tedfroop21 89 Posted July 18, 2025 Posted July 18, 2025 2025-07-18 08:46:42.534 Error Main: Error writing pid file: /var/run/emby-server.pid I'm guessing the update executed some recursive command to set permissions and reset the pid file permissions. Other than direct intervention in the OS is there a way to fix it.? It seems Metadata fetching and loffing is what is affected. The server seems usable still apart from that.
Solution tedfroop21 89 Posted July 18, 2025 Author Solution Posted July 18, 2025 Think I got it. Set file owner to emby:emby and don't see the error on reboot. embyserver.txt
