 7 hours ago, Luke said: OK since you're on the beta server please try again with the next build. Thanks. I will wait for the next Emby beta build than once that is uploaded. 1
lawm0500 6 Posted October 10, 2025 Author Posted October 10, 2025 On 9/28/2025 at 11:54 PM, Luke said: OK since you're on the beta server please try again with the next build. Thanks. Running some tests on 4.9.2.2, seems to be working, going to test more later. 1
lawm0500 6 Posted October 10, 2025 Author Posted October 10, 2025 On 9/28/2025 at 11:54 PM, Luke said: OK since you're on the beta server please try again with the next build. Thanks. 4.9.2.2 is working, I appreciate the help. 1
