embyzone 5 Posted September 6, 2025 Posted September 6, 2025 Hi All I am pretty sure there just to be a Add repository under the catalog? But I dont have that option anymore? So how do I add missing repositories to Emby today? I am missing some custom meta agents... Br Casperse
Neminem 1623 Posted September 6, 2025 Posted September 6, 2025 If you don't see this under plugins, we need logs.
embyzone 5 Posted September 6, 2025 Author Posted September 6, 2025 I do see that... I am talking about how to add the repositories of plugins that is not listed here? Or is that only a Jellyfin feature? (I am sure it was there when I first started using Emby many years ago)
Solution Neminem 1623 Posted September 6, 2025 Solution Posted September 6, 2025 TBH I have never seen a way to import a external source into Emby. That Being said, you can upload plugins to Emby plugin server folder. But side loaded plugins are sometimes not reliable. And please only use plugins, that state.... That they work with Emby. When you do this, it's out of Emby's control and dev's might not able to help you.
embyzone 5 Posted September 6, 2025 Author Posted September 6, 2025 Okay fair enough - I just thought that meta agents was less likely to break Emby. But I guess your right better to be safe than sorry. Thanks for clarifying this!
Neminem 1623 Posted September 6, 2025 Posted September 6, 2025 Well if its from this forum then you can try, loading it into your plugin folder. But be sure to report issues too where you read about it. 1
Luke 42242 Posted September 6, 2025 Posted September 6, 2025 You can copy the DLL into your plugins folder manually.
