AdelioS 0 Posted August 18, 2025 Posted August 18, 2025 I have my tv programs set-up in the following folders Example tv/A/Altered Carbon/Season 01 Now like this it all works, but if i accidentally put a season folder at the same level as the program i,.e, tv/A/Season 01 It totally buggers up the "A" folder view in EMBY. Last time it happened (In the F Folder) it suddenly thought everything belonged to an anime called "F"
GrimReaper 4897 Posted August 18, 2025 Posted August 18, 2025 3 hours ago, AdelioS said: Last time it happened (In the F Folder) it suddenly thought everything belonged to an anime called "F" <root folder>/<TV show folder>/<Season folder> is the default TV shows naming convention - how do you expect Emby to interpret "tv/F/Season 01" as anything other than TV show titled "F"? To avoid such occurrences, add each letter subfolder separately as library path, instead of Tv shows root folder.
