chowbok 136 Posted August 3, 2025 Posted August 3, 2025 I have my subtitle mode set to "Default", which works how I want it all of the time, except when a video has closed captions. Emby always selects these as on by default. As far as I can tell, there's no way to set or unset a "default" flag for CC in MKV metadata, and no way to get rid of the captions without reencoding the video. Is there any way I can set it so it doesn't default to them being on?
JoLas 26 Posted August 8, 2025 Posted August 8, 2025 (edited) I've had a couple of movies with EIA-608 close captions, they're not visible as a normal subtitle tracks and always selected. First I tried MKVToolNix to strip away subtitles like I normally do but I couldn't find them there. I managed to strip it out using ffmpeg: ffmpeg -i input.mkv -codec copy -bsf:v "filter_units=remove_types=6" output.mkv If you have a H.265 video and CTA-708 closed captions the command is: ffmpeg -i input.mkv -codec copy -bsf:v "filter_units=remove_types=39" output.mkv Edited August 8, 2025 by JoLarsson
Luke 42290 Posted August 8, 2025 Posted August 8, 2025 Hi, you might want to try the Smart subtitle mode instead of default. That will look at languages more than the default flag.
chowbok 136 Posted August 8, 2025 Author Posted August 8, 2025 34 minutes ago, Luke said: Hi, you might want to try the Smart subtitle mode instead of default. That will look at languages more than the default flag. Problem with "Smart" is that it doesn't load "forced" when the spoken language matches your preferred language. That should be changed IMO.
ebr 16354 Posted August 9, 2025 Posted August 9, 2025 16 hours ago, chowbok said: Problem with "Smart" is that it doesn't load "forced" when the spoken language matches your preferred language It does for me. Perhaps we should look at an example.
JoLas 26 Posted August 15, 2025 Posted August 15, 2025 (edited) I also had intermittent success with "Smart" so kept it "Always play subtitles". Some media types didn't work... I got a few complaints from some users when I had Smart and I didn't feel like troubleshooting so just flipped it back to how it has been for years. Edited August 15, 2025 by JoLarsson
