bilalm 1 Posted August 2, 2025 Posted August 2, 2025 Hello. I have just installed Emby today. But i can't fast forward and rewind in 4k videos. I am using with direct wifi connect with local ip address. Can you help me please? Device: Terramaster f2-223 Nas Emby version: 4.8.11.0 Video file: 7.83gb .mkv, 4K HEVC HDR Dolby
Luke 42233 Posted August 2, 2025 Posted August 2, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
bilalm 1 Posted August 3, 2025 Author Posted August 3, 2025 7 hours ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Hi. Thank you for your reply. I added log file here. embyserver.txt
bilalm 1 Posted August 4, 2025 Author Posted August 4, 2025 Also added ffmpeg logs ffmpeg-remux-d25c6615-920a-44e7-9dba-01a02a006540_1.txt
SamES 1084 Posted August 6, 2025 Posted August 6, 2025 On 04/08/2025 at 23:09, bilalm said: Also added ffmpeg logs ffmpeg-remux-d25c6615-920a-44e7-9dba-01a02a006540_1.txt 109.98 kB · 1 download Just be aware that this log file is not from playback on the LG TV. App: Emby Web 4.8.11.0 Chrome macOS User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36
bilalm 1 Posted August 6, 2025 Author Posted August 6, 2025 14 minutes ago, SamES said: Just be aware that this log file is not from playback on the LG TV. App: Emby Web 4.8.11.0 Chrome macOS User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36 Sorry it was another device's log. Forwarding issue doesn't throw ffmpeg log file. I tried again now with transcoding and without transcoding. Here is the new log file, mb it helps you. embyserver.txt
SamES 1084 Posted August 6, 2025 Posted August 6, 2025 Is it just the one file that has this issue? I suspect there might be an issue with the file encoding
bilalm 1 Posted August 6, 2025 Author Posted August 6, 2025 2 minutes ago, SamES said: Is it just the one file that has this issue? I suspect there might be an issue with the file encoding There is no ew encoding log file. Only embyserver.txt. I check old logs and found this but idk it related to LG WebOS because it not includes App info (or i can't found). ffmpeg-transcode-fd554619-5484-4336-ace8-4dd9ab237095_1.txt
SamES 1084 Posted August 6, 2025 Posted August 6, 2025 4 minutes ago, bilalm said: There is no ew encoding log file. I mean the actual file itself that you are trying to play. If it hasn't been made correctly then you can have issues with things like ff/rew. That's way I ask if it is just one file that has an issue or all files.
bilalm 1 Posted August 6, 2025 Author Posted August 6, 2025 34 minutes ago, SamES said: I mean the actual file itself that you are trying to play. If it hasn't been made correctly then you can have issues with things like ff/rew. That's way I ask if it is just one file that has an issue or all files. It happens on entire season videos but I downloaded all from same source.
Neminem 1619 Posted August 6, 2025 Posted August 6, 2025 4 hours ago, bilalm said: It happens on entire season videos but I downloaded all from same source. Blacklist that source and buy the media and rip it your self. Like most things in life " If you want it done right, do it your self " 1
Solution SamES 1084 Posted August 6, 2025 Solution Posted August 6, 2025 9 hours ago, bilalm said: It happens on entire season videos but I downloaded all from same source. If it is just that season from the one source then likely it has not been correctly encoded at creation. If other files/sources play correctly, then that would mostly confirm it.
bilalm 1 Posted August 8, 2025 Author Posted August 8, 2025 On 07/08/2025 at 01:02, SamES said: If it is just that season from the one source then likely it has not been correctly encoded at creation. If other files/sources play correctly, then that would mostly confirm it. Yes it related to video file. I tried another 4k hevc video and it is working perfect. 1
SamES 1084 Posted August 9, 2025 Posted August 9, 2025 12 hours ago, bilalm said: Yes it related to video file. I tried another 4k hevc video and it is working perfect. Thanks for confirming. 1
