bugman9317 5 Posted July 6, 2025 Posted July 6, 2025 This is the first time I have had an issue with a file playing since I started using Emby. I'm just trying to trouble shoot it so I know what's going on if it ever happens again. It is a 4K - Remux HEVC 5.1 DTS Sound file, but I have many of these in my library and never have any issues. If I play this file on my tablet using wifi, it plays fine - direct play at 95mbs Setup - Hardwired Nvidia Shield Direct Play, Samsung 8k TV In Emby, when I hit play, it loads to the play screen, but just stays black. I have all my settings at max for streaming, and if I go into setting and reduce down to 4k - 80mbs, it will play. Anything higher, it will stop playing. Speed isn't an issue because its hardwired on my Shield. It's weird, I tried like 10 other files that are that are about the same, without any issues. Even LOTR, and its about the highest bit rate file I have. I did get the movie to play once by waiting for about 2 minutes on a blank screen, but once I try to start agian, it just stays on a black screen. If I load up Plex, the file direct plays without any issues. Any insight would be great.. I attached the logs embyserver.txt
Abobader 3491 Posted July 6, 2025 Posted July 6, 2025 Hello bugman9317, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42301 Posted July 7, 2025 Posted July 7, 2025 HI, can you try updating to the latest version of Emby for Android and see if that helps? Thanks.
bugman9317 5 Posted July 7, 2025 Author Posted July 7, 2025 Thanks for the reply. I just updated and rebooted my Shield, but that file does the same thing. It goes through the cinema intro, and looks like its going to play, but just goes to a black screen. It puts the Rated R in the top left corner, but just doesn't play.
Luke 42301 Posted July 7, 2025 Posted July 7, 2025 OK we're looking into it. Workaround for now would be to disable cinema intros. Thanks.
bugman9317 5 Posted July 7, 2025 Author Posted July 7, 2025 Thanks. I turned the intros off, and it still doesn't play. Im thinking its something with the Nvidia Shield. I have two Onn 4k boxes in my bedrooms, and the movie plays fine. I have two Nvidia Shields, and tried it on both of them, and it just won't play. It's weird because the Nvidia will normally play anything.
Luke 42301 Posted July 12, 2025 Posted July 12, 2025 On 7/7/2025 at 6:01 PM, bugman9317 said: Thanks. I turned the intros off, and it still doesn't play. Im thinking its something with the Nvidia Shield. I have two Onn 4k boxes in my bedrooms, and the movie plays fine. I have two Nvidia Shields, and tried it on both of them, and it just won't play. It's weird because the Nvidia will normally play anything. Hi, can we please see a new log example? Thanks.
bugman9317 5 Posted July 12, 2025 Author Posted July 12, 2025 I attached the newest log. I tried playing it, and left it go on a black screen for about 2 minutes, and then backed out. I've narrowed it down. It has to be something with processing DTS HD MA audio. I would think that if it couldn't process the audio, it would just transcode it, but for some reason with this file, it doesn't transcode. I just got a new Zidoo Z9x for my theater. It plays the file fine, and I am using Emby, just with an external player instead of the one from Emby. If I try to play it on the Zidoo with the internal player, it does the same thing the Nvidia does. The Nvidia won't play it no matter what I try. It's even weirder because I tried my Jurassic Park movies, and they have the same DTS HD MA audio, but they play fine with the Nvidia and Zidoo. When I play this movie on my Onn 4K box, it plays direct play, and if I play it in Plex, it will direct play Emby On Onn Box English DTS-HD MA 5.1 (Default) Direct Play On Plex Audio Direct Play (English - DCA 5.1) I'm not sure what the problem is, I was just trying to figure it out. embyserver.txt
Luke 42301 Posted July 13, 2025 Posted July 13, 2025 On 7/12/2025 at 1:36 PM, bugman9317 said: I attached the newest log. I tried playing it, and left it go on a black screen for about 2 minutes, and then backed out. I've narrowed it down. It has to be something with processing DTS HD MA audio. I would think that if it couldn't process the audio, it would just transcode it, but for some reason with this file, it doesn't transcode. I just got a new Zidoo Z9x for my theater. It plays the file fine, and I am using Emby, just with an external player instead of the one from Emby. If I try to play it on the Zidoo with the internal player, it does the same thing the Nvidia does. The Nvidia won't play it no matter what I try. It's even weirder because I tried my Jurassic Park movies, and they have the same DTS HD MA audio, but they play fine with the Nvidia and Zidoo. When I play this movie on my Onn 4K box, it plays direct play, and if I play it in Plex, it will direct play Emby On Onn Box English DTS-HD MA 5.1 (Default) Direct Play On Plex Audio Direct Play (English - DCA 5.1) I'm not sure what the problem is, I was just trying to figure it out. embyserver.txt 62.59 kB · 0 downloads Hi, we're looking into it. Thanks.
