HappyGilmour 20 Posted August 27, 2025 Posted August 27, 2025 (edited) Hi, I have some IPTV channels that I can get to play on VLC, they previously played on Emby but not are reporting "Tuner Not Found." I have attached my server log. Please let me know if you need additional info. Thank you. *****UPDATE: I saw online (Yes I actually searched before but didn't see this answer) to refresh the guide. So doing that now. I will let you know. Thank you. embyserver (2).txt Edited August 27, 2025 by HappyGilmour UPDATE
sa2000 697 Posted August 27, 2025 Posted August 27, 2025 1 hour ago, HappyGilmour said: I have some IPTV channels that I can get to play on VLC, they previously played on Emby but not are reporting "Tuner Not Found." I have attached my server log. Please let me know if you need additional info. Thank you Could see if enabling debug logging on the emby server gives some clues for this error 2025-08-27 10:27:36.506 Info LiveTvManager: Opening channel stream, external channel Id: m3u_a007a3c8ab205ed35580a0fa44d626a11e43be3c703e4ff3c944ea46ec55a76c_24.7.Dummy.us 2025-08-27 10:27:36.506 Info LiveTV: Streaming Channel m3u_a007a3c8ab205ed35580a0fa44d626a11e43be3c703e4ff3c944ea46ec55a76c_24.7.Dummy.us, with streamId: 794159ddb8069a27e35ad8e8dd231040 2025-08-27 10:27:36.510 Error MediaSourceManager: Error opening live stream *** Error Report *** Version: 4.8.11.0 System.Exception: System.Exception: Tuner not found. so please enable debug logging, restart the server to get fresh logs created and repeat the test. And as IP Addresses are probably relevant to the issue, suggest getting the raw embyserver.txt log rather than download a santized file. So after you reproduce the problem with debug logging, copy this file out C:\Users\donmo\AppData\Roaming\Emby-Server\programdata\logs\embyserver.log and send it to me by Private Message Also details of the iptv configuration setup in emby server
HappyGilmour 20 Posted August 27, 2025 Author Posted August 27, 2025 3 hours ago, sa2000 said: Could see if enabling debug logging on the emby server gives some clues for this error 2025-08-27 10:27:36.506 Info LiveTvManager: Opening channel stream, external channel Id: m3u_a007a3c8ab205ed35580a0fa44d626a11e43be3c703e4ff3c944ea46ec55a76c_24.7.Dummy.us 2025-08-27 10:27:36.506 Info LiveTV: Streaming Channel m3u_a007a3c8ab205ed35580a0fa44d626a11e43be3c703e4ff3c944ea46ec55a76c_24.7.Dummy.us, with streamId: 794159ddb8069a27e35ad8e8dd231040 2025-08-27 10:27:36.510 Error MediaSourceManager: Error opening live stream *** Error Report *** Version: 4.8.11.0 System.Exception: System.Exception: Tuner not found. so please enable debug logging, restart the server to get fresh logs created and repeat the test. And as IP Addresses are probably relevant to the issue, suggest getting the raw embyserver.txt log rather than download a santized file. So after you reproduce the problem with debug logging, copy this file out C:\Users\donmo\AppData\Roaming\Emby-Server\programdata\logs\embyserver.log and send it to me by Private Message Also details of the iptv configuration setup in emby server Hi, Thank you for your response and offer to help. Turns out it was the guide data needed to be refreshed. Thanks again! Don 2
