noistr 5 Posted July 2, 2025 Posted July 2, 2025 If the video quality is not selected as automatic, and other resolutions and bit rates are selected for transcoding, the video will be very stuck or cannot be played directly. I checked that my graphics card gtx1650 can encode and decode videos in addition to av1 format, but other formats can be used. However, when I watch the transcoding, the GPU is basically not working, but the CPU is working at full capacity. What is the reason?embyserver-1.txt embyserver-2.txt embyserver-3.txt ffmpeg-transcode-1a689363-72f0-4008-859d-393afc5a6efc_1.txt ffmpeg-transcode-07d69225-6371-4fd2-97c8-7122ad7c129c_1.txt ffmpeg-transcode-df894e96-7f6d-4ee0-9c4a-d1451ab3e1c5_1.txt ffmpeg-transcode-021a87b5-81bd-4d34-ae7c-334642597fac_1.txt ffmpeg-transcode-1491a027-6215-46cc-8323-941225008916_1.txt ffmpeg-transcode-eeffd6cc-0cc1-47c2-a42c-a84e983327e2_1.txt ffmpeg-transcode-e5bf9125-c121-4a7a-ae93-ff79c83f8f0f_1.txt ffmpeg-transcode-e84e2bcd-084e-4359-a331-db4afac6f47f_1.txt ffmpeg-transcode-7ced4f8b-8cad-4b13-a33d-76d2e02c66b3_1.txt ffmpeg-transcode-ca0bb54f-2bd6-4132-a1f6-fa5ed462136f_1.txt ffmpeg-transcode-8c9869f9-79b5-4361-aa09-f44ce42ed4a6_1.txt ffmpeg-transcode-55c75be0-b2ed-47b9-be5a-1c83896e1a0c_1.txt ffmpeg-transcode-3c79aaeb-415a-4d1e-a590-f9b315b6eb23_1.txt ffmpeg-transcode-90de2ca2-647f-4519-9342-e73c4b528261_1.txt ffmpeg-remux-5f91b193-bcfc-474d-93f9-ddc26a90dbff_1.txt
noistr 5 Posted July 3, 2025 Author Posted July 3, 2025 On 2024/11/17 at AM11点24分, Luke said: 由于您同时拥有 cuvid 和 nvdec 解码器选项,您是否尝试过更改优先级来测试它们? I have the same situation as zzsx644, also using GTX1650, I am using WIN11 system, the interface shows hardware acceleration, but in fact the GPU usage is 0, and the CPU usage is about 80,I have tried the method you mentioned, it doesn't work
Luke 42290 Posted August 1, 2025 Posted August 1, 2025 @noistrHi, we are looking into this. We will have an updated ffmpeg build on the server beta channel in the near future, so stay tuned for that.
noistr 5 Posted August 2, 2025 Author Posted August 2, 2025 11 hours ago, Luke said: @noistrHi, we are looking into this. We will have an updated ffmpeg build on the server beta channel in the near future, so stay tuned for that. OK, I don't use Windows system anymore, I use Synology DVA3221 version 7.2.1 instead, I can call my graphics card to transcode, but I have to uncheck the option starting with Nvdia in the settings and check the option starting with CUDA. Now it can be used normally, but the emby version is still 4.8.8.0. Synology's suite updates very slowly, but it doesn't matter, as long as it can be used now. I am most afraid that the suite will not work after the update, after all, Synology version 7.2.2 no longer supports hardware transcoding. I hope the emby update of the suite will not affect the transcoding, thank you
Luke 42290 Posted August 11, 2025 Posted August 11, 2025 On 8/2/2025 at 12:19 AM, noistr said: but I have to uncheck the option starting with Nvdia in the settings and check the option starting with CUDA. hi, for some this is normal as there are two different techniques that can be used with Nvidia. It's not always possible to auto-detect which one should be used, so some will have to configure it manually. Thanks.
