rechigo 367 Posted July 30, 2025 Posted July 30, 2025 (edited) Is it expected behavior for PGSSUBS to burn-in on Android mobile? I could have sworn last time I used Emby, PGSSUBs are able to direct play on the Android client. Also I'm noticing that DTS-HD is not direct playing, but I also vaguely remember being able to direct play on Android. I have an S25+, Android 15, Emby Android 3.4.74, 4.7.1.12 server beta Edited July 30, 2025 by rechigo
Luke 42241 Posted July 30, 2025 Posted July 30, 2025 The app can handle both of those without transcoding, so maybe it's the quality setting.
rechigo 367 Posted July 30, 2025 Author Posted July 30, 2025 I verified its not due to quality setting. I have max quality selected and server reflects that the reason for transcoding is incompatible codec
Luke 42241 Posted July 30, 2025 Posted July 30, 2025 I would check the playback settings in the app to make sure you're not forcing conversions on any formats.
rechigo 367 Posted July 31, 2025 Author Posted July 31, 2025 I see "convert unsupported surround audio to DD" option is the reason for audio transcoding. Thanks for pointing out. Now for the subs issue... If you enable PGSSUB while direct streaming, emby will switch to a transcode and burn them in. If you enable them while direct playing, they play without burn in. Am I correct to assume this is a limitation of HLS protocol only being able to supply text/vtt subtitles? If so, is there any way for you guys to somehow work around this in the future?
Luke 42241 Posted July 31, 2025 Posted July 31, 2025 Quote If you enable PGSSUB while direct streaming, emby will switch to a transcode and burn them in. If you enable them while direct playing, No idea what you mean? We use those two terms interchangeably. They mean the same thing.
Luke 42241 Posted July 31, 2025 Posted July 31, 2025 Quote Am I correct to assume this is a limitation of HLS protocol only being able to supply text/vtt subtitles? Right, you can't put PGS into HLS.
