sentinel1970 1 Posted July 19, 2025 Posted July 19, 2025 Just updated to the new version Emby for Samsung tvs (2.1.0) now the episode description can't read the words they disappear into the backdrop. Only happens on the Samsung app.
Luke 42239 Posted July 19, 2025 Posted July 19, 2025 Hi there, can you please show a screenshot of what you mean? Thanks.
sentinel1970 1 Posted July 19, 2025 Author Posted July 19, 2025 Only does this on my samsung Tv model suhd tv series 8000. LG and android boxes are fine with this. Server is 4.8.11.0
sentinel1970 1 Posted July 20, 2025 Author Posted July 20, 2025 the emby samsung tv app gives you Closed Caption on shows only the app. My android box on same tv does not do any of these things
Luke 42239 Posted July 26, 2025 Posted July 26, 2025 @sentinel1970what is the full model number of your TV?
Luke 42239 Posted July 28, 2025 Posted July 28, 2025 OK so a 2017 model? We are looking into it. Thanks.
FrostByte 5453 Posted July 28, 2025 Posted July 28, 2025 7 hours ago, Luke said: OK so a 2017 model? We are looking into it. Thanks. K=2016 model. An M8000 would be 2017.
sentinel1970 1 Posted July 29, 2025 Author Posted July 29, 2025 (edited) The Closed Caption is fixed does not do it anymore. Looks like other people are having the same issue. Kelwarin (Difficult to read the plot) has the same problem. Edited July 29, 2025 by sentinel1970
Solution Luke 42239 Posted August 1, 2025 Solution Posted August 1, 2025 Hi, can you please try installing 2.1.5 and let us know if the issue is resolved? Thanks.
Luke 42239 Posted September 12, 2025 Posted September 12, 2025 1 hour ago, Danhcc said: Have the same issue Model: UN60KU630D Hi, it should be resolved in the next app update. Thanks. 1
