King Pin 34 Posted September 10, 2025 Posted September 10, 2025 I have the 3 episode mini-series of the tv show V. Full title is V: The Final Battle (1984) Emby brings it up as the show V from 1984-1085 with 19 episodes which is incorrect. I tried to use identify to match it but it reverts back to the incorrect match. I have tried matching using imdb & tvdb id numbers but it won't change. Is there a way to force it to use the IMDB id?
Solution GrimReaper 4926 Posted September 10, 2025 Solution Posted September 10, 2025 From some time in the past: 1 1
King Pin 34 Posted September 10, 2025 Author Posted September 10, 2025 LOL that was quick. Thank you Grim! 1
dcook 303 Posted October 10, 2025 Posted October 10, 2025 OP, I had the same issue: Was advised at the time to use TVDB as default, even though it wasn't the 1st choice in the metadata provider search list, I am not sure if they have fixed the order yet
Luke 42289 Posted October 10, 2025 Posted October 10, 2025 35 minutes ago, dcook said: OP, I had the same issue: Was advised at the time to use TVDB as default, even though it wasn't the 1st choice in the metadata provider search list, I am not sure if they have fixed the order yet @dcookthe order can be whatever you want it to be, based on what media you have. Generally tvdb is recommended, but there is no universal right or wrong order.
