Hoedus 1 Posted August 26, 2025 Posted August 26, 2025 Hello, After searching on the forum, I will submit my problem because I can not find a solution. I have a Windows server, I7-8700K, 32GB RAM, Full SSD (OS and Data). The server has a 2.5Gb network card, 10gb switch, 10gb NAS with SSD cache. The files are on the NAS. I have an Emby Premiere Lifetime License. If I don't enable hardware acceleration no read problem whatever the file type and format but I have a CPU at 80% So I installed a GTX1060 6gb with the latest Nvidia drivers. So I can choose the hardware decoders in the emby parameters. I tried everything, the different options, put a cache on a separate SSD, reduce the throughput, nothing does. On a 4K H265 HEVC file for example, the playback is not jerky but black screen, it starts again, black screen, it starts again and that every 2 seconds until you have the following message: "No compatible stream is currently available. Please try again later or contact your system administrator for more details." I hope you can help me Thank you.
Abobader 3491 Posted August 26, 2025 Posted August 26, 2025 Hello Hoedus, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2039 Posted August 26, 2025 Posted August 26, 2025 My server is a little below yours in spec (7th hen Intel, GTX 1050Ti), so I tried transcoding a 4k HEVC file by playing it in a browser (which I wouldn't normally do). It's behaving rather differently from yours. In the browser it's just sitting there with a spinner; but if I look at the user sessions (part of the diagnostics plugin) it shows the transcoding apparently progressing at about twice real speed, but the play position is jumping around between 0sec and about 5secs. Cpu is about 25%. It's worth noting that it is also burning in PGS subtitles (very few, as it's just the forced ones). I am attaching logs for my case (taken while it's still running) - you should also provide logs for your case to help the devs diagnose the reason. Paul ffmpeg-transcode-d95754b9-4d36-4208-ae02-b2a2bce8218d_1.txt embyserver(1).txt
Hoedus 1 Posted August 26, 2025 Author Posted August 26, 2025 Indeed, I also put my logs. ffmpeg-transcode-b88df7a9-0f87-407b-99e4-785aa74479e9_1.txt embyserver.txt
Neminem 1630 Posted August 26, 2025 Posted August 26, 2025 In both cases I would try with out PGS subs enabled.
Hoedus 1 Posted August 26, 2025 Author Posted August 26, 2025 In my case, even with the subtitles disabled I have the same problem.
Neminem 1630 Posted August 26, 2025 Posted August 26, 2025 Do you have Diagnostics plugin installed ? Warning: Hardware-accelerated subtitle-overlay is disabled due to diagnostic option Try unticking that, I have no idea if that would work.
pwhodges 2039 Posted August 26, 2025 Posted August 26, 2025 It makes no difference, which is not surprising when having no subtitles behaves the same. Paul
Hoedus 1 Posted August 26, 2025 Author Posted August 26, 2025 This plugin is not installed and I agree with Paul. While software transcoding works perfectly, the problem could come from poor management of hardware transcoding? I would be curious to know the configuration of the people with whom it works properly.
Luke 42289 Posted August 30, 2025 Posted August 30, 2025 Hi @Hoeduswe'll have a new ffmpeg build on the server beta channel in the near future, so stay tuned for that. Thanks.
Hoedus 1 Posted August 30, 2025 Author Posted August 30, 2025 Hi @luke, thank you for the information. i will wait ^^ 1
