xmqfetya 1 Posted September 11, 2025 Posted September 11, 2025 Hi I have installed repository.emby.kodi-1.0.8.zip Installing "Emby for Kodi Next Gen" fails with the following messages: Spoiler 2025-09-11 18:49:32.445 T:4574 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:32.445 T:4574 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:32.467 T:4554 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:32.467 T:4554 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:32.571 T:4554 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:32.571 T:4554 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:32.661 T:4578 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:32.661 T:4578 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:51.783 T:4595 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:51.783 T:4595 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:51.820 T:4595 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:51.820 T:4595 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:53.984 T:3957 info <general>: Loading skin file: DialogAddonInfo.xml, load type: KEEP_IN_MEMORY 2025-09-11 18:49:56.324 T:4600 error <general>: CCurlFile::CReadState::FillBuffer - (0xe3afff38) Failed: Stream error in the HTTP/2 framing layer(92) 2025-09-11 18:49:56.325 T:4600 error <general>: GetDirectory - Error getting zip://special%3a%2f%2fhome%2faddons%2fpackages%2fplugin.service.emby-next-gen-11.1.27.zip/ 2025-09-11 18:49:56.325 T:4600 error <general>: CAddonInstallJob[plugin.service.emby-next-gen]: invalid package special://home/addons/packages/plugin.service.emby-next-gen-11.1.27.zip 2025-09-11 18:49:56.344 T:4613 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:56.344 T:4613 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition 2025-09-11 18:49:56.380 T:4613 error <general>: Repository add-on repository.kodinerds uses old schema definition for the repository extension point! This is no longer supported, please update your addon to use <dir> definitions. 2025-09-11 18:49:56.380 T:4613 error <general>: Repository add-on repository.kodinerds does not have any directory matching 21.2.0 and won't be able to update/serve addons! Please fix the addon.xml definition I am on CoreELEC 21.2 Can you help please?
xmqfetya 1 Posted September 11, 2025 Author Posted September 11, 2025 I think there is an issue with https://embydata.com/downloads/addons/xbmb3c/multi-repo/repositories/addons.xml <addon id="repository.kodinerds" name="kodinerds.net Add-ons" version="6.0.0" provider-name="L0RE"> <extension point="xbmc.addon.repository" name="L0RE"> <info compressed="true">https://raw.githubusercontent.com/kodinerds/repo/master/addons.xml</info> <checksum>https://raw.githubusercontent.com/kodinerds/repo/master/addons.xml.md5</checksum> <datadir zip="true">https://raw.githubusercontent.com/kodinerds/repo/master/</datadir> Those URL are dead
Luke 42237 Posted September 11, 2025 Posted September 11, 2025 Hi we’ll see what @quickmic thinks. Thanks.
quickmic 1709 Posted September 11, 2025 Posted September 11, 2025 (edited) 24 minutes ago, Luke said: Hi we’ll see what @quickmic thinks. Thanks. This repo (link) is completely outdated, I'll try to fix it/or remove it. Actually it's a link to a 3rd party repo. https://repo.kodinerds.net/ Not sure if this should be integrated in Emby's Kodi repository as it's not part of Emby's Kodi plugins. Edited September 11, 2025 by quickmic 1
quickmic 1709 Posted September 11, 2025 Posted September 11, 2025 @xmqfetya btw, I assume the issue has nothing to do with the e4k installation issue. You can sideload the plugin as a workaround.
xmqfetya 1 Posted September 12, 2025 Author Posted September 12, 2025 Thanks for the reply I have successfully installed the plugins by sideloading It would be great to have a repo though The issue is related to those errors then ? 2025-09-11 18:49:56.324 T:4600 error <general>: CCurlFile::CReadState::FillBuffer - (0xe3afff38) Failed: Stream error in the HTTP/2 framing layer(92) 2025-09-11 18:49:56.325 T:4600 error <general>: GetDirectory - Error getting zip://special%3a%2f%2fhome%2faddons%2fpackages%2fplugin.service.emby-next-gen-11.1.27.zip/ 2025-09-11 18:49:56.325 T:4600 error <general>: CAddonInstallJob[plugin.service.emby-next-gen]: invalid package special://home/addons/packages/plugin.service.emby-next-gen-11.1.27.zip Let me know if I can help
quickmic 1709 Posted September 12, 2025 Posted September 12, 2025 I'm not sure why this happens on some devices. The zip file is actually valid.
