metropical 38 Posted August 17, 2025 Author Posted August 17, 2025 moved it to TV and Emby is rescanning now. See if that fixes it. Perhaps I should re-rip the files with Handbrake, if that doesn't work. 1
Happy2Play 9798 Posted August 17, 2025 Posted August 17, 2025 1 minute ago, metropical said: Perhaps I should re-rip the files with Handbrake, if that doesn't work That would be your best bet as no provider list this collection as one item and not sure if every item is listed on provider if you want to do individual movies either. But think TMDB has each one listed as a movie but doesn't looks like they all have images. example Act Without Words I (2001) — The Movie Database (TMDB) Act Without Words II (2001) — The Movie Database (TMDB)
metropical 38 Posted August 17, 2025 Author Posted August 17, 2025 If Emby comes up with first frame or nothing, that be fine. I thought the Sniper thing was a security breach.
metropical 38 Posted August 17, 2025 Author Posted August 17, 2025 emby stuck it back in Movies. Weird. Whoever did the meta on the DVD must have had their own convention. Re-ripping with Handbrake, but I doubt that'll be any better. Those same wrong images. It seems there was a film called Sniper. Sniper was named Beckett. Emby also came up with 2 copies of a film that I have only one. Perhaps this is an issue with Sequoia, as I am having other weird issues with other apps in Sequoia that were fine with Monterey. IIWII
metropical 38 Posted August 18, 2025 Author Posted August 18, 2025 didn't change anything. Just moved them to Movies and rescanned. In the long run, not worth the time you guys are good enough to lend and my tearing my hair out. As long as Emby sees it as a playable file, that'll do for this one collection. Thanks Luke & H2P 1
