MEGAMEGO 2 Posted August 8, 2025 Posted August 8, 2025 i have some .MKV TV series episodes that has an SRT files for subtitles that will not show as well as .ASS embedded subtitles for the same but only that happens on my MI stick, when using web interface on windows or using android app on phone i have no problem showing the subtitles .
Luke 42289 Posted August 8, 2025 Posted August 8, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
MEGAMEGO 2 Posted August 8, 2025 Author Posted August 8, 2025 the problem is from MI stick that is used only through internal network and has no internet connection to send report can this be done from the emby server PC ?
ebr 16354 Posted August 8, 2025 Posted August 8, 2025 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
MEGAMEGO 2 Posted August 9, 2025 Author Posted August 9, 2025 tried to download emby only but loading very slowly and not playing videos. but i got a work around . i have to play the video and select the subtitle and then go back and select again subtitle and start the video and again select the subtitle when the video is playing . only then subtitle will appear.
Luke 42289 Posted August 9, 2025 Posted August 9, 2025 14 hours ago, MEGAMEGO said: tried to download emby only but loading very slowly and not playing videos. but i got a work around . i have to play the video and select the subtitle and then go back and select again subtitle and start the video and again select the subtitle when the video is playing . only then subtitle will appear. Hi, what version number did you test with?
MEGAMEGO 2 Posted August 10, 2025 Author Posted August 10, 2025 4 hours ago, Luke said: Hi, what version number did you test with? Server version: 4.8.11.0 Mi stick with emby for android tv version 2.1.23g registered
MEGAMEGO 2 Posted August 10, 2025 Author Posted August 10, 2025 if i changed to x264 has no problem i can see subtitles .(direct play) i guess there is a problem while transcoding
seanbuff 1360 Posted August 10, 2025 Posted August 10, 2025 6 hours ago, MEGAMEGO said: Mi stick with emby for android tv version 2.1.23g registered This is not the correct application that the Devs were suggesting you try. That particular app is no longer under active development. Search for "Emb" in the app store (without the 'Y'), you will see two results. Install the other one and see how it compares. 1
MEGAMEGO 2 Posted August 10, 2025 Author Posted August 10, 2025 3 hours ago, seanbuff said: This is not the correct application that the Devs were suggesting you try. That particular app is no longer under active development. Search for "Emb" in the app store (without the 'Y'), you will see two results. Install the other one and see how it compares. emby for android tv is one of these 2 apps the other one loads but when i try to play any movie it does not respond.
Luke 42289 Posted August 10, 2025 Posted August 10, 2025 4 hours ago, MEGAMEGO said: emby for android tv is one of these 2 apps the other one loads but when i try to play any movie it does not respond. Hi, what version number of the other one did you try?
MEGAMEGO 2 Posted August 11, 2025 Author Posted August 11, 2025 10 hours ago, Luke said: Hi, what version number of the other one did you try? Emby for android 3.4.74
Luke 42289 Posted September 8, 2025 Posted September 8, 2025 On 8/10/2025 at 11:21 PM, MEGAMEGO said: Emby for android 3.4.74 @MEGAMEGO Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
