EZEd 60 Posted September 11, 2025 Posted September 11, 2025 My setup is Hisense Google TV -> Denon X1600 rcvr using eARC. I'm running Emby Android TV client. If I queue up a movie with True HD sound and bring up stats for nerds it identifies the audio codec as TrueHD with (software decode) in parentheticals out to the side. When I bring up a movie with DTS-HD or MA sound the audio codec says DTS-HD (direct). This implies to me that DTS is playing direct but TrueHD is being transcoded. Is this correct? If so, how do I set Emby (what settings to make inside either server or client and/or both) to force pass-through for both TrueHD and DTS-HD/MA to my receiver which handles both natively without needing any audio transcoding on either?
yocker 1414 Posted September 11, 2025 Posted September 11, 2025 1 hour ago, EZEd said: My setup is Hisense Google TV -> Denon X1600 rcvr using eARC. I'm running Emby Android TV client. If I queue up a movie with True HD sound and bring up stats for nerds it identifies the audio codec as TrueHD with (software decode) in parentheticals out to the side. When I bring up a movie with DTS-HD or MA sound the audio codec says DTS-HD (direct). This implies to me that DTS is playing direct but TrueHD is being transcoded. Is this correct? If so, how do I set Emby (what settings to make inside either server or client and/or both) to force pass-through for both TrueHD and DTS-HD/MA to my receiver which handles both natively without needing any audio transcoding on either? TVs don't support passing through formats like TrueHD. You will need a player like a Nvidia Shield to be able to support formats like TrueHD. Rule of thumb is that TVs usually just support DD+ and 5.1. 2
EZEd 60 Posted September 11, 2025 Author Posted September 11, 2025 The TV supports DTS-HD. Which is odd that it would support DTS and not TrueHD. I would have thought it would be the other way around with TrueHD being more popular. Guess not.
Solution FrostByte 5454 Posted September 11, 2025 Solution Posted September 11, 2025 Check toward the back of your user manual for a chart listing supported audio codecs. I just picked a 2025 Hisense TV at random from their website and indeed it lists DTSHD, but not TrueHD.
yocker 1414 Posted September 11, 2025 Posted September 11, 2025 4 hours ago, EZEd said: The TV supports DTS-HD. Which is odd that it would support DTS and not TrueHD. I would have thought it would be the other way around with TrueHD being more popular. Guess not. Mine will play DTS-HD as well but anything over 5.1 channels will either lag a lot or gets transcoded.
