Best "Device" for Emby Client for a 4k TV
Yeah PC is what I'll use. Up to last month, I still had in mind that Dolby Vision and HDR10 wasn't possible to be played though a pc and send the signal to a TV. Was the case for a while (specially for MKV) but thing evolve and now, it can be played. I will have to update my GPU since my Quadro P4000 only have DP port and DP to HDMI cable doesn't give proper communication to the tv and thus, no DV support.
  • 1 month later...
On 8/3/2025 at 3:57 AM, Dizzy49 said:
The Firecube I have has a NIC built in.  It's only 100Mbps, which I can't understand why that would do that with a GB connector is like 3 cents more.  With a speed test I get 90Mbps wired, and 485Mbps wireless.  I have tried both Wired and Wireless and experienced the same issues.
I picked this MiniPc up on Black Friday for $140.  The problem is the wife factor.  If I'm home and set it up it's great, but the second I leave the house she tries to watch something and all hell breaks loose and I hear about it for MONTHS about what a waste of money everything was if she can't ever use it.
Reading your thread -- I literally laughed out loud.  Welcome to my world -- been married 37 years so I KNOW your situation / pain/ joy / etc
So @Dizzy49- what did you settle on ?   I have had an Nvidia Shield for years (but I think it is failing).  I got a great deal on a mini PC Amazon Prime Days -- looking for best thing to use it for lol
How are you controlling the Windows (via Remote)?
Problem with google tv streamer is that it doesn'T support many audio codec. While you might see it do get them, it actually convert them to pcm. There's no Dolby TrueHD nor DTS-HD or even DTS:X support for passthrough. It's actually the same as the Chromecast 4k and Onn Pro 4k.
My onn pro4k plays all audio & video formats
Not because it plays that's its pass-through, which is what I want. The onn 4k pro doesn't support Dolby truehd or dts:x just like any smart tv and Google tv. Yes it will play. Depending on the device, either emby will convert it before sending it or it will receive it the player will convert it before output. Google TV actively transcode to pcm all format it doesn't pass-through..
https://www.reddit.com/r/AndroidTV/s/tI8ANF6F6n
