chrisrobbins1970 82 Posted July 18, 2025 Posted July 18, 2025 Is there a way to use the background; The Purple Smoke. across all the media sections... Be able to use the same PURPLE SMOKE background in the TV section or Movies...
ebr 16332 Posted July 18, 2025 Posted July 18, 2025 Afraid not. If you have the option to show backdrops while browsing on, it is going to show the backdrop assigned to the item in focus. If you turn it off, it will just show the default background.
chrisrobbins1970 82 Posted July 18, 2025 Author Posted July 18, 2025 Yes. I figured that, but thought I'd ask. I suppose no way to implement that either?
ebr 16332 Posted July 18, 2025 Posted July 18, 2025 I wouldn't say "no way" but I also wouldn't say that we'll be allowing you to customize that any time soon. However, we will eventually have themes in the app that will give you some more background options.
chrisrobbins1970 82 Posted July 18, 2025 Author Posted July 18, 2025 Themes ...that sounds interesting
