Todd3835 2 Posted July 12, 2025 Posted July 12, 2025 Having some issues with Emby's scrobbling to Trakt. I even tried issuing a new API key and tried that and still nothing. Am I doing something wrong? Attached screenshot of my settings, and attached the log which is showing errors. embyserver.txt
Luke 42176 Posted July 12, 2025 Posted July 12, 2025 Quote I even tried issuing a new API key and tried that and still nothing Hi, what exactly did you do?
Todd3835 2 Posted July 12, 2025 Author Posted July 12, 2025 I clicked get API, went to Trakt, hit authorize or whatever, copied new API key and put it into Emby and hit Save. I had noticed that scribbling stopped 2 weeks ago and figured best option was to generate a new key.
Todd3835 2 Posted July 13, 2025 Author Posted July 13, 2025 Ok, guessing something broke in the recent update then. I was thinking it was something I did wrong, but if you are having a problem also, sounds like it's not something I did.....
Solution Luke 42176 Posted July 13, 2025 Solution Posted July 13, 2025 On 7/12/2025 at 2:10 PM, Todd3835 said: I clicked get API, went to Trakt, hit authorize or whatever, copied new API key and put it into Emby and hit Save. I had noticed that scribbling stopped 2 weeks ago and figured best option was to generate a new key. Hi, can you try this again and see how things compare? Thanks.
Todd3835 2 Posted July 13, 2025 Author Posted July 13, 2025 Not sure why this suddenly worked now, but it appears it has. Is there any way to see a log of what I've watched in the last few weeks easily? I need to mark some things as watched in Trakt..... 1
