twiggy2cents 2 Posted August 20, 2025 Posted August 20, 2025 I attached the log file. The chapter extraction was the last thing in the log. I cant get it to generate images anymore and I am unsure what I am looking at in the logs. This is on linux but I was unsure if it was general emby or linux? Any advice? embyserver.txt
twiggy2cents 2 Posted August 20, 2025 Author Posted August 20, 2025 Welp this is self induced somehow. I had it on chapter extraction and not 10 second extraction. That seems to of fixed it. 1
Luke 42289 Posted August 20, 2025 Posted August 20, 2025 Thanks for following up. For what it's worth, any process such as this that needs to step through the file could potentially have difficulty with the mpegts format.
twiggy2cents 2 Posted August 20, 2025 Author Posted August 20, 2025 1 minute ago, Luke said: Thanks for following up. For what it's worth, any process such as this that needs to step through the file could potentially have difficulty with the mpegts format. I've been advised before to convert the media/container but I never settled on anything that worked well. The problem is that due to it being OTA some times I end up with corrupt video sections which emby chokes on. Usually trying to jump ahead works. The problem though is that the conversions I tried would also fail for the same reasons. Also there is times that we watch the episode as it is recording which I dont think we could do if we were transcoding it. 1
