impaych 3 Posted July 24, 2025 Posted July 24, 2025 I just purchased a Roku voice remote RCA1R. It works fine except that after I delete a TV episode in Emby it exits out of Emby and takes me back to the TV's main screen. I tested it on 2 different TCL/Roku TV's and they both kick me out to the main menu after deleting an episode. My older voice remotes and IR remotes delete without exiting Emby. Roku calls the remote RCA1R but my TCL TV says it is a RC1082. Any idea why pressing OK to delete something would kick me out of Emby?
ebr 16332 Posted July 24, 2025 Posted July 24, 2025 Hi. I doubt this has anything to do with the remote. That is probably a coincidence. Can you please go into your Roku settings and turn on "Debug Option". Then re-start the app and create the problem. Then restart the app and immediately go to the user menu and select the "Send log" option. Then come back here and tell me when you did that. Thanks.
impaych 3 Posted July 24, 2025 Author Posted July 24, 2025 I agree that it shouldn't have anything to do with the remote, yet it keeps happening only with that remote. I sent you the log you requested. Thanks.
ebr 16332 Posted July 25, 2025 Posted July 25, 2025 23 hours ago, impaych said: I sent you the log you requested. Thanks. This is a really weird one. What version of the app does your Roku show?
impaych 3 Posted July 25, 2025 Author Posted July 25, 2025 Version 4.1 build 46. After 2 days of consistent behavior, the same thing happened last night on a different TCL/Roku TV with an old remote. I don't know if that helps or makes it even weirder. Same version of Emby on both TV's. Thanks.
ebr 16332 Posted July 25, 2025 Posted July 25, 2025 Did you already have the debug option turned on in the app before I asked you to send the log?
impaych 3 Posted July 25, 2025 Author Posted July 25, 2025 Possibly. I don't think so but now I'm not sure. How come?
ebr 16332 Posted July 26, 2025 Posted July 26, 2025 17 hours ago, impaych said: Possibly. I don't think so but now I'm not sure. How come? Just for kicks try turning it off and restarting the app and then see if the problem still occurs. Thanks.
impaych 3 Posted July 26, 2025 Author Posted July 26, 2025 Debug is turned off and I restarted Emby. I watched an episode, deleted it and Emby disappeared and left me back at the main Roku screen. Also, this was using my original remote. Thanks.
ebr 16332 Posted July 26, 2025 Posted July 26, 2025 Thanks for trying. I think I've chased this issue down. Thanks for reporting. If you will wait a few seconds after returning from playback before deleting the item, I believe you will avoid this problem. Wait until the screen updates with the new next up episode and proper watched status, etc.
impaych 3 Posted July 26, 2025 Author Posted July 26, 2025 Great! I will give it a try tonight. Thanks again. 1
impaych 3 Posted July 27, 2025 Author Posted July 27, 2025 Still having trouble. Now when an episode is nearing the end and I press the back arrow to go back to the series screen it takes me out of Emby and back to the Roku home screen. I couldn't even try deleting until I went back into Emby. At least I know it has nothing to do with the new remote! Thanks.
ebr 16332 Posted July 27, 2025 Posted July 27, 2025 13 hours ago, impaych said: to go back to the series screen You are playing from the series screen? How are you deleting an episode from there?
impaych 3 Posted July 27, 2025 Author Posted July 27, 2025 I may not be using the correct terminology. I watched episode 5 of a 6 episode series. While the episode credits were playing I used the back arrow on the Roku remote to go back to the episode 5 screen. Instead of taking me back to the episode 5 screen Emby disappeared and left me at the main Roku menu screen. Next, I went back into Emby and to the series I was watching and selected episode 5 and then selected the delete button.
