ryancey 56 Posted July 22, 2025 Posted July 22, 2025 (edited) It takes a few tries each time to be able to drag the item. I guess a perfect vertical movement is needed to trigger the drag, but it is rarely the case with a trackpad or a mouse, even more when the drop target is a playlist on the side of the window (needing an horizontal movement). Screencast from 2025-07-22 15-06-24.webm Edited July 22, 2025 by ryancey 1
brothom 205 Posted July 22, 2025 Posted July 22, 2025 2 minutes ago, ryancey said: It takes a few tries each time to be able to drag the item. I guess a perfect vertical movement is needed to trigger the drag, but it is rarely the case with a trackpad or a mouse, even more when the drop target is a playlist on the side of the window (needed an horizontal movement). Screencast from 2025-07-22 15-06-24.webm 321.89 kB · 0 downloads @ryanceyit's not just songs. All of the playlist / drag / drop elements in Emby (especially the web app) have this issues. Dragging items inside a playlist is basically a 50/50 chance; sometimes it works and sometimes it doesn't. I agree though, on desktop the horizontal "swipe" to delete items seems so unnecessary.
