Mendocinotim 22 Posted September 12, 2025 Posted September 12, 2025 I have an unusual issue.. The Drobo (which I used for many years, and has many many movies and TV shows on it) no longer allows writing to it. It is still readable however. One particular show I have on it has many corrupted files, and needs to be replaced. I have a second drive I am using when I add new shows and movies now; and the show which needs replacing already has the replacement on it. My goal here is to figure out a way to tell Emby that I want it to ignore that show's show folder, only (the one on the read-only Drobo). - There are other shows on the (now) read-only volume, and I still want Emby to access those. So, as the volume is read-only, I cannot add a .embyignore file to it. No, I do not want to remove the volume from emby, and then add each show folder individually, as I have too many to make that practical. BTW: Yes, I do intend to replace that Drobo, just as soon as I can afford to do so. But meanwhile.. Is there a way to tell Emby server to ignore just that show, from the read-only volume?
Luke 42237 Posted September 18, 2025 Posted September 18, 2025 HI, sadly I cannot think of a way to avoid it being scanned. Obviously you can use various technique to hide it once it's imported but that's not quite as desirable of a solution.
