clarkss12 304 Posted August 27, 2025 Posted August 27, 2025 (edited) I have a lot of videos with the VC-1 video codec and Emby is identifying that codec and transcodes it correctly as it should. The problem is that it also transcodes the audio codec from DTS-HD MA to just plain DTS. All of the other videos without that VC-1 code play with DTS-HD MA. This happens on both Emby versions. Attached logs embyserver.txt ffmpeg-transcode-289ccb49-be85-4b96-95e9-ef7c05c18732_1.txt ffmpeg-transcode-686f29c2-d696-4619-a0a1-238870e71c53_1.txt hardware_detection-63891839594.txt Edited August 27, 2025 by clarkss12
Solution Luke 42176 Posted August 27, 2025 Solution Posted August 27, 2025 hi, when transcoding is needed you can't put dts into the HLS protocol that we're using, so that's why the audio gets converted as well.
clarkss12 304 Posted August 27, 2025 Author Posted August 27, 2025 14 hours ago, Luke said: hi, when transcoding is needed you can't put dts into the HLS protocol that we're using, so that's why the audio gets converted as well. Thank you for that information. 1
