kenemby 0 Posted August 21, 2025 Posted August 21, 2025 I have just installed script X for the first time. What I want to achieve is this: Whenever a movie is added to my library (Movie_test), I want it to immediately scan and fetch the metadata. Is there any guide or manual that explains how to use this feature or any related resources I can refer to?
Neminem 1626 Posted August 21, 2025 Posted August 21, 2025 Ask here New Plugin - Custom Scripting | Emby ScripterX Or use this But search is your Friend
ebr 16346 Posted August 21, 2025 Posted August 21, 2025 3 hours ago, kenemby said: Whenever a movie is added to my library (Movie_test), I want it to immediately scan and fetch the metadata. Hi. You don't need any plugin for that. See option above.
