Kelwarin 4 Posted August 24, 2025 Posted August 24, 2025 Hi! After update 2.1.7 or 2.1.8 there are a few new problems with Emby on KS7005. First, in collections of movies it does not show any of the movies. Second, if you look at an actor it does not show what movies he/she is in. Third, in the description a few letters is missing. You can see it on the second picture.
FrostByte 5453 Posted August 24, 2025 Posted August 24, 2025 Yes, if on beta server you will probably see this with all clients including web server.
Kelwarin 4 Posted August 24, 2025 Author Posted August 24, 2025 (edited) Im not on beta server. 4.8.11, and on web server everthing looks good. Only see this on my Samsung. Edited August 24, 2025 by Kelwarin
FrostByte 5453 Posted August 24, 2025 Posted August 24, 2025 I'm on 2.1.7 and not having the same issue on my 2018 Q8F. I can see the movies within a collection and the actors all show what movies from my library they are in. I'll see if I can find 2.1.8
FrostByte 5453 Posted August 24, 2025 Posted August 24, 2025 I wonder if the fix for the problem I was having then broke yours. Luke mentioned there might be some side-effects with 2.1.7, but I didn't see anything so may be model year specific.
Luke 42239 Posted August 24, 2025 Posted August 24, 2025 Hi, please see if 2.1.9 resolves your issue. Thanks.
Kelwarin 4 Posted August 24, 2025 Author Posted August 24, 2025 Hi, i can not see 2.1.9 for download.
FrostByte 5453 Posted August 24, 2025 Posted August 24, 2025 2 hours ago, Kelwarin said: Hi, i can not see 2.1.9 for download. It's on GitHub at the usually link in the pinned post. Just downloaded it myself and installed
