CarneAsada 12 Posted September 17, 2025 Posted September 17, 2025 That fixed the problem, thank you very much! 1
yocker 1423 Posted September 17, 2025 Author Posted September 17, 2025 17 hours ago, Flippz said: Would it be possible to add a function that adds a Notification or meaasge to the Emby front page? I sadly don't think that's possible. The way i do it my self is i make a movies library and then put a custom image with a message on it for people to read. 1
yocker 1423 Posted September 17, 2025 Author Posted September 17, 2025 New quick version (v1.1.6) Added "time-out" feature. This will give selected user a time-out for X number of minutes. Think a long the lines of dinner time for children. Download here or on the WatchingEye - Github WatchingEye.dll 1
yocker 1423 Posted September 18, 2025 Author Posted September 18, 2025 New version (1.1.9.0) Just finished something i have been working on for a while. I've added an API system so the time limits can be controlled remotely through external programs or such. The readme is located in the settings for the plugin. !!! I will not make any programs or anything for this, that is up to someone else to do, at least it's a possibility now. !!! Please consider it beta as i have only tested it with scripts and programs like Postman but it should work 100%. WatchingEye.dll
feerlessleadr 173 Posted September 18, 2025 Posted September 18, 2025 1 hour ago, yocker said: New version (1.1.9.0) Just finished something i have been working on for a while. I've added an API system so the time limits can be controlled remotely through external programs or such. The readme is located in the settings for the plugin. !!! I will not make any programs or anything for this, that is up to someone else to do, at least it's a possibility now. !!! Please consider it beta as i have only tested it with scripts and programs like Postman but it should work 100%. WatchingEye.dll 355 kB · 0 downloads Thanks for the API. Do you have any examples that you could share that folks could use as a starting point?
yocker 1423 Posted September 18, 2025 Author Posted September 18, 2025 4 minutes ago, feerlessleadr said: Thanks for the API. Do you have any examples that you could share that folks could use as a starting point? For now the info is in the readme on the settings page in the plugin. But i have this script for postman i used for testing. WatchingEye.postman_collection.json
yocker 1423 Posted September 18, 2025 Author Posted September 18, 2025 (edited) 30 minutes ago, feerlessleadr said: Thanks for the API. Do you have any examples that you could share that folks could use as a starting point? You can also try this version i used to develop it. It has a built in webserver so you can just enter a website to control it outside Emby. For example "http://EmbyServerIP:9988" In Windows you will need to open command prompt as admin and write: netsh http add urlacl url=http://*:9988/ user="Everyone" Then in the plugin activate the webserver and then reset Emby. You will get a webpage like this: This should work better for mobiles that going into Emby it self. I didn't add it because it was for testing and it has that requirement in Windows for it to work, but it's an easy way to use the API system. The version number is higher because i changed some stuff before uploading it here. WatchingEye.dll Edited September 18, 2025 by yocker
yocker 1423 Posted September 19, 2025 Author Posted September 19, 2025 The latest build is now on the WatchingEye Github
yocker 1423 Posted September 21, 2025 Author Posted September 21, 2025 New version (1.2.7.0) Added: 1) Ability to stop transcoding of specific formats like for example mkv, av1 and so on. 2) List of libraries to be excluded from notifications and transcode blocks. Download here or on WatchingEye Github WatchingEye.dll
kikinjo 294 Posted September 23, 2025 Posted September 23, 2025 @yockerAny chance for blocking 4K resolution transcoding under Transcode Blocking, with custom message ?
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 3 hours ago, kikinjo said: @yockerAny chance for blocking 4K resolution transcoding under Transcode Blocking, with custom message ? Funny you should ask, i have just put the finishing touch on precisely that. It hasn't been fully tested yet so please consider it beta for now, the testing i have done shows it working 100& though. If you find a problem or suggestion for a change then please report it to me so i can fix it. WatchingEye.dll 1
PeteGul 41 Posted September 23, 2025 Posted September 23, 2025 The notifications is god send for me. But, is there a way to make the show a litt bit longer. I'm a litte bit slow reader 1
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 (edited) 8 minutes ago, PeteGul said: The notifications is god send for me. But, is there a way to make the show a litt bit longer. I'm a litte bit slow reader There's no way to get them to show any longer. Instead there's a setting to show them multiple times. Edited September 23, 2025 by yocker
kikinjo 294 Posted September 23, 2025 Posted September 23, 2025 For resolution blocking we need custom message before stream is killed. Currently there is no option to set message, but i know yocker will deliver
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 (edited) 8 minutes ago, kikinjo said: For resolution blocking we need custom message before stream is killed. Currently there is no option to set message, but i know yocker will deliver Yep, working on it. Completely block resolution transcoding with a message or message and THEN stop video? Edited September 23, 2025 by yocker 1
PeteGul 41 Posted September 23, 2025 Posted September 23, 2025 Then I don't understand how. 1st It's how many max to send totally 2nd Delay between the messages, but they only show one time. I don't think people can change a movie within 4 seconds? 3rd Between different messages. As far as I understand, there isn't a choice to show one message twice. Sorry if I don't understand.
kikinjo 294 Posted September 23, 2025 Posted September 23, 2025 First message ( user clicks ok on message) , then stream is killed.
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 2 hours ago, PeteGul said: Then I don't understand how. 1st It's how many max to send totally 2nd Delay between the messages, but they only show one time. I don't think people can change a movie within 4 seconds? 3rd Between different messages. As far as I understand, there isn't a choice to show one message twice. Sorry if I don't understand. I should change the wording on those settings, they can indeed be a little confusing. Max number of notifications is how many times it should send the message. Initial delay is how long it should take before the first message. Delay is how long of a delay between the messages.
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 2 hours ago, kikinjo said: First message ( user clicks ok on message) , then stream is killed. That might be hard to do as i don't think the confirmation button can trigger anything.
yocker 1423 Posted September 23, 2025 Author Posted September 23, 2025 2 hours ago, yocker said: I should change the wording on those settings, they can indeed be a little confusing. Max number of notifications is how many times it should send the message. Initial delay is how long it should take before the first message. Delay is how long of a delay between the messages. I added a confirmation button and a custom message option. Sadly i can't make it so that the video gets stopped when pressing ok because of how the messaging works. Btw. please note that these messages might not work for all clients (I don't have one to test with but Roku might be a problem) but they should for the vast majority. I also quickly made a small performance improvement, the timers now tick every 15 seconds and only checks relevant streams. As it was before a busy server with many users could have the plugin take a bit more resources than was necessary. As before this is still a small beta as it's fresh out the oven so please report any problems. Next on todo, clean up the settings page.. It's a bit of a mess. WatchingEye.dll 1
kikinjo 294 Posted September 24, 2025 Posted September 24, 2025 @yocker I have tested last version for 4K trascode killing / warning. We have chicken / egg situation here . I force it to trancode on 4K and then i get the fist warning about trancoding (the genral one)...it does not get to 4K killing at all. So if have to guess, check should be first check for 4k transcoding than show message and kill it. 4K actions should have priority over others, at least i see it like that. 1
yocker 1423 Posted September 24, 2025 Author Posted September 24, 2025 1 hour ago, kikinjo said: @yocker I have tested last version for 4K trascode killing / warning. We have chicken / egg situation here . I force it to trancode on 4K and then i get the fist warning about trancoding (the genral one)...it does not get to 4K killing at all. So if have to guess, check should be first check for 4k transcoding than show message and kill it. 4K actions should have priority over others, at least i see it like that. Yeah, i've been a fool and didn't think of that, i noticed it my self last night when doing more testing. It should hopefully be fixed in this version. Also made the transcoding reason messages a bit more robust so they actually warn about the right thing. Many thanks for reporting it!! Please report if you find any other things wrong so it can be fixed. WatchingEye.dll 1
kikinjo 294 Posted September 24, 2025 Posted September 24, 2025 (edited) Resolution blocking and message test, all working fine Thank you very much for this @yockerthis 4k transcode blocking feature is missing from emby for years, i m pretty sure a lot of users will use this. Cheers man ! Shoot me some address so i can send some money for few beers. Edited September 24, 2025 by kikinjo 1
yocker 1423 Posted September 24, 2025 Author Posted September 24, 2025 21 minutes ago, kikinjo said: Resolution blocking and message test, all working fine Thank you very much for this @yockerthis 4k transcode blocking feature is missing from emby for years, i m pretty sure a lot of users will use this. Cheers man ! Shoot me some address so i can send some money for few beers. Many thanks, appreciate the kind words and happy i could help. A thanks to you as well for testing and reporting! I have a buy me a coffee here https://buymeacoffee.com/yockser But you absolutely don't have to, i'm happy as long as i can make something people like to use. 1 1
