Trapperjohn61 24 Posted August 17, 2025 Posted August 17, 2025 Hi, When using the app the android version not the fire tv version on my Firestick 4k max App version 3.4.74 Selecting a movie then just before selecting play the screen gives detail about the movie and also video,audio, and subtitle info. When looking at any tv show I see tv episode detail but no video , audio, subtitle information showing. Am I missing a setting if not it would be nice to have this also for tv shows since they do come in many video and audio types too.it would be helpful before playing which media type I am watching in case there could be a higher level available. Form the pics there is room to have this detail showing as in movies. I have attached pics showing the differences in the views. Thank you for your help, Bryan
Solution GrimReaper 4897 Posted August 17, 2025 Solution Posted August 17, 2025 17 minutes ago, Trapperjohn61 said: When looking at any tv show I see tv episode detail but no video , audio, subtitle information showing. You're looking at TV show detail screen - there's no MediaInfo details there - you need to look at episode detail screen, you'll have same info there. 1
Trapperjohn61 24 Posted August 17, 2025 Author Posted August 17, 2025 4 minutes ago, GrimReaper said: You're looking at TV show detail screen - there's no MediaInfo details there - you need to look at episode detail screen, you'll have same info there. Oh ok have to go few more levels deep to find the info but it is there Thanks for your help, Bryan 1 1
Trapperjohn61 24 Posted August 17, 2025 Author Posted August 17, 2025 Oh one more question when you go to a tv show and left an episode in the Selene not add this info there without having to go further down and go into the episode when you have resume in the first screen? There is room to put the info for the resumed prodded there?
GrimReaper 4897 Posted August 17, 2025 Posted August 17, 2025 14 minutes ago, Trapperjohn61 said: Oh one more question when you go to a tv show and left an episode in the Selene not add this info there without having to go further down and go into the episode when you have resume in the first screen? There is room to put the info for the resumed prodded there? That's a question for the Devs, but I'd assume reason to be twofold: one, those are single item properties and TV shows are collection of items, each of which can have different properties and two, it'd make that screen look quite busy (more than it already is). Those are just my assumptions, though. 1
Luke 42243 Posted August 17, 2025 Posted August 17, 2025 The other reason is that putting the media info right there would suggest that it's more important than being able to get to the season list of the series (or other episodes). I think that would be a problem for many. 1
Trapperjohn61 24 Posted August 17, 2025 Author Posted August 17, 2025 True you both have very good points. is there a link to where I can see the details of each update for the android app Which I assume is the one is hooked be using not the fire app version thank you, bryan
GrimReaper 4897 Posted August 17, 2025 Posted August 17, 2025 (edited) 10 minutes ago, Trapperjohn61 said: is there a link to where I can see the details of each update for the android app You can follow updates/Release notes for all Emby server/apps versions here: Edited August 17, 2025 by GrimReaper 1
Trapperjohn61 24 Posted August 17, 2025 Author Posted August 17, 2025 Thank you to both of you for the link have a great day bryan 1 1
