Dont1982 8 Posted July 27, 2025 Author Posted July 27, 2025 (edited) So turn off UPnP on the router and manual forward the port. The port 8099 is for internal connection and the 8096 is for external according to the network section of the settings in emby. And i set up all the other ports because i seen them in the help article about connections. Update: Turned off Upnp and only have the 2 ports 8069 and 8099 forwarded and restarted the server and still have no access. Edited July 27, 2025 by Dont1982
Solution Q-Droid 1011 Posted July 27, 2025 Solution Posted July 27, 2025 Yes, turn off UPnP and manually forward focusing on the port(s) you need. Did you choose 8099 for a specific reason? You can change it but can stick with it for now. In the Emby Network settings make sure: - "Allow remote connections" is enabled. - "Local http port number" is 8099 - "Remote http port number" is 8096 Then on your router setup one, and only one port forwarding rule for WAN port 8096 (public) to LAN port 8099 on .243 (local). Should probably have an IP reservation for the Emby server if you haven't done so already or if not static IP. Should you decide to make the ports consistent using the default then change ALL 8099 values above to 8096 and restart the Emby server.
Dont1982 8 Posted July 27, 2025 Author Posted July 27, 2025 3 minutes ago, Q-Droid said: Yes, turn off UPnP and manually forward focusing on the port(s) you need. Did you choose 8099 for a specific reason? You can change it but can stick with it for now. In the Emby Network settings make sure: - "Allow remote connections" is enabled. - "Local http port number" is 8099 - "Remote http port number" is 8096 Then on your router setup one, and only one port forwarding rule for WAN port 8096 (public) to LAN port 8099 on .243 (local). Should probably have an IP reservation for the Emby server if you haven't done so already or if not static IP. Should you decide to make the ports consistent using the default then change ALL 8099 values above to 8096 and restart the Emby server. I will try this in the morning and report back. All of the ports were there when I installed Emby. External connections are allowed. And I have already bind the ip for the computer running the server. 38 minutes ago, Luke said: 1
Dont1982 8 Posted July 28, 2025 Author Posted July 28, 2025 (edited) I changed the ports to 8096 and set the port forwarding in the router and it works now. I wonder why i had to change the ports like that with this router and didn't have too with the other router? Any who, thank you all for the help, no we will see if i still have the half show recordings happen. Will give it a few days and report back. Edited July 28, 2025 by Dont1982 1
Q-Droid 1011 Posted July 28, 2025 Posted July 28, 2025 You're welcome. It'll be less confusing going forward using same port values.
Dont1982 8 Posted July 30, 2025 Author Posted July 30, 2025 The secret of skinwalker ranch only recorded 24 minutes of an hour show. i have attached the log from yesterday. Any ideas why this is happening? Should have recorded 8pm to 9pm. embyserver-63889430400.txt
Luke 42240 Posted August 7, 2025 Posted August 7, 2025 On 7/30/2025 at 7:21 AM, Dont1982 said: The secret of skinwalker ranch only recorded 24 minutes of an hour show. i have attached the log from yesterday. Any ideas why this is happening? Should have recorded 8pm to 9pm. embyserver-63889430400.txt 48.77 MB · 0 downloads Hi, looks like it went 40 minutes, no? 2025-07-29 20:39:57.720 Info LiveTV: Recording completed to: E:\TV Shows\The Secret of Skinwalker Ranch (2020)\Season 6\The Secret of Skinwalker Ranch S06E09 Darting Around.ts
Dont1982 8 Posted August 7, 2025 Author Posted August 7, 2025 It only recorded 24 minutes of the show. And the show is 1 hour show so it should have been 1 hour and 4 minutes due to the buffer I have set.
Luke 42240 Posted August 7, 2025 Posted August 7, 2025 3 hours ago, Dont1982 said: It only recorded 24 minutes of the show. And the show is 1 hour show so it should have been 1 hour and 4 minutes due to the buffer I have set. What makes you think it was only 24 minutes?
Dont1982 8 Posted August 8, 2025 Author Posted August 8, 2025 because when i go into the tv shows and go into that show it only shows 24 minutes under the episode and when i open the episode to watch it it is only 24 minutes long. I have deleted it and downloaded it from the interwebs so i could watch the full show.
Luke 42240 Posted August 8, 2025 Posted August 8, 2025 Can you try refreshing the metadata on it and see if that updates the runtime?
Dont1982 8 Posted August 8, 2025 Author Posted August 8, 2025 It wasn’t just the meta data. When I tried to watch it it was only 24minutes. The show with no commercials is 43 minutes and with commercials and the buffer should have been 1h4minutes
