blackcatTN 3 Posted May 4, 2025 Posted May 4, 2025 Getting same error with AV1 files. Other file types play ok. 2025-05-03 22:52:47.385 Info App: ProcessRun 'StreamTranscode ac3da1': Stopping ffmpeg process with q command for /mnt/c/transcoding-temp/73265A/73265A_0.ts 2025-05-03 22:52:47.387 Info App: AppendExtraLogData - Read graph file: /var/lib/emby/logs/ffmpeg-directstream-ac3da126-64e9-4a02-848c-b3039aeaa6f4_1graph.txt 2025-05-03 22:52:47.387 Warn App: AppendExtraLogData: Unable read graph output file: /var/lib/emby/logs/ffmpeg-directstream-ac3da126-64e9-4a02-848c-b3039aeaa6f4_1graph.txt 2025-05-03 22:52:47.389 Info App: ProcessRun 'StreamTranscode ac3da1' Process exited with code 137 - Failed
Luke 42243 Posted July 16, 2025 Posted July 16, 2025 @blackcatTN Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
