michnmi 10 Posted August 26, 2025 Posted August 26, 2025 Hi team. As a user i want to be able to take advantage of the id3 tags regarding the song creators. For instance, i have an mp3 file with tags about the creators (composer and lyricist) These are based on https://docs.mp3tag.de/mapping/ In a song item in EMBY, if i edit the metadata i can see in the people categories that you have, among others, these roles: - Composer - Writer Would it be possible to pull those from the file (mp3) if the tags exist? Either create new roles or utilize the existing ones? Many thanks MM
beckfield 174 Posted August 27, 2025 Posted August 27, 2025 Emby does pull the composer from the TCOM tag in MP3 files. I don't think it pulls, or displays, the Lyricist (from TEXT tag in MP3), though. In my tag editor: In Emby, after re-scanning files: 1
Luke 42243 Posted August 30, 2025 Posted August 30, 2025 Right currently composer is supported, but not writer. So that's something to look at. 1
