stehohrhase 1 Posted July 19, 2025 Posted July 19, 2025 When playing mp4 in LG App (1.0.47), the audio langage is wrong. That means: Select German -> Audio is english Select English - > Audio is german The mp4-File is ok. Emby for ios and android plays correct. General Complete name : movie.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/dby1/iso2/mp41) Audio #1 ID : 3 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ec-3 Duration : 1 h 21 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 149 MiB (4%) Language : German Service kind : Complete Main Default : No Alternate group : 1 Audio #2 ID : 4 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ec-3 Duration : 1 h 21 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 149 MiB (4%) Language : English Service kind : Complete Main Default : Yes Alternate group : 1
SamES 1084 Posted July 19, 2025 Posted July 19, 2025 (edited) Hi, what model TV (Model number)? Edited July 19, 2025 by SamES
SamES 1084 Posted July 19, 2025 Posted July 19, 2025 Did this work fine with the previous app version?
SamES 1084 Posted July 19, 2025 Posted July 19, 2025 Can you please also check that the TV has the latest firmware version? Thanks
stehohrhase 1 Posted July 19, 2025 Author Posted July 19, 2025 Yes - webOS 4.4.3-22 is latest version. I am new at Emby (came from plex) - i don't know, if previos version work. But when i use the Jellyfin APP v1.2.2, i see the emby Web 4.8.11.0 and Audio works like expected. When i use the Emby APP v1.0.47, the i see Emby for LG 1.0.47 with the problem. As workoround, i use Jellyfin in the moment.
SamES 1084 Posted July 19, 2025 Posted July 19, 2025 Thanks and I presume this is DirectPlay. Can you please also confirm that you have this same problem regardless of whether your select the audio track before playback and also during playback. We've seen this issue previously, and it's caused when the audio track marked as 'Default' is not the first audio track, which I can see in your example (Audio track 2 is the default). You can check if you have some examples with multiple Audio tracks but track 1 marked as the default - these examples should work correctly, but it would be great if you can confirm. The problem is that LG automatically swaps the audio tracks so that the 'default' track becomes the first track. We have resolved this by also swapping our track order to match, so I'm surprised that you are seeing this issue. I think all the previous examples where I have seen this were mkv files, so I'm wondering if MP4 files have a different issue. 1
stehohrhase 1 Posted July 19, 2025 Author Posted July 19, 2025 Yes - direct play. Yes - when i select the track before playback, is also wrong. For example, i select German before playback, it shows me during playback German - but is it english. Then i marked the first audio track as default - then the plaback is corrrect ! Is it possible to fix this ? Audio #1 ID : 3 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ec-3 Duration : 1 h 21 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 149 MiB (4%) Language : German Service kind : Complete Main Default : Yes Alternate group : 1 tagc : public.main-program-content Audio #2 ID : 4 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ec-3 Duration : 1 h 21 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 149 MiB (4%) Language : English Service kind : Complete Main Default : No Alternate group : 1
Luke 42233 Posted July 19, 2025 Posted July 19, 2025 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
SamES 1084 Posted July 19, 2025 Posted July 19, 2025 8 hours ago, stehohrhase said: Is it possible to fix this ? I need to see if I can replicate this issue (but I don't have a TV the same as yours), then I need to try and confirm if it is only an mkv issue, or if it affects other formats. Can you find a similar mkv file with multiple audio tracks, try setting the second track to the default track, then see if you can reproduce this issue using an mkv format. That would be really helpful. Thanks.
stehohrhase 1 Posted July 20, 2025 Author Posted July 20, 2025 i have testet with mkv files. They have not that issue. Audio is always correct. No different witch audiotrack is default. Attached is the log file from an mp4 playbak with this issue. embyserver.txt
SamES 1084 Posted July 20, 2025 Posted July 20, 2025 Perfect, that sounds like our correction is working but only needs to be applied for mkv files. Thanks.
SamES 1084 Posted July 21, 2025 Posted July 21, 2025 On 20/07/2025 at 12:52, stehohrhase said: i have testet with mkv files. They have not that issue. Audio is always correct. No different witch audiotrack is default. Attached is the log file from an mp4 playbak with this issue. embyserver.txt 44.78 kB · 0 downloads I was able to reproduce this issue for mp4 files. It should be fixed for the next release. Thanks
stehohrhase 1 Posted October 10, 2025 Author Posted October 10, 2025 Now is 3 month ok. How long need the fix and new release ?
Luke 42233 Posted October 10, 2025 Posted October 10, 2025 14 hours ago, stehohrhase said: Now is 3 month ok. How long need the fix and new release ? Hi, as soon as it gets through LG review. Thanks.
Alien0 1 Posted November 14, 2025 Posted November 14, 2025 Just found this thread - though something was wrong with my setup but I see it's an app issue. Hopefully there will be a fix soon.
stehohrhase 1 Posted December 22, 2025 Author Posted December 22, 2025 On 10/10/2025 at 9:17 PM, Luke said: Hi, as soon as it gets through LG review. Thanks. May I politely ask for an update? I can't believe it's taken 6 months/half a year for an LG review.
Luke 42233 Posted December 22, 2025 Posted December 22, 2025 3 hours ago, stehohrhase said: May I politely ask for an update? I can't believe it's taken 6 months/half a year for an LG review. Hi, unfortunately LG has a tendency to fail app submissions for really silly or meaningless reasons. So this is what happened and we had to submit again and now we are waiting for the app review process again. Thanks. 1
Alien0 1 Posted December 26, 2025 Posted December 26, 2025 Finally the update came today on my LG - audio issues seem to be fixed 1
