vluobotou 1 Posted August 5, 2025 Posted August 5, 2025 Hello developer, I am a lifetime member. May I ask if Emby has implemented the long press speed playback feature? I need this standard function.
ebr 16337 Posted August 5, 2025 Posted August 5, 2025 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
Luke 42243 Posted August 6, 2025 Posted August 6, 2025 Many Emby apps now have a setting that allows you to configure the long press action during video playback. We will add the playback speed menu as one of the options that you can pick, so that long pressing the OK button during playback will pull up the playback speed menu. Thanks.
vluobotou 1 Posted August 7, 2025 Author Posted August 7, 2025 21 hours ago, Luke said: Many Emby apps now have a setting that allows you to configure the long press action during video playback. We will add the playback speed menu as one of the options that you can pick, so that long pressing the OK button during playback will pull up the playback speed menu. Thanks. Are you saying that this feature will be implemented in the future? I mainly install the EMBY client on TV. I have tried other TV external players, but none of them are as user-friendly as EMBY and do not have the feature of long press and double speed. Therefore, I sincerely hope that the TV version client can provide a long press and double speed playback. Currently, the TV version uses long press to display media information, or if there is a way to modify it, I can customize the middle key myself, which is also acceptable to me.
Luke 42243 Posted August 7, 2025 Posted August 7, 2025 HI, yes the long press will be to pull up the playback speed menu, if you configure it that way.
