DomMortuus 1 Posted July 1, 2025 Posted July 1, 2025 When I use the "Photos" section of my Video & Photos library the photo I see in the thumbnail is not the same as the photo that is displayed when I click on it. The metadata for the thumbnail seems to be correct, but it still doesn't link to the correct photo. I have removed, scanned, and re-added the library. I've also done that same process and deleted all the .info files from the folders before re-adding. Each time there is no resolution to the issue. Does anyone have advice on how to fix this? I'm in the process of archiving a lot of old photos from CDs and if this won't work with Emby, I'll need to find a better solution. I've attached a log file from right after re-adding the library today. embyserver.txt
DomMortuus 1 Posted July 5, 2025 Author Posted July 5, 2025 Did I report this issue correctly or should I put this in a different section?
DomMortuus 1 Posted August 19, 2025 Author Posted August 19, 2025 Would you guys like any more info in this behavior in order to troubleshoot?
Luke 42289 Posted August 19, 2025 Posted August 19, 2025 2 hours ago, DomMortuus said: Would you guys like any more info in this behavior in order to troubleshoot? Hi, we have reproduced and are working on it. Thanks.
DomMortuus 1 Posted October 16, 2025 Author Posted October 16, 2025 It looks like this is fixed now. Thank you! 1
