Keenuts 2 Posted August 12, 2025 Posted August 12, 2025 Hi, This is an issue I have on Emby for iOS 2.2.41 (serveur is 4.8.11.0 but shouldn't be relevant here). Overall, any layout/filtering/sorting option showed on the client is non-functional when the server is unreachable. Repro steps: - Connect to the server using the iOS application. - download some of the server music offline on the device. - put the phone offline (make sure the server is unreachable) - restart Emby iOS -> the server selection screen should be visible - select "Downloads" > "Music" > "Songs" - notice the display is sorted in a certain way, and shows large tiles - click on "...", and in view, instead of "Principal", select "List" - tap "done" Expected behavior: the list should change the a list view. Observed behavior: the list remains with large tiles. - click on the sorting icon - click on "sort by added date" Expected behavior: the list should now be sorted with the most recently added song first. Observed behavior: the sorting doesn't change. Note: this bug does not happen if the server is reachable, and I click "Change server > Downloads" and do the same steps. Seems like this only happens when the server is truly unreachable. 1
Luke 42239 Posted August 17, 2025 Posted August 17, 2025 HI, yes the goal and what we are working on is bringing views of downloaded content fully up to speed with server connected content. Thanks for reporting.
