Blueskies278 43 Posted August 25, 2025 Posted August 25, 2025 (edited) Dune Homatics Box R 4k android 12 Auto framerate switching not working - 29.97fps. Outputting 59 fps. 25/8/2025 - 15:16 Blueskies278 Log File: emby_android_1756131070389.txt Edited August 25, 2025 by Blueskies278 change wording
Blueskies278 43 Posted September 5, 2025 Author Posted September 5, 2025 On 25/08/2025 at 18:06, Luke said: Hi, we'll take a look at it. Thanks. Update: The Android TV version 2.1.27g detects 29.97 fps.
Luke 42241 Posted September 19, 2025 Posted September 19, 2025 Hi, can you please try this version? Thanks.
Blueskies278 43 Posted September 20, 2025 Author Posted September 20, 2025 (edited) 23 hours ago, Luke said: Hi, can you please try this version? Thanks. unfortunately 3.5.03 still outputting 59fps. A big thanks to all the Emby team trying to solve this bug. Not sure if this will help. As previously mentioned, the Android TV version (2.1.27g) outputs the correct fps. It has an extra setting “prefer exact refresh rate”. When disabled, it will output 59fps. Prefer Exact Refresh Rate enabled Edited September 20, 2025 by Blueskies278 edit
Luke 42241 Posted September 22, 2025 Posted September 22, 2025 OK we'll take another look at this. Thanks. 1
Solution Blueskies278 43 Posted November 9, 2025 Author Solution Posted November 9, 2025 (edited) Hi Luke, Currently using Emby for Android beta 3.5.16. I don't know when AFR switching for 29.97fps was fixed, but it's now working. Thanks Edited November 9, 2025 by Blueskies278 1
