BillOatman 597 Posted September 4, 2025 Posted September 4, 2025 How do I get rid of these channel numbers in the guide display? My primary interest is the android TV client.
Luke 42289 Posted September 4, 2025 Posted September 4, 2025 Hi there, have you explored clicking the icon at the top left of the guide?
BillOatman 597 Posted September 4, 2025 Author Posted September 4, 2025 20 minutes ago, Luke said: Hi there, have you explored clicking the icon at the top left of the guide? Thanks, that worked for the web client. How about the android tv client running on my shield? I've poked around everything I can see on the UI but see no way to turn that off.
Luke 42289 Posted September 4, 2025 Posted September 4, 2025 3 minutes ago, BillOatman said: Thanks, that worked for the web client. How about the android tv client running on my shield? I've poked around everything I can see on the UI but see no way to turn that off. Our standard android app will actually use the same setting, so just restarting the app now that you've changed it should be enough. Or perhaps just signing out and then back in.
BillOatman 597 Posted September 6, 2025 Author Posted September 6, 2025 On 9/4/2025 at 1:42 PM, Luke said: Our standard android app will actually use the same setting, so just restarting the app now that you've changed it should be enough. Or perhaps just signing out and then back in. No luck, the numbers in the web app are gone but they are still there on the android TV app.
BillOatman 597 Posted September 7, 2025 Author Posted September 7, 2025 On 9/6/2025 at 2:11 PM, Luke said: What version number of the app? Windows server 4.8.11.0 AndroidTV 2.1.23g Registered
Luke 42289 Posted September 7, 2025 Posted September 7, 2025 1 hour ago, BillOatman said: Windows server 4.8.11.0 AndroidTV 2.1.23g Registered Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
