svyaznoy362 17 Posted August 15, 2025 Posted August 15, 2025 (edited) On 6/19/2025 at 2:23 AM, Luke said: стандартное приложение Emby для Android Hi. I've been using the standard Emby Android app for 2 months and noticed a problem with AFR. In the mobile app, it often doesn't work, and instead of showing the movie at 24fps, it outputs it to me at 50fps. There is no such problem in the ATV version, the AFR always works correctly there. -When you add the detailed information about the file. The ATV version has many times more. -When will you add 1000 Mbps? Edited August 15, 2025 by svyaznoy362
Luke 42243 Posted August 16, 2025 Posted August 16, 2025 Quote When you add the detailed information about the file. The ATV version has many times more. hi, what piece of information do you think is missing?
