Robert87354 18 Posted August 31, 2025 Posted August 31, 2025 (edited) @EZAM89lástimosamente Emby no sirver para la reproducción directa de TV, tengo igual una lista de IP TV y desde Emby se corta constantemente, da igual desde que dispositivo, si veo la IP TV directamente sin pasar por Emby, todo perfecto, mi experiencia con Emby y la TV no ha sido buena, recomiendo reproducir directamente la TV desde tu propio dispositivo, móvil, pc o smartTV. Edited September 18, 2025 by GrimReaper
Luke 42239 Posted August 31, 2025 Posted August 31, 2025 @Robert87354 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Solution Robert87354 18 Posted September 14, 2025 Author Solution Posted September 14, 2025 (edited) Cerrar este tema, ya no uso ip tv en emby. Gracias. Edited September 14, 2025 by GrimReaper
Robert87354 18 Posted September 17, 2025 Author Posted September 17, 2025 (edited) On 9/16/2025 at 10:02 PM, Luke said: @Robert87354Hi, why not? Hola, no he abierto este tema (lo abrió un moderado), el tema original donde tiene problemas y usan IP TV es Gracias. Edited September 18, 2025 by GrimReaper
Luke 42239 Posted September 17, 2025 Posted September 17, 2025 OK can you please give it another try? Thanks !
