HairyBizRat 21 Posted August 18, 2025 Posted August 18, 2025 Hi in a premium member and I’m having problems with cinema intros. This is my folder structure meda meda/movies media/tv shows i created a folder in media/intros Ann’s placed a mp4 file in there. I entered the custom path in cinema intros and did a library scan. when started a movie it played a random episode from one of my tv shows for some odd reason. So I moved the intros folder to the same parent folder as media u:/media u:/intros now nothing plays , what am i doing wrong here?
HairyBizRat 21 Posted August 18, 2025 Author Posted August 18, 2025 Not sure what happened as I changed nothing and it’s working now. is there a way to force cinemas intros for all users on all devices? I’d hate to have to login to each device and user to enable it
Solution Luke 42289 Posted August 18, 2025 Solution Posted August 18, 2025 1 hour ago, HairyBizRat said: Not sure what happened as I changed nothing and it’s working now. is there a way to force cinemas intros for all users on all devices? I’d hate to have to login to each device and user to enable it Hi, it can't be forced enabled on the server but our apps enable it by default. The only way it would be off is if the user disabled it. 1
