LordVZlomka 6 Posted July 14, 2025 Posted July 14, 2025 Hi, I'm running Emby on a D923+ Synology NAS and tried to download the Trailers plugin, but instead of the section working, it created a new folder in the main section (near movies, shows, music, etc.). What am I doing wrong? Also, the green link does not direct to the plugin, but instead to the catalog.
Luke 42239 Posted July 14, 2025 Posted July 14, 2025 Hi, this has been resolved as part of the upcoming 4.9 server release. Thanks.
LordVZlomka 6 Posted July 14, 2025 Author Posted July 14, 2025 3 hours ago, Luke said: Hi, this has been resolved as part of the upcoming 4.9 server release. Thanks. I'm running Version 4.8.11.0, how do I get 4,9?
Happy2Play 9811 Posted July 15, 2025 Posted July 15, 2025 2 hours ago, LordVZlomka said: I'm running Version 4.8.11.0, how do I get 4,9? You have to install the beta version over your current install found via your platform download page. Download Emby - Emby But note if you install the beta version you can not downgrade without a clean install of restoring a full backup of Emby before the installation of 4.9 do to database changes.
LordVZlomka 6 Posted July 15, 2025 Author Posted July 15, 2025 (edited) 1 hour ago, Happy2Play said: You have to install the beta version over your current install found via your platform download page. Download Emby - Emby But note if you install the beta version you can not downgrade without a clean install of restoring a full backup of Emby before the installation of 4.9 do to database changes. This is how I back it up, right? It will not affect the media metadata (images etc) if I upgrade/downgrade right? Edited July 15, 2025 by LordVZlomka
Solution Luke 42239 Posted July 15, 2025 Solution Posted July 15, 2025 14 hours ago, LordVZlomka said: This is how I back it up, right? It will not affect the media metadata (images etc) if I upgrade/downgrade right? Hi, you cannot degrade from 4.9 to 4.8 without having to do a fresh install, so just be aware of that.
